Question about Exercise & Fitness
Getting elevation error message on Spirit XT275 treadmill.
Completed workout on Spirit XT275 treadmill and pressed END button. Treadmill came to a complete stop and then went to full elevation all by itself. I have tried to press the DOWN button to lower the treadmill, but it does not respond to the elevation buttons. I have tried unplugging the treadmill, but when I turn it back on, I receive a message that says ''ELEVATION ERROR.'' Any ideas on how to reset the treadmill or how to regain control over the incline function?
erpaalai
  • 999 Answers
SOURCE: My Proform treadmill will not incline. It is stuck
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
Posted on Jun 17, 2009
My proform treadmill is stuck on the highest incline (10) and it doesn't budge from there..Help my workouts are killing me!
Posted on Jun 24, 2009
rylee_smith
  • 8619 Answers
SOURCE: Describe your Spirit ® XT275 Folding
Hi
Thanks for using FixYa. Please read this out:
How to Troubleshoot a Treadmill
If still the issue is not resolved then you can contact local repair center.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 05, 2010
  • 43 Answers
SOURCE: My ProForm 530 is stuck in the incline position.
plug her back in, insert key, let her do her thing while u just sit back- I believe shes trying to Calibrate. If so, she will go up all the way,then back down on her own. after she's in down posistion, console will beep/beep and she has reset herself.. let me know what goes on after u do this. David
Posted on Jan 07, 2010
maxtreadmill
  • 832 Answers
SOURCE: Treadmill powers off when pressing Incline Increase "br 1" error
You may have a beltand deck problem. Test by the following procedure:
without the poweron stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill this means that you have high belt/deck friction I first apply silicone lubricant between the belt & deck to see if that clears up the problem. Most problems originate from the belt and deck 75 to 85% of the time
Posted on Jun 13, 2010
I have a spirit treadmill machine model ct800 since last the machine is shown Low Speed error. Please suggest me what to do
When do you get the message? In the middle of a workout or right when you start he machine? Does the belt move at all before you get the message?
Jan 20, 2018 | Spirit Exercise & Fitness
Free spirit club FS200
Could be that the belt has stretched and it needs to be retightened or replaced with new one.
Oct 18, 2015 | Spirit Exercise & Fitness
Jun 13, 2010 | Spirit Fitness Z500 Treadmill
E1 error on display
E1 code means an elevation problem but I am not familiar with the new Spirit models. Been trying to set up with Spirit now that I am getting calls on them again. Its been 5 years since my last call, best thing to do is get in contact with Spirit and they will direct you on what to do or give you phone # to call a service provider. The older units had a calibration sequence for such a problem.
Customer Service and Parts Departments
800-258-4555
May 27, 2010 | Spirit Esprit ET10 Folding Treadmill
I turned on my treadmill after a long hiatus :) and got an error message and a beep. The errors were E4, E9 and a few others. It is a Vision Fitness T9400HRT model. Any idea how to fix?
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
May 04, 2010 | Exercise & Fitness
Describe your Spirit ® XT275 Folding Treadmill Problem - serial number 90488105100032rev-00 I started the treadmill as I normally do by pressing the start button. The belt does not move. I think...
Hi
Thanks
Rylee
Jan 05, 2010 | Spirit ® XT275 Folding Treadmill
Exercise & Fitness Logo
193 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
