How do you get the case open on a toshiba Satellite L305-S5944 laptop?
  • norman886 Jul 17, 2010
    Yes . . . it was awesome. The directions were perfect. I saved $120.
    Thanks so much. Highly recommended.
  • 4,737 Answers
Instructions on how to disassemble a laptop, means, more than minimum 20 steps, and if i include pictures, that'll take a long time. If you don't mind, I can give you the link on how to disassemble and reassemble your toshiba. But first of all, be ready with your screwdrivers and other tools.
Open this link... Toshiba Satellite Disassemble tutorial, there are three pages "Page 1" through "Page 3" as Menu and altogether there are 21 steps with pictures. This will be helpful for you.
If you have problem, let me know, I'll be assisting you as you go ahead.
Good luck.
Thanks for using FixYa.
Posted on Jul 17, 2010
  • Lebanon Raingam
    Lebanon Raingam Jul 18, 2010
    You are always welcome. I am always here to help you.
Toshiba Satellite L305
best to check with Toshiba or a computer shop . FIXYA does not sell any products
Jan 02, 2018 | Toshiba Computers & Internet
How to change a fan on a toshiba laptop l305-s5900
Remove the keyboard, base and then motherboard. change the fan.
Take lots of photographs and record which type/length screw went where!
Oct 22, 2012 | Toshiba Satellite L305-S5944 (4400 mAh)
Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Oct 14, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
BIO PASS WORD
Reset BIOS password, it can be done in two ways
Manual
Open the cover under laptop, remove the CMOS battery about 7 seconds, then plug it back. Turn on laptop, BIOS password will be lost. Perform setting date, time, etc.
Online (conditions: the laptop can desktop access)
Toshiba gives services, online flash BIOS. Download and install software ACPI Flash BIOS, according to model of laptop.
Example: Toshiba Satellite L305-SP6983R, software version: ACPI Flash BIOS version 2.20 for Satellite/Satellite Pro L300/L305/L350/L355
Nov 17, 2011 | Toshiba Satellite Laptop L655S5150
Toshiba battery charger pa3468u-1aca for satellite L305-s5944 is beeping and the unit is not charging, what is wrong?
Probably a failed AC adapter. Please try to charge the laptop with a good, working AC adapter & see if the problem disappears.
Jun 12, 2011 | Toshiba LAPTOP AC Adapter Power Charger...
I have removed all screws from the bottom of my L305-S5944 toshiba and I cant get the casing off look like it is attached in the center but the is no screw to remove.HELP.
Hi
Take care, not all the screws are same, remove them all again
and try to categorize the screws before fixing them
Please tell us your results
Good Luck
May 13, 2011 | Computers & Internet
How can I replace the screen bezel clips on my toshiba satellite L305D-S5974 laptop?
The cheap way is do not replace them Get some clear silicone and sparingly put silicone in their place.
The right way is to replace the bezel which comes with the clips. I found one here for $32.95 plus shipping.
http://www.laptoprepairparts.com/html/LRsearchmodelresults.asp?brand=toshiba&model=L305-&txt=Satellite L305 Series#case
Hope this helps
Apr 04, 2010 | Toshiba Satellite L305D-S5874 Laptop
How to do a system recovery in toshiba L305-S5944
First backup all data or software that you don't want to lose!! This is important because you will lose anything that is on your computer...if you are doing a clean recovery to factory settings. Then insert the recovery disc that came with your computer and restart. It should automatically start and many take a little while to finish. If you are referring to a system restore, this can be located at Start>all programs> accessories>system tools> system restore. Using the latter of the two, you still want to back up any software you installed before the date of restore.
Nov 08, 2009 | Computers & Internet
Need of network drivers
go to www.driverguide.com
you should be able to get your drivers from there and its free to join.
Apr 30, 2009 | Computers & Internet
Open Questions:
Toshiba Laptop running slow and becomes unresponsive while surfing the web Is your laptop freezing too frequently and crashing down in the middle of something important? Are you having issues with your processor like it being slower than before and operating less efficiently? Have you noticed your laptop battery having issues staying charged for long? All these could be the results of effects of overheating of your Toshiba laptop on various parts of the system like processor, battery etc. Call Toshiba and forget about all tech related worries that you face due to issues in your Toshiba laptop. For preventing laptops from getting overheated and causing adverse effects on the internals of Toshiba laptop, it is advised to place the laptop on a flat hard surface while using instead of any soft surface like pillow, bed or your lap, as softer surfaces could block the air flow at the bottom of laptop. For making sure overheating doesn't affect the internal components of the laptop severely or because a serious danger to your safety, you can use few below given steps to prevent overheating from damaging the laptop. Call Toshiba support for assistance over the phone, email or chat or even at your door steps through toll-free helpline number +1888784-9316. Laptop overheating could be due to any one or more of these mentioned reasons like non-working of the fan which is meant for providing air to the inside parts of the laptop and keep it cool or the fan moving slower than is required for keeping the internal components cool. Another possible reason could be restriction to air by an accumulated layer of dust over the air vent. Therefore it is always advised to keep the fan clean for easier passage of air to the inside of laptop. For tech support regarding overheating issues in Toshiba laptops or other software and hardware issues you can call toshiba customer support for Toshiba laptops and we assure you of technical assistance anywhere at any time. For getting detailed knowledge and prevention tips call Toshiba support US. Overheating could also be cause by some undetected malware present in your system. As presence of malicious particles in the system can put unnecessary pressure on the internal components making them work more cause them to overheat which could result in overheating of the whole laptop when air fanned in would not be able to cool down the laptop. In this situation you can call our Toshiba support expert and acknowledge your problems.
Oct 19, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
64 people viewed this question
Alun Cox
David Payne
David Payne
