Question about Sharp LC-32SB23U 32 in. LCD TV
No picture "Incompatible video signal has been received?" Sharp LC-32sb23U hooked via hdmi cable to a sony bluray player.
  • 177 Answers
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
Posted on Jul 17, 2010
Won't accept my PS3 video signal
HDMI does not like being connected when units are powered up.
Try unplugging both units--wait and then connect the HDMI and power both units up again.
May 16, 2012 | Sharp LC-45GD7U 45 in. HDTV LCD
Sharp Aquos LC42d64u has blurry picture...
Is it slow and blurry? if yes then return it to warranty immediately. The video processing circuits are malfunctioning and the repair cost is prohibitive if you must pay for it on your own.
I hope it is still under warranty. So, do not delay getting it into the Sharp Authorized facility or back to the retailer you purchased it from.
The connection cable you use could have something to do with it, but is should work on all formats. The best for reliability and absence of blocking is just analog composite - but that is also the lowest picture resolution. S-video is okey too, but it is analog as well. Component is the highest grade; going to hdmi is just another way of receiving the signal - I don't think it will effect the error correction problem in any way. My opinion.
Goodluck..
Feb 25, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tvs on but theres no picture audios good but no picture i set it back to factury setting and lost picture
you have to get into the manu and set the in-let ....If yo use the hdmi o take signal from receiver select the port you use on it ..Just take a look to see in what port is the cable inserted ...and select the port as is labeled..and will work ...It may be a hdmi port or just a regular antenna one or another kind ..
Aug 03, 2011 | Sharp LC-32SB23U 32 in. LCD TV
The receiver is hooked through my Blue Ray Disc Player via HDMI cables. When watching a movie the sound is way to overbearing on the effects end making it almost impossible to hear any speaking voices. ...
I'm not sure if this will help you but if you can hook your Bluray player directly to TV(HDMI) then out from TV to reciever via HDMI or digital optical, it very well may solve your problem.
Apr 28, 2011 | Sony STR-DG820 Receiver
I recently purchased a new Samsung Blue Ray player. My previous Sony DVD player used the blue,green, red cords plugged into DVD imput, and I used Coaxial for sound. The Blue Ray only uses HDMI, which the...
Optical carries only 5.1 sound, no video. HDMI carries both video and sound. If your receiver doesn't have HDMI, check your TV for optical output. You can go BluRay to TV via HDMI, then TV to receiver via optical.
If you don't have optical out on your tv, you're going to need either a receiver with HDMI or a BluRay player with component output (blue, green, red).
Dec 06, 2009 | Sony STR-DG500 Receiver
Sharp Aquos 40lcd will not play bluray
You need to change the resolution on the Blu-ray to 720P to match the Tv native resolution.
Jun 26, 2009 | Televison & Video
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Incompatible signal
Check your resolution settings on you playstation 3 menu's. If you are using an HDMI cable, there is a chance that your ps3 could be trying to output at 1080i or 1080p. The unit you have only goes up to 720p and if you set it any higher than that, you run the risk of having picture issues, or not getting a picture at all. Good luck to you
Mar 28, 2009 | Sharp LC-32SB24U 32 in. LCD TV
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Sharp LC-32SB23U 32 in. LCD TV Logo
551 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
