Question about Sceptre X24WG-NAGA Monitor
I am trying to connect a Sceptre monitor
I am trying to connect a 24" Sceptre monitor to a computer and it will not turn on. Am I possibly using the wrong cable?
Thanks Cesar
  • 78 Answers
Will the monitor work on another computer? Will the computer work with a different monitor? Are you connecting the vga port to vga output on the video card or the dvi input to the dvi output on the card. You may need a video card with hdmi output.
Posted on Jul 17, 2010
Sceptre x20wg 1080p monitor
In case you know very well electronics, you must open the cover of your monitor and find a fuse burned. You change this. You must repair power supply which supports voltage to work light on your screen. You must be expert to repair this.
Oct 29, 2009 | Computers & Internet
I have a Sceptre X7G Komodo II 17" LCD monitor/built-in speakers
You would need to connect the speakers to your computer. There should be a little jack on the back of the monitor marked audio. This will need to be connected to your soundcard jack for front speakers. Once this cable is connected you should have sound from your speakers. Hope this helps.
Aug 15, 2009 | Sceptre X7G Komodo II 17 in. Flat Panel...
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Apr 07, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
No picture sceptre 7x 17" monitor
Check for a bulged capacitor. They should be flat on top, look for one, possibly two with a "bulge" on the top :)
Nov 08, 2008 | Sceptre 17" LCD Monitor
Sceptre x9g nagaV
you cannot connect your vga monitor to your rca vcr its not compatible unless you have a vga to rca converter
Nov 03, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
No picture
I fixed mine. Had to replace one bulging capacitor in the power supply. Yours may need more or less but it was pretty easy if you do any electronics. The specifics can be found under some of the other problem posts, especially for one of the 19" sceptres.
May 04, 2008 | Sceptre 17" LCD Monitor
Monitor Problem
Use ctrl+alt+ up Arrow key on your keyboard (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Jan 17, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre LCD problem
You didn't say if this monitor used to work on your computer or if it's new to you. Assuming it's new. Check if you get the Bios text etc when the compter is first switched on, if so then the monitor may not be able to support your windows resolution. If you have two monitor sockets on your PC then try the other one. If you are plugging in to a laptop, sometimes you have to enable the external monitor output. Just a few guesses, more info required.
Sep 20, 2007 | Computers & Internet
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Sceptre monitor will not return from idle.
The only workaround was to not use the DVI cable but to use the old VGA cable. You still get the same resolution.
I have a different ATI board, so I'm thinking it's an ATI+Sceptre on DVI input bug. Anyway, use the VGA cable, it'll work.
May 22, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X24WG-NAGA Monitor Logo
234 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
