Question about Panasonic PT-47WX53 47" Rear Projection HDTV
I cannot get the blue convergence cross to line up with others.
  • Panasonic Master
  • 8,457 Answers
The tv convergence board is dead.Any colors G,B,R don't alignment matches up.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Posted on Jul 17, 2010
My pt-47wx53g The screen bows up in the center . Ive center the screen but still have the same problem
Posted on Aug 08, 2010
premtech
  • 934 Answers
SOURCE: Convergence problem on a Toshiba 57h81
A service manual won't help you on this and yes it's most likely the convergence amps. That unit takes two stk392-110 Sanyo amps. You can substitue with stk392-150's or 180's also... Personally I'd get them from acme sales in florida along with any solder, de-soldering braid, heat sink compound and other supplies you'll need for the job. Acme, because you are assured of getting originals not some chineese knock-offs.
I'd suggest a package of 1.8 ohm/2w resistors, looks like that's what this unit uses in the yoke return circuit and they commonly have failed, and likely the cause for the amp failure. You might also take a meter to any picos in the circuit. F850, 851, 852 and see if any of them are open. If the amp opened you're okay, but if it went to ground it may have opened a fuse.
I will send the manual via Pando - so if you don't already have Pando go there first and download their free program.
Bill
Posted on Jan 17, 2009
Slinteriors
  • 8617 Answers
SOURCE: Panasonic convergence- Blue Cross line not able to adjust
The panasonic rear projection convergence repair kit #2 is available for your model at the following link under convergence repair kits which has the ICs and resistors plus detailed instructions.
http://servicemanuals.vstore.ca/
Posted on Mar 14, 2009
  • 33 Answers
SOURCE: I have a blue shadow that outlines every image.
The problem is in the convergence system which can also cause the tv to not power up or intermittently turn on and off. About 50% of them are bad connections on the convergence power pacs. The convergence power pacs are easily located by the large heat syncs associated with them. The digital control board is located very close to the power pacs. Remove the circuit board housing the heat syncs and using high magnification look for rings around the pins of the convergence power pacs on the foil side of the board. Re-soldering up all the cracked solder joints in the convergence system including the digital control board should solve the problem.
If there are no cracked solder joints in the convergence system, or if repairing the connections does not restore the unit, the power pacs will have to be replaced. Ensure that you apply heat sync compound on the backs of power pacs or they won't last.
After replacing the power pacs, check all of the precision resistors for burn marks or detolerancing and replace as necessary. Next, although rare check the fuse links to the power pacs. This should complete the repair process unless there is some other atypical problem which is beyond the scope of this discussion.
Posted on Apr 28, 2009
SD Tech
  • 14553 Answers
SOURCE: Blue line Ghost Image on Panasonic Projection TV
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This set uses two Stk-392-110 convergence IC chips; both need to be replaced along with any of the 2.2. ohm light blue resistors around them; a bad resistor will be white in the middle; You can buy both for less than 13 dollars plus shipping on Ebay.
The chips are located on metal heat sinks with fins and are side by side. They are black(about 2 inches wide by 1 1/2 tall) and should have the STK-392-110 number printed on them in white.
Depending on your level of skill at this kind of work you may be able to do it yourself---if you need step by step instructions contact me---I have them in Microsoft word---start to finish repair including what you will need to do it.
If you are not able to do the repair yourself now is the slow time of year for TV repair shops----It should be fixable right in your home and the repair takes about an hour--I have done hundreds of these sets--some shops charge 300-400 but I do lots of them for 200-250 total cost. Make sure whoever you get changes BOTH of the chips!
Shop around and if they say "needs to go to shop" keep looking; any good tech can do this right in your home.
I do this here for free so if this helps you give me a vote here. If you need direct help contact me.
etower.766@netzero.net
Posted on Aug 27, 2009
Slinteriors
  • 8617 Answers
SOURCE: Trying to manually fix color convergence on Toshiba 57H81
The convergence ICs and the six 1.8 ohm 1watt resistors need to be replaced. You can get the convergence repair kit for your model at www.tvrepairworld.com which has the Two Convergence ICs and the six resistors plus the CD with instructions on how to do the repair.
Posted on Dec 02, 2009
Testimonial: "Thanks! I'll give it a try!"
I have a Sony KDP-57WS550 TV that has a convergence problem. Based on the symptoms, I'm not sure whether to indict the convergence ICs. In the convergence mode, I can move the red (and blue) crosses,...
With your TV in setup Use a small magnet to "move" the non converged Red, Blue, or, Green color lines "crosses" (each CRT will need to be adjusted in turn) by moving the magnet close to the offending Red, Blue or,Green color CRT yoke or, tube while observing the movement of the CRT color line "cross" in a mirror ( try several places near the tube and, several strengths of magnets:) a refrigerator sheet magnet works well (you can cut these with a scissors to make a better fit or, apply less magnetic "pull." by making them smaller (you may need more than one magnet per tube to fix each CRT's convergence) When you have each CRT tube's convergence right, apply some clear silicone adhesive to the magnet and, permanently affix the magnet to the now "fixed" CRT tube exactly where you placed the magnet to obtain the best convergence on the CRT.
(Do not adjust the "Green" CRT unless you must, as it is used as the color line to adjust other lines to)
Jun 30, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
Convergence Adjust
It means probably one of the two convergence ICs has blown
Jul 13, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Seeing a picture like double vision.Tried to adjust the red & green crosses and the blue. The crosses or plus ( ) signs are supposed to be ontop of each other I assume?. What seems to be the problem.
They have to be on top of each other, converging perfectly. If you are unable to align them - you have convergence issue. Two convergence IC's have to be replaced inside of your TV. I would strongly recommend to let it do by professional technician.
regards.
Russ.
Aug 12, 2010 | Philips Televison & Video
I have panasonic rear projection tv. There is
The PT53WX53 convergence repair kit available at www.tvrepairworld.com should repair that issue. The repair kit contains the parts and the CD with instructions.
Oct 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Convergence Problem
Unfortunately you will have to replace the convergence board in this unit. it has failed. this particular board regulates the alignment procedure that you are having issues with. replacing this board will fix this issue.
May 21, 2009 | Mitsubishi VS-5047 50" Rear Projection...
Mar 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
May 21, 2007 | Toshiba 43H70 43" Rear Projection...
Convergence
you have bad convergence ics
Apr 13, 2007 | Toshiba TP61H60 61" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
358 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
