Question about Epson Stylus C43SX InkJet Printer
Head cleaning does'nt doing
Printer can not being head cleaning (cardridge not move)
  • Anonymous May 10, 2008
    i have the same too..
    why??...
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Hmmm..ok..unplug from computer
turn off for 5 min
replug in power ONLY no computer cable
try a test print from front panel buttons
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
How to change the cartridge
turn off the printer power supply, in some printer wen power is off the cardridge head becomes free and it can be moved.
Mar 29, 2014 | Epson Stylus NX400 InkJet Printer
Printing is grey - too pale
You're running out of black color. Check the black cartridge or replace it.
Sep 29, 2008 | Canon PIXMA MP160 All-In-One InkJet...
I have an Epson color 440 printer that will not print black and white. I have put in a new black and color cartridge but it still won't print black. It will only print the things that are color and leave...
How about if you just print a plain text did you printer print it out a black text ? if yes so there's just some settings on the printer utility that should be check ...
Hope that helps..........
Sep 06, 2008 | Office Equipment & Supplies
Message : 'unable to clean' have replaced cartridges and put old ones back but to no effect.I have not used the machine for a long time
If printer has been sitting for a long time the problem is probably due to a clogged print head. Ink residue can dry in the print head and clog the ports. Replacing the print head can be as expensive as a new printer. Before running out for a new printer do a web search for 'print head cleaning'. There are several sites that provide detailed step by step instructions for cleaning most print heads. To prevent this in the future; print a tet sheet at least once or twice a week or, if your orinter will be idkle for a extended time, remove the cardridges a seal them in an air tight container.
Jun 13, 2011 | Office Equipment & Supplies
Cant find out how to clean the head i have horizontal banding and colours are funny
Hello !
I will give you a number of reason or solutions that I hope will help you .
1. All of your printer heads are bad and its not helping if you clean them because maybe you havent been printing for a while the heads get dry.
2. Somewhere in the printer program installed on your computer there should be a helping program for cleaning. If you find it then the printer should tell you when the cleaning is done but the only problem with that function is that you are losing a lot of ink.
3. This is a solution that could work if the cartridges are dry. Take away the cartridges from the printer and put them on a dishcloth contains lukewarm water. Just for a few seconds untill you can see its clean because you dont want to destroy the electronic parts on the cardridge. If its working you will see the ink drain into the dishcloth or paper. Wait for the cartridges to dry completely and then put them in the printer.
4. If none of this reasons will help you need to buy new cardridges.
Good Luck
Best Regards
Joakim
May 13, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Lexmark X5630 indicates refill black and color cartiridge
Is your ink still comming out of the cartridge? if soo than the person who has refilled it hasn';t done it carefulkly and might have damaged it.
I should suggest you to buy a new one......
Apr 28, 2010 | Lexmark X3650 Printer
Cardridge jammed
Hello hens,
Try reinstalling the CARDRIDGE, by taking them out of teh printer & then reloading them as instructed.
Also clean the printer head.
Mar 24, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Red ink not printing!!!
To clean a print cartridge you should a glaas of water and 15-25 ml of alcohol and mix it in a small wide pan. Dip the head (usually head is mounted to the cartridge itself) in the solution and move horizontally (while the head portion only submerged) keep it there for 5-10 minutes. This should clean your print head. After the head is dry you can mout it to the printer and print. Caution: Do not touch the electronic contacts on spilt water or alcohol in it. This will damage the printer.
Oct 05, 2007 | Brother DCP-110C All-In-One InkJet Printer
Epson Stylus C43SX InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
