Question about Philips Audio Players & Recorders
Philips HTS3555 will not power on
Philips HTS3555: Can anyone identify the component (diode?) that is located at position ZD908 on the power board? It's located near the center left section of the board. Mine's burnt and broken and I want to try to replace it.
Did you find the part or where to get it? I'm in the same boat and want to know what you may have found...
crys2b21@Hotmail.com
Posted on Aug 18, 2010
  • rolfcj Aug 22, 2010
    Crys2b21... No... I bought a diode at Radio Shack and soldered it on but it didn't fix my problem. I ended up buying another surround sound system. Sorry.
NEED TO IDENTIFY A PART
Most diodes have numbers and letters on them. If not visible, they might be on the bottom side where they cannot be seen without removing the component. There is a chance Toshiba used some sort of proprietary number on it. In that case, you'd have to guess at its function based on its location in the circuit. Electronic circuitry knowledge would be needed for that. Amazon currently sells the entire circuit board. So that's another option.
Apr 02, 2016 | Toshiba 55G310U LCD TV
Tip
Philips HTS3555 Manual Download
Download Philips HTS3555 Manual
Have you misplaced your Philips HTS3555 Owners Manual?
Would you like a digital, searchable, pdf version of the Philips HTS3555 Users Guide?
Follow this link
(& click FREE) to download a pdf version of the Philips HTS3555 instructions.
I hope that helps.
_______________________________________________
on May 13, 2010 | Audio Players & Recorders
Tip
Follow this link (& click FREE) to download a pdf version of the Philips HTS3555 instructions.
I hope that helps.
on May 13, 2010 | Philips HTS-3555 System
I need a power supply board # 080GL19X01LT
Have a look here. Hover your mouse over the area of the PCB to zoom in on the component you're trying to identify. I saw the C604 labeled as:
"B. 102K 1KV" I couldn't see the other part you're look for though.
Check out this replacement PCB for $88. It isn't available for shipping until March though.
Feb 05, 2013 | Vizio E420VT 42 Class Razor LED HDTV
Fuse keeps blowing in my philips 32pfl3505d/f7 tv
Good day!!!!
That problem is cause of shorted bridge diode or power mosfet..
just see the picture below to see the image of bridge diode and power mosfet..
If you don't have a tools or you have no electronic background you only have to is order the new power supply board..
I hope this solution will be helpful..Thanks for using fixya....
Sep 04, 2011 | Philips 32PFL3505D 32 in LCD TV
Need info on component 3071 on power supply board - burned up.
Its been a while since i worked on that power board. But I believe you are refering to the orange diode that runs into the single connector for the video board next to the power supply. I replaced mine with a 1n914 diode after replacing the 2200uf lytic cap and the tv fired right up.
Jul 23, 2009 | Philips Televison & Video
Philips HTS3555 custom settings reset to factory on its own
this happens when the electricity is fully discharged
May 17, 2009 | Philips HTS-3555 System
Philips DVDR 3506/37 - when in stand by mode -
I had the same problem, it is a Diode on the Power Supply Board. The Location number is D1054, you should change C1051 also. It maybe leaky. I used a 10v 1000uf capacitor instead of the 6.3v 1000uf it had. Make sure to be careful when changing these components, making sure the polarity is right. Good Luck!
Jan 22, 2009 | Philips DVR-1
Philips hts3555 dvd player has no power
I just fixed an HTS3555/37 with a no power problem. As one person mentioned, you can hear a ticking sound.
The problem is a diode/rectifier on the power supply board. There was no identifiable number on the board for the part, but it's located just above the "T" in the word "TYPE" in the silk screen notice on the board stating "...REPLACE WITH SAME TYPE FUSE". The original part is an HER104, but I suggest replacing it with a larger diode having 400PIV and 2A rating. I used a 30D4, but any equivalent diode could be used. Proper polarity for the diode is silk screened on the board.
To fix this successfully you should to have some soldering and general electronics repair know-how. Caution: There is in excess of 300V on the power supply board even in its non-working state.
Nov 14, 2008 | Televison & Video
785 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
