Question about Sony Cyber-shot DSC-W50 Digital Camera
Lens stuck halfway open
My lens is stuck half way open and wont open or close any further
Fully charge the battery or connect the camera to the power supply (if you have an ac adaptor).
If it still does not work, it means that the lens is broken.
Reason can be that the camera was in your pocket pr carrying bag and the camera inadvertantly open and the lens mechanism was damaged. In this case, it needs repair.
Posted on Apr 21, 2008
The sunroof is half closed and the other half is slightly open. How do I fix this ?
Do you mean that your sunroof is stuck halfway and now won't open or shut correctly? This sounds like a normal setting with the roof half closed and the deflector at the front beginning to close. If it won't move from there first check the fuse but it would be smart to look for silly simple things like a piece of road debris stuck in one of the runners.
Oct 22, 2015 | 2002 Protege Lx Sunroof Motor
My lens shutter is stuck half closed and will not open and close any further. Is there something I can do to fix this problem?
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Apr 29, 2010 | Panasonic DMC-TZ5 Digital Camera
The lens is stuck out- it wont close and the screen reads "lens error" how can i fix this?
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 17, 2010 | Nikon COOLPIX L3 Digital Camera
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Lumix dmctz2 lens protector gets stuck halfway open
This usually happens due to dust or grit in the camera lens mechanism. I usually dont advise people to fix it themselves but if you are desperate and you need to save the cash and have the patience then follow this article. You will find it worth your while.
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jan 12, 2009 | Panasonic Lumix DMC-TZ2 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
313 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
