Question about Nokia Cell Phones
6300i dual insert sim card - Nokia Cell Phones
  • 316 Answers
SOURCE: INSERT SIM problem
try cleaning the sim with a soft eraser first and then make sure you are putting the sim in the correct way?
the copper plate on the sim must be touching the contacts in the phone.
If this doesn't work then I'm affraid your sim reader in the phone is not working and needs repair by a technician
Posted on Feb 09, 2008
  • 242 Answers
SOURCE: Insert SIM Card
make sure the sim card can make good contact with the phone.
Also check if it doesn't have space to slide, causing it to loose contact with the phone.
Posted on Mar 27, 2008
Put two layers of paper between SIM card and SIM holder to make it a tight hold.It solves your problem.
Posted on Jan 07, 2009
bdouglas
  • 290 Answers
SOURCE: x sim card insertion with indian sim card insertion in i-phone
Some SIM cards because of their design have to be trimmed slightly in order to work with the turbo SIM. You can find a video on how to do this on youtube
Posted on Jan 09, 2009
bdouglas
  • 290 Answers
SOURCE: sim card
Sounds like phone is locked or firmware is bad
Posted on Mar 16, 2009
How & where to insert Sim cards
Hi
I haven't had much luck with finding a manual for this machine to tell you precisely where a SIM card would go, but on the specifications toward the bottom of this page:
iRulu 7 WCDMA 3G Black Tablet PC Dual Core Cam 4GB Android 4 2 Bluetooth...
it quite clearly shows it as a dual SIM machine. This may mean that you have the SIM in the wrong slot, or yoou may need 2 to make it operate. Not having found a manual I' m afraid I can't be more specific.
Cheers
Jan 01, 2015 | Irulu 7 inch Android Tablet PC, 4.2 Jelly...
SIM Card
If the Dual SIM accepts GSM networks, insert your T-mobile SIM and use it. If the mobile is locked to a GSM network it wont accept other SIM cards. You have to unlock it to use. You can unlock it using codes very easily. Visit ClassicUnlocking.com to order your unlock codes.
Jun 27, 2012 | Cell Phones
How to insert the dual sim cards
If your phone Supports Dual Sim then First locate where your Sim are inserted...may be under battery or near battery...now insert both Sim and switch on the phone..Now Go to setting and then phone setting now..here you can choose weather you want to activate one Sim or both at a time..you are free to choose what you want....
Oct 19, 2010 | Dual Cell Phones
I INSERT MY SIM CARD AND IT STARTS OUT OK, IT SHOWS AT&T AND THEN IT LETS ME MAKE ONE PHONE CALL IF THAT AND THEN IT SAYS INSERT SIM OR UNABLE TO CONNECT, WHEN IT WAS CONNECTED JUST A FEW SECONDS...
cell go to call center / call settings and switch end call to off....
this should do the trick...if this phone is a dual sim make sure the setting is on 1 and the sim is in sim card holder #1
May 19, 2010 | Dual Electronics CECT P168 Cellular Phone
A dual sim cell phone malfunction
HAve you ever experienced both working, most dual sim phone its one sim working at a time, you need to switch between the sims, via a switch on the side or via the menu,
I need the name and model for the phone
your vote counts for me
Mar 27, 2010 | Dual Electronics N99i Cellular Phone
Where do I insert the dual sims into the iphone?
slip the back cover off the cell, take the battery out...you have three slots...2 for sim cards and 1 for external storage (microsd)
Jan 18, 2010 | Dual Electronics CECT P168 Cellular Phone
Ive inserted a vodafone sim card in sciphone, phone sayn insert sim. also why is there 2 sim card slots?
This is called Dual sim phone. Go to settings and make sure that the Dual Sim is enable. Whe a phone state "Insert Sim" after inserting the sim card, it is most probably that you had inserted the sim the wrong way, so that the gold connectors is not connecting with the phone. Invert the sim card and try. If the problem persist, try the other sim slot.
Dec 16, 2009 | Lands Phones
Emergency calls only and not showing service provider
sounds like either your sim card isnt inserted correctly, or the slots arent turned on. sim card slot 2 is the slot closest to the phone, gold chip faces up, sim card slot one is slightly elevetaed off the phone, gold chip faces down. make sure it is inserted all the way down. perss fimly. then go to SETTINGS>DUAL SIM SETTINGS>DUAL SIM OPEN>CLICK OK. This opens up both sim card slots. after you find out which slot you are going to use, you can repeat these steps and only have opened the one you are using.
Jun 02, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Cect P168 not dectecting My sim Card
The "insert sim" error is a common error. Usually it is caused from putting the sim in incorrectly.
Try this. If this is the one with the sim card ports that are on top of eachother than put the sim card in the port closest to the phone with the gold side pointing up.
Insert battery, turn on phone.
On the phone, go to the main menu. Tap phone settings. Tap dual sim settings. Tap to open sim 2. Go back to the main screen.
If that does not resolve go back to phone settings, tap dual sim settings, tap to open sim 1, go back to the main screen.
If this is the type of phone with the sim card ports seperate, insert sim with gold side down in either port. Go to phone settings, tap dual sim settings, tap open dual sims. Go back to main screen.
If this problem persists than either the phone or the sim is defective. Test the sim by putting it in a phone that belongs to the carrier the sim came from. If it works in that phone it is not the sim.
Sep 09, 2008 | Dual Electronics CECT P168 Cellular Phone
Cell Phones Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
