I can not get my printer to print out pages I tried reinstalling my cd but it has a few scratches how can I get the printer up and running again?
    Genius:
  • 2,785 Answers
Plz visit the manufacture website and download it from it
Posted on Apr 21, 2008
I moved my HP 4000 printer from one office to another. When I hooked It back up, it printed out a few pages of symbols and then will not print at all. The ready light is on, but it will not print. Any
If you get a bunch of meaningless symbols on the page the usual causes are a corrupt or wrong print driver, a bad communication cable or a failed formatter or possibly a print job stuck in a queue on the computer that you connected the printer to (pending jobs often corrupt when you reconnect your printer). Unplug the parallel or network cable from the printer and restart and then try to print the configuration page. If it prints then plug in the communication cable and try printing again. Still bad after that reinstall the printer driver. If a fresh driver does not work, try a different cable.
Sep 17, 2014 | HP LaserJet 4000 Printer
Printer only prints blank pages
I would suspect that the you didn't get the drum back in properly. There are contacts on the drum casing that need to make contact with the base of the printer. It's possible that either it's not seated properly or that some toner is lodged over the contact preventing a good electrical connection. Try removing the drum again and carefully reinsert.
Jun 16, 2017 | United Stationers Oki B2200 Laser Printer...
Got to work this morning and the thermal printer had continuously printed the previous days manifest until it had run out of labels. I inserted new labels and it started to print the manifest again. I...
Uninstall the printer and restart the computer once installed reinstall the printer from the CD that came with the printer or get the latest software / pilots from the printer's web page
Jul 21, 2011 | Datamax E-CLASS DMX-E-4203 Label Printer
When i send to print not print inmediaty. i have to turn off the computer when i turn on again print only some pages not all. when turn on again the computer print again few pages not all. and so
have you installed any new software or hardware recently? It could be causing conflict with the printer.
If you use windows, try the "fixing a printing problem" troubleshooter. Click "Start" , select "Help and support" then "printers and faxes". Deleting and reinstalling the printer drivers could help too if above doesn't.
hope this helps
LC
www.inkbank.com.au
Nov 12, 2010 | Lexmark X2670 All-In-One Printer
My hp laserjet 1200 series keeps running test pages, how do I reset it?
Follow these steps:
Reset your printer if you are having communication problems with the computer. To do so, press the "Power" button to turn off the printer. Wait a few seconds and then power it back on.
Power off the printer again if you are still running into problems and disconnect the power cable from the AC power. Wait a few seconds and reconnect the power cable. Power on the printer. This simple procedure resets the printer back to the default factory settings. Move to the next step if the reset does not work.
Disconnect the USB cable from the printer. Insert the printer software installation CD into the CD-ROM drive on your computer and wait for it to automatically launch. Click the Windows "Start" button if it does not launch and click "My Computer. Right-click the CD-ROM drive with the disk and click "Autoplay to run the CD.
Select "Setup" on the CD and select "Remove HP printer. The printer software and drivers are removed from your computer.
5
Reconnect the USB cable to the printer. The installation disc automatically recognizes it and begins reinstalling the software and drivers.
6
Print a test sheet to verify that the printer is now working. You can print a test sheet using a word processing application (e.g. Microsoft Word) or using the Internet.
Oct 26, 2010 | Office Equipment & Supplies
Printer has ink, but will not print.
First I would start from scratch.... Remove printer in control panel by deleting then run the add new printer set up wizard and follow the easy install steps...If still not printing you need to run the maintenance program on printer.. Remove the ink cartridges and reinstall making sure they are fully seated in the carriage..Then clean print nozzles,align page and then try to print a test page....if it still doesnt print make sure printer is communicating with computer..if it isnt then check that you are connected to the correct port ...Good Luck!!!!
Jun 25, 2010 | Lexmark Z53 Color InkJet Printer
Can't print entire pdf documents only first page.
There may be a few possible things for your to try. Below is the list of things you can try.
1) Reinstall the PDF software that you use to open your pdf documents. (reader or acrobat) *restart machine after reinstall.
2) Remove the printer from your list of printers and faxes then add it back again
3) Restart the spooler service
click start -> run
type services.msc then ok
on new window, look for print spooler, right click and select restart service.
May 29, 2009 | Kyocera Mita FS-C5016N Printer
Printer help
need to start from scratch , try this , update your computer , using WINDOWS then download SP2 or SP3 , THEN TRY again to install your printer CD. LET ME KNOW . thanks AJ
May 03, 2009 | HP DeskJet 610c InkJet Printer
I have hp 1500 series printer suddenly doesn't print
Hi Adele,
The only way to reset your printer is to unplug the power cable, wait a few seconds, and plug it in again.
Also if you still have the driver/software cd that came with your printer, uninstall your printer driver which you will find by clicking on the start menu, then printers and faxes. Reinstall the driver and software from your cd and try using the printer again. If you no longer have the cd, you can find the software on HP's website: http://www.hp.com/
If this does not resolve the problem, try putting a new cartridge in (as you will need a new one soon anyway). If this doesnt work, then I'm afraid you will have to send your printer in for servicing. Remember that it may cost you less to purchase a new printer than having your old one repaired.
Good luck.
Regards,
Graemevm
Apr 22, 2009 | HP LaserJet 1500L Printer
KODAK 5300 BLACK WON'T PRINT
Try removing the printer and reinstall it again
Sep 24, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
jasbo
jasbo
