Just got 1st laptop acer 530, 2nd hand no instuctions, dont know where ac adapter plugs in. do i need it to run laptop on mains electricity, sorry for ignorance but afraid to just give it ago,without knowledge, thanks for any help in advance .
    Genius:
  • 3,587 Answers
It has a power pack..that goes into the wall, and the other end of the power pack goes into an opening on back or side of laptop.
I'd recommend you get a basic computer training course.
Posted on Apr 21, 2008
No power nec laptop
The first thing I would try is taking the battery out and trying to power the laptop on mains-only power, next I would try changing your AC adapter, or checking you AC adapter is outputting electricity using a multimeter. If you KNOW the AC is working, perhaps the DC socket that the AC adapter plugs into is damaged and needs replacing. If it's none of those things there could be a more serious fault with the laptop, such as motherboard failure.
Jan 31, 2014 | Computers & Internet
AC adapter 4750z
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
If you need to buy a new laptop charger, the following to adapters are for your reference:
Replacement Acer Aspire 4750 AC Adapter 65Watt 19V 3.42A
Replacement Acer Aspire 4750 AC Adapter 90Watt 19V 4.74A
Nov 15, 2012 | Acer Pwr Ac Adapter For Travelmate 4750...
I have an acer aspire one aand even though I plug it up it says (plugged in, not charging.) How do I make it charge?
Welcome to FixYa!
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 17, 2011 | Acer Aspire One PC Notebook
I have Samsung NP-R505H laptop. My laptop won't
You say it isn't charging, but will it run off of AC power? If it isn't getting *ANY* AC power, then it might be the female end of the power jack on the laptop. If it will run on AC, the culprit is likely to be a battery that needs replaced.
May 13, 2011 | Samsung Computers & Internet
Acer Aspire 7741Z - 4643 that is only 2 month old. It is plugged in, and recognizes that it is plugged in, but does NOT charge the battery. Please let me know what to do. Thanks, Not charging
Hope this will help...Your response is very much appreciated...
Feb 06, 2011 | Acer Aspire One PC Notebook
BOOTING PROBLEM
If the computer will not power on:
  1. Make sure the power cord or AC adapter is plugged into the computer and into an electrical outlet that is live.
  2. If it is plugged into a power strip or surge protector make sure it is powered on.
  3. Try using a different electrical outlet.
  4. Check voltage setting on power source (AC Adapters are auto switching).
  5. Perform a power reset on the computer.
To perform a power reset:
  1. Unplug and remove the AC adapter and battery, or power cable from the computer.
  2. Press and hold the power button on the computer for about 30 seconds.
  3. Release the power button and plug the AC adapter and battery, or power cord back into the computer.
  4. Press the power button and see if the computer powers up.
  5. If that does not work, try a different AC adapter, battery, or power cable and repeat these steps.
If the problem persists the computer may need service. You may need to contact Acer support.
Nov 24, 2010 | Acer Aspire 5100 Notebook
My Acer Aspire 9805WKHi wont turn on past the main acer start-up screen after my battery died. I didn't realize it wasn't plugged into the ac adapter so it was running only on battery.
Try taking out the battery and just plug in the ac adapter and see if it powers on that way. If it does use it that way for about 30 minutes then shut down. Put the battery back in, and keep it plugged in and wait about 30 minutes before you turn it on. This should refresh the battery enough to start charging.
Aug 24, 2010 | Acer Aspire 9805WKHi Notebook
My Acer Aspire 5720 laptop won't charge while it's running
Hello there:
try removing the battery from the computer and turning on the computer to see if the power cord works correctly if it does inspect the battery and clean the terminals on the battery and computer and put the battery back in while it is still on now you should see the battery show up on the taskbar if not right click anywhere on the desktop and go to properties and than go to than go to screensaver than look towards the bottom and you will see power click on it and you should see the options for the battery ok sorry this was so long but i needed to explain it in full
please dont forget to rate this
best regards mike
(usn retired)
Jul 30, 2009 | Acer Aspire 5720-6661 Notebook PC
It seems that my laptop want go to ac (adapter) and shuts down
Most likely your problem is caused by a loose connection on the main board of the laptop. Even though it will plug in to the connection, the connection on the mainboard is either cracked or broken. Laptops are VERY hard to work on and you need to find a authorized repair shop for that brand computer in your local area to properly fix this problem.
Dec 22, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
41 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
