What is the memory part number for Toshiba notebook Satellite M100 series?
    Genius:
  • 3,587 Answers
You can only get that by going to toshiba.com and looking up accessories by model number..should be listed there.
or there will be a configuration option for your model there.
Posted on Apr 21, 2008
When i turn onToshiba Satellite M100-JG2, get black screen,and hear 2 bee sounds,computer won't start.
Two beeps a generally a memory parity error.
Use a test utility like memtest86 to check it. Youll need another computer with a CDRW to create a test disk from an ISO.
Then boot the computer with the cd in and it should run from CD.
Memtest86 Advanced Memory Diagnostic Tool
Jul 02, 2014 | Toshiba Satellite M100 Notebook
Tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 | Computers & Internet
My wifes mother needs an instruction manual for the above toshiba laptop she is 85 years of age part number on laptop PSMAOA-OJ4002 CAN YOU HELP THANKS RON
Does it belonges to Toshiba satellite M100 series? If so, you can seach a manual of Satellite M100 easily by Google.
May 19, 2011 | Computers & Internet
My toshiba satellite M100 keep turn off, why?
I use a Satellite. They are not heat friendly. Use canned air to blow out the vents on the side & back and blow out the fans on the bottom. Get a cooling fan for under the computer. Try to use it on a firm or hard surface since a soft surface won't allow air flow. Blow it out at least every 2 weeks.
Sep 30, 2009 | Toshiba Satellite M100 Notebook
When i start-up my toshiba satellite m100 it ask to insert media
try to remove the media player form the.. system, sturt up..
Go to start, run, type msconfig then enter, then remove sturt up then ok
Jun 07, 2009 | Toshiba Satellite M100 Notebook
Toshiba Satelite M100 PC notebook wont start up windows XP
This sounds like a memory problem. Download and run memtest 86, it is a small iso file that you create a bootable cd from. Run this for at least one pass.
If the memory passes boot from your xp disk and choose R to get into the repair console. Once there type the following commands
fixboot
fixmbr
then try the install again. Hope this helps
Apr 29, 2009 | Toshiba Satellite M100 Notebook
ATI DRIVER FOR TOSHIBA SATELLITE M100
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Apr 21, 2009 | Toshiba Satellite M100 Notebook
Laptop satellite m100 will not start up suddenly
Try the following things and try to bring it up after each action:
1) Remove and reinstall your memory module(s)
2) Remove the CD drive, any PCMCIA cards, flash drives, all but 1 memory module and anything else that you might have connected to te system.
3) Remove the hard drive and try to bring the system up. You should get a message that sez something to the effect that the OS can't be found.
Let me know what happens and we'll go from there.
Thanks, and have a good one!
Ron
Dec 14, 2008 | Toshiba Satellite M100 Notebook
You should upgrade your RAM memory. Check with the owners manual and purchase RAM module. Install the RAM module in the memory slot provided at the bottom of your laptop.
http://www.notebookreview.com/assets/11050.jpg
You should also check the speed of the internet connection you use.
May 13, 2008 | Toshiba Satellite M100 Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
