Question about Nintendo Wii Console
My wii just stopped working, no power. Is it the
My wii just stopped working, no power. Is it the motherboard, I checked connections and all?
  • 218 Answers
If you checked the connections, then the problem most likely has occurred on the motherboard. I recommend taking it to Geek Squad and having them look at it. Unfortunately the only other thing that you would be able to do other than get it looked at is purchase a new one.
Posted on Jul 17, 2010
Can't connect to server. Error code 52230 comes up.
Here are some troubleshooting ideas:
Error Code: 52230
Unable to connect to your wireless network
Likely cause: Your router or Internet Service Provider is having difficulty assigning a DNS or IP address to the Wii.
How to fix: Manually assign an IP address and DNS to the Wii.
The address below will show you how to manually assign an IP
http://en-americas-support.nintendo.com/app/answers/detail/a_id/3068
Other suggestions:
  • Did this connection used to work but has suddently stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the router back in. Wait a couple of minutes for it to initialize, and try to connect the Wii console online and test for proper response.
  • Check for wireless interference, which can affect the signal strength to the Wii console.
  • What to Do:
    • Check the location and distance of your wireless router.
      The further a device is from your wireless router, the weaker it's signal strength will be. If your wireless signal has to pass through any walls or floors, this will also weaken the wireless signal strength. Move the router to a central location within your home and as close to your system as possible.
      Additionally, if your router is on the floor, moving it to a higher location can improve the signal strength.
    • Change the wireless channel your router is broadcasting on.
      Wireless routers can broadcast on a variety of channels. Sometimes a specific wireless channel may experience interference from other devices and routers nearby. How to
    • Move any metal objects or electronic devices away from your Nintendo system and wireless router.
      Metal objects and electronic devices may interfere with wireless signals. If you have any of these, such as filing cabinets, speakers, power strips, glass, or cordless phones, next to your system or wireless router, move them away.
Nintendo Customer Service Nintendo Wi Fi Connection Error Code Results
Sep 30, 2015 | Nintendo Wii Console
I'm getting an Error code 51030 when I'm trying to make a wifi connection on my wii console
Error Code: 51030
Likely cause: Your wireless router may need to be power cycled, or the connection settings have changed.
How to fix: Power cycle your router; redo the connection settings on the Wii and try again.
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
  • Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected.
Jun 05, 2011 | Nintendo Wii Console
Error 51030 shows. has worked fine until today
  • Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected. We suggest following our guide to create a new connection file and start over.
May 29, 2011 | Nintendo Wii Console
What does code 51030 mean??
This is a connection error on a Wii. The Wii is trying to connect to your wireless router and failing.
firstly, power cycle the router (turn off, leave for 30 seconds, turn on) then try the Wii.
If that does not work then delete the Wii connection settings and re-connect to your router.
May 01, 2011 | Nintendo Wii Console
Code it asks for is 51030 how do i get this code in my will my netfilx had been working then not
Wii error code 51030:
Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii online and test for proper response.
Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected. We suggest following our guide to create a new connection file and start over. If at the end you still need help, you'll find contact information to reach our specially-trained representatives.
Step by step instructions to connect your wii to the internet can be found here
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
Good Luck,
Rodrick
Apr 22, 2011 | Nintendo Wii Console
My wii will not work the wires are plugged in but the light is not on it was working fine yesterday but it wont work now please help
Try your wii power supply in your friends' house. If your power supply didn't work on your friends wii, Buy new power supply. If it worked on your friend's wii then your wii is dead. Call Nintendo to take care of it. If you dont have a warranty, do it yourself. Take out the motherboard and google Wii FUSE. Chage the fuse. If you don't have the fuse, use soldering iron and join the palce you place the fuse together. If that didn't work again, Replace the wii motherboard. Trust me your wii will work this time and your MII you created will still be there because they are all on your harddrive not wii motherboard.
Rate if this helped you.
Apr 12, 2011 | Nintendo Wii Console
We have recently moved home and our nintendo wii remotes have stopped working. i have checked all the connections and have put new batteries in them
Make sure the Wii is plugged in correctly and the light on the power button is on.
open the small panel in the front of the Wii and open the battery panel at the bottom of the Wii remote
and press the red buttons together
If you had been suffering from batteries lasting a little while then Nintendo will replace the controller for free
Jul 08, 2008 | Nintendo Wii Console
Wii remotes stopped working
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
May 21, 2008 | Nintendo Wii Console
HELP PLEASE!!!!!!!
I've had this same problem. Remove the batteries from the remotes. Then disconnct the power cord from the back of the Wii and disconnect the power cord from the wall. Let it sit for 5 min. Double check that the sensor bar is plugged into the Wii and check the cord for any breaks that might stop the signal. After you are sure that the sensor bar is connected and the 5 min. have gone by plug it all back in, install your batteries and re-sync it.
Mar 28, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
973 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
