Question about Kodak EASYSHARE M340 Digital Camera
My camera lens wont go back in once turned off and
My camera lens wont go back in and it wont come on because the lens are stuck some how. How can i fix this?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 17, 2010
Lens wont go back in
The mechanical rectactors are probably worn out. Try turning it on and off again. If that doesn't work, try pushing gently the lens with your palm while shutting it off, maybe the rectractors need a bit of help or are just stuck and may fix themselves after you help them rectact the lens once.
Mar 05, 2014 | Canon PowerShot A580 Digital Camera
Camera stuck with lens out & wont turn on =/
This happens with many cameras, whatever you do, do not force the lens back. You will see this as a suggestion on some blogs. Doing it might further damage the camera lens and other parts.
Here is a repair place that is very reliable: http://www.teleplancamerarepair.com/Olympus_FE_FE-370
WHen sending it in make sure you cushion it so it doesn't get worse when shipping.
Jul 04, 2010 | Olympus FE-370 Digital Camera
The lens is stuck out and wont go back in have
turn cam on and grab hold of lens and try to wiggle it back into alignment.
May 12, 2010 | Kodak Easyshare M893 Digital Camera
Kodak v803 wont turn on
i had the same problem, if you try to turn the lens in as if you turning a dile, the lens will go back in manually once you have the lens completly in again, as if the camera is switched off, then turn the camera back on at the power button and the camera will operate as normal, this worked for me i hope it works for you too.
Jul 28, 2009 | Kodak V803 Digital Camera
Kodak Easy Share Z1275 stuck lens
**** a very common problem with most cameras. There hasn't been much of a solution for this problem except to try to wiggle the lens zoom while pushing and holding the power button.
Also make sure you have brand new batteries installed. Even the slightest dead battery will cause a problem.
Jun 02, 2009 | Kodak EasyShare Z1275 Digital Camera
Optio M40 turns itself off and the lens wont retract into the camera when off
yes me too! one side of my lens hit the ground and is stuck. it wont come out and my camera also automatically turns itself off once i try to start it. i think you shoudl go get your lens fixed...mines stuck and wont go in or come out
Apr 28, 2008 | Pentax Optio M40 Digital Camera
Camera lens stuck out and wont turn on
I purchased my Canon SD 1000 a couple months ago and as soon as I owned it one month I had lens problems. Stuck shut stuck open and now its still stuck open. I take care of my camera and carry it in a case all the time. This is my second rodeo and there wont be a 3rd,
CANON IS DONE GETTING MY MONEY
Jan 20, 2008 | Nikon COOLPIX L2 Digital Camera
It turns on but then turns off
You need new batteries... My camera did the same thing
Dec 15, 2007 | Polaroid I533P Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Kodak EASYSHARE M340 Digital Camera Logo
136 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
