Question about Phonic - XP 5000 - 5000 Watt Power Amplifier Amplifier
What power in RMS have in 4 ohm y 2 ohms? - Phonic - XP 5000 - 5000 Watt Power Amplifier Amplifier
  • 17,130 Answers
Your question is not very clear, The Root Mean Squarre power is the determined power available from the amplifier's outtput according to the design. The output delivery for 2 ohms will be double that of the 4 ohms. hence the rated speakers sufficient for the load must be given to prevent damage to the speaker orr the amplifier. Hope this helps you to guide . Good day
Posted on Jul 18, 2010
How many watts is my jl audio 2150 amplifier
It depends on whether you have the M2150, A2150, or E2150.
M2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
Rated Power 14.4 V Stereo: 70 W RMS x 2 @ 4 ohm, 110 W RMS x 2 @ 2 ohm
Rated Power 14.4 V Bridged: 140 W RMS x 1 @ 8 ohm, 220 W RMS x 1 @ 4 ohm
Rated Power 12.5 V Stereo: 45W RMS x 2 @ 4 ohm, 75W RMS x 2 @ 2 ohm
Rated Power 12.5 V Bridged: 90W RMS x 1 @ 8 ohm, 150W RMS x 1 @ 4 ohm
THD at Rated Power: 12.5V: <0.08% THD, 20Hz-20kHz, 14.4V: <1% THD, 20Hz-20kHz
S/N Ratio: >104 dB referred to rated power (A-weighted, 20Hz-20kHz noise bandwidth)
Frequency Response: 10 Hz-25 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz, >100 @ 2 ohm per ch. / 50 Hz
Input Range: 200mV, 8V RMS
E2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
THD at Rated Power: <0.08% @ 4 ohm 20Hz-20kHz
Frequency Response: 10Hz-25kHz (+0, -1dB)
A2150 Class A/B Two-Channel Amplifier Specifications:
Rated Power 12.5 V Bridged: 150W RMS x 1 @ 4 ohm
THD at Rated Power: <1% @ 4 ohm 20Hz-20kHz
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 23, 2011 | Car Audio & Video
I dont know how many watts it is
4 Ohm Stereo Power (RMS): 250W X 2
4 Ohm Mono Power (RMS): 850W X 1
2 Ohm Stereo Power (RMS): 450W X 2
Signal-to-noise ratio: 100 dB
Frequency Response: 5 Hz - 50 KHz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 200mV-4V
Length: 16.93"
Width: 11.66"
Height: 2.37"
Continuously variable 0 - 18dB Bass Boost
Built-in continuously variable 18dB per octave crossover, from 50Hz to 250Hz
Dec 23, 2010 | Concept CC-2502 Car Audio Amplifier
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    Whats the specs
    • Bridged Max Power: 520 Watts
    • RMS Mono: 170
    • Variable Low Pass 40Hz-120Hz
    • Variable Hi Pass 150Hz-1.5Khz
    • THD: 0.02%
    • Die-Cast Aluminum Heat Sinks
    Sep 20, 2010 | Power Acoustik XL2-520 SPL Car Audio...
    I need to know what the wattage the alpine mrv-f407 puts out when its bridged or only running 2 channels?
    RMS Continuous Power (at 12.0V)
    Per channel into 4 ohms...............40W, 0.08% THD
    Per channel into 2 ohms ..............50W, 0.3% THD
    Bridged into 4 ohms.....................100W, 0.3% THD
    RMS Continuous Power (at 14.4V)
    Per channel into 4 ohms...............60W, 0.08% THD
    Per channel into 2 ohms...............80W, 0.3% THD
    Bridged into 4 ohms.....................160W, 0.3% THD
    Max. Power (at 14.4V)
    Per channel into 4 Ohms..............120W
    Bridged into 4 Ohms....................320W
    This should help.
    Apr 30, 2010 | Alpine MRV-F407 Car Audio Amplifier
    Whats is the rms at 2 ohms and rms at 4 ohms of m1900xe MA Audio
    what is the amplifier model number and how many channels does it have... if you can just read off the numbers on the top of the amp...
    Dec 12, 2009 | MA Audio M1900XE Car Amp
    I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
    Hi mate very nice amp you got there here is the specs for it
    Model: MA Audio HK401SX
    Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
    1 x 1800W RMS @ 0.5 Ohm Mono
    1 x 1200W RMS @ 1 Ohm Mono
    1 x 650W RMS @ 2 Ohm Mono
    1 x 500W RMS @ 4 Ohm Mono
    Fully Unregulated MOSFET Power Supply
    2 Ohm Stable @ Mono
    1 Ohm Stable @ Mono
    0.5 Ohm Stable @ Mono
    if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
    Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
    Mtx audio 4252 amplifier
    Hello freshman_fox,
    63 watts X 2 @ 4-ohms.
    125 watts X 2 @ 2-ohms
    250 watts X 1 @ 4-ohms bridged
    Since no power rating is given @ 2-ohms in bridged mode, it means that the amp is only stable to 4-ohms.
    The manual does not specify a peak power, but since RMS is about 70.7 of peak, that makes it 353.5 watts.
    You can download the manual from here. Hope this helps.
    Jul 10, 2009 | Car Audio & Video
    I don't know how many watts is this amp
    ECLIPSE makes a 32440
    If this is the amplifier you are looking for specs on...
    4 x 85W @ 4 ohms (13.8V - 0.1% THD)
    4 x 120W @ 2 ohms (13.8V - 0.1% THD)
    2 x 240W @ 4 ohms bridge (13.8V)
    Thanks for using FixYa -a FixYa rating is appreciated for taking the time to answer your Question.
    Mar 28, 2009 | MTX Thunder 1501D Car Audio Amplifier
    Do you have instructions for wiring install on volfenhag GX8200??
    Amplifier Class AB
    Number of Channels 2
    RMS Power (4 ohms) 120 watts x 2 channels
    RMS Power (2 ohms) 200 watts x 2 channels
    RMS Power (1 ohm) Not Stable
    Bridged RMS Power 400 watts x 1 channel
    Total RMS Power Output 400 watts
    Peak Power Output 1000 watts watts x 1 channel
    Minimum Impedance Unbridged 2 ohms
    Minimum Impedance Bridged 4 ohms
    THD at Rated RMS Power 0.1%
    Speaker Level Inputs No
    Preamp Outputs 1 pair
    Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
    High-Pass Crossover Frequency 40 - 250 Hz
    Low-Pass Crossover Frequency 40 - 250 Hz
    Subsonic Filter N/A
    Signal-to-Noise Ratio N/A
    Channel Separation N/A
    Bass Boost 0 - 18 dB
    Bass/Gain Remote Yes
    Fan Cooled Yes
    Fuse Rating 20A x 2
    Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
    Phonic - XP 5000 - 5000 Watt Power Amplifier Amplifier Logo
    75 people viewed this question
    Top Phonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Gil Shultz
    ray gallant
    Are you a Phonic Audio Player and Recorder Expert? Answer questions, earn points and help others
