Question about Lexmark Office Equipment & Supplies
Lexmark x4270 power connection the cord plugs into a black box but it doesen't seem to work Lightas on fax machine come on and off
  • tellblb Jul 18, 2010
    yes but we need to know where we can find a manuel?
  • 2,272 Answers
Remove the cartridges from the printer.On the cartridges there will be brown color dotted circuit.clean that circuit with a moist tissue also the clean the circuit in the printer where cartridges are inserted. Then reinsert the cartridges and check.If still the same blinking lights problem then its the fault of any of the cartridges.Replace both the cartridge one by one.But if the cartridge replacement does not solve the issue then its not the problem power cord or black color box in which power wire is inserted.Its the problem of printers logic card .That has to be checked and replaced. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 17, 2010
  • 1 more comment
  • tellblb Jul 17, 2010
    we do not have a book how do we remove the cartridges?
    Thanks for your help. we fixed the problem but now could you tell me where we can find a manuel?
  • raj somaiya
    raj somaiya Jul 18, 2010
    To get the manual please click on the link below
    http://www.retrevo.com/support/Lexmark-X...
    After you click the link there will be a option in dark blue color
    "download the manual".
    click that option.
    After you click that option there will be 5 digit code shown on the page.exactly fill that 5 digit code and then click the option shown in red color that "download now"
    the manual will be downloaded in few seconds.
    This will help you to get the manual.
    Thanks for keeping updated with your query.
Lexmark X4270 won't send out a fax
If you have DSL. you need a filter on the line you are trying to fax through.
Mar 24, 2012 | Lexmark X4270 All-In-One InkJet Printer
My lexmark x4270 constantly say's black cartidge missing..but I just placed a new cartridge in...please help me!!!!
Make sure you are inserting a genuine Lexmark cartridge.
Try to re-insert the cartridge into the printer. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
Should you still experience the problem even with a genuine Lexmark cartridge, please contact Lexmark Technical Support Center for additional assistance.
Oct 07, 2011 | Lexmark X4270 All-In-One InkJet Printer
I cannot receive faxes on my lexmark X4270. It will ring but nothing come through
Please go through the following checklists:
  • Make sure the that the fax line is working. To check, insert a telephone device straight to the fax line. You should get a dial tone.
  • Make sure the telephone cord from the phone jack in the wall is plugged into the Line port on the back of your Lexmark printer.
  • Assign the correct fax number on the printer.
  • If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
  • If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
If these don't help, please contact Lexmark Technical Support Center for additional assistance.
Sep 24, 2011 | Lexmark X4270 All-In-One InkJet Printer
I tried to send a fax but the machine turn on and off by it self and only the fax button keeps on, it makes the noise like if going to send the fax, but it turn off
It could be that the printer is not getting enough power. Pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. This will help reset the printer.
If that doesn't help, try to plug the printer into a different known working power outlet to verify that it's not a faulty power outlet issue.
Sep 09, 2011 | Lexmark X4270 All-In-One InkJet Printer
My lexmark x4270 can't connect message. what do I do?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have error 1200 on my lexmark x4270 fax machine after installing new black cartridge.
The 1200 error code indicates that the cartridge carrier has stalled. It could be due to the new black cartridge installed in the printer. Make sure you are using the correct version of black cartridge for your model and it's properly inserted in the cartridge carrier.
To remedy the problem, try to remove the black cartridge from the carrier > close the cover > unplug and re-plug the printer into the power source to reset it > when the printer turns on, re-insert the new black cartridge > check for any errors. If problem continues, try to insert a different known working black cartridge to determine if the new one is faulty.
For further troubleshooting, you may also refer to this article found in the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
Jul 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
Does a lexmark x4270 have a power cord or power box?
The printer requires to be plugged into the power source with the power cord connected to its power adapter to function. Please contact Lexmark technical support for assistance if you lost the cord or the adapter. Thanks.
Feb 25, 2011 | Lexmark X4270 All-In-One InkJet Printer
Printer will not function. Power light on, fax light on. Won't turn off with buttons. Disconnected power and usb and reconnected, still nothing. Can it be set back to factory specs?
Refer to this article How to Restore the Factory Defaults on the Lexmark X4250/X4270 for instructions on how to reset the printer to its factory settings. If the printer still won't turn off using the power button, unplug the power adapter from the printer. The power adapter is the rectangular black brick behind the printer where the power cord plugs is plugged in. Replug after 30 seconds. That should give enough time for the printer to refresh itself. Thanks.
Nov 11, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 copy and fax
The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used." To resolve this issue, please do the following:
  1. Power the printer off.
  2. Remove all cables from the back of the printer.
  3. Reinsert the power cord.
  4. Switch the printer back on.
  5. Check the operator panel to see if the 1201 error message is displayed.
  6. If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
reference: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&framed=&docid=ENUS22014&relevance=1
Please rate this solution. =)
Jul 14, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270
Power the machine down and restart it may have locked up. If this doesn't work check the fax button maybe stuck down. Failing this poss control board.
Thanks J
Feb 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
