Question about LG GSA-H42N 18x DVD RW DL IDE Drive (Black) Burner
My Pentium 3 does not detect dual dvd drives on secondary eide wire. All jumpers are correctly placed. Why is that?
  • 78 Answers
Check the bios to see if multiple drives are supported. Try swapping the drives on the cable.
Posted on Jul 17, 2010
Want to install wd1200jb-75cra0 as slave drive in dell xps420 with vista operating system operating master drive. do i need a driver installed first before it will recognize the wd1200 as a slave?.
there is a jumper setting on the drive itself that determines master and slave. Look closely at it, there is always a diagram of the pins to connect or disconnect for master slave setup.
No longer needed with Sata drives...
Feb 18, 2011 | Western Digital Cavier SE WD1200JB 120 GB...
Ive built my first pc and all went well until the message no hard drive detected comes on all parts are new so any help would be great in fixing this thanks dave
Verify that the hard disk is connected on both data and power cables and is receiving power (it hums at startup); also that the proper EIDE or SATA slot on the motherboard is used, and properly jumpered (e.g. a SATA 2 disk on a SATA 1 configured port is likely to malfunction).
Check that the BIOS is configured to autodetect the hard disk type, and is using the appropriate adapter (EIDE or SATA port), without RAID options or such.
In a pinch, try also ignoring the motherboard labels (e.g., plug the hard disk on the fourth SATA port instead of the first -- the mobo numbering is not always the "logical" one, even if it usually should be.
Jul 02, 2010 | Computers & Internet
My Gigabyte GA-945GZM-S2 motherboard is not detecting any CD/DVDROM attached to the ide port. it is also not detecting the rom in bios. cable and rom ate both working fine there have been tested on other...
IF THERE IS ANOTHER IDE PORT FOR A SECONDARY DRIVE i WOULD TRY TO SWITCH OVER TO IT . IF NOT THE MOBO MAY HAVE A PROBLEM WITH THE IDE PORT. VEIRFIED THAT THE DRIVES ARE CORRECT AND TRY TO CHANGE THE BOOT ORDER IN BIOS .
May 15, 2010 | Gigabyte GA-945GZM-S2 Motherboard
HP Pavilion 7955 main HD failed; my data is on second drive (Maxtor ATA/EIDE) - still good. I want to install this as a second drive in Dell Optiplex 620 which has SATA main drive. The only IDE cables are...
Most IDE cables have THREE connectors:
* one to the motherboard
* one to the "primary" device (CD/DVD or disk-drive)
* one to the "secondary" device (disk-drive or CD/DVD)
If your IDE cable only has TWO connectors, buy a cable with THREE connectors, and connect your disk-drive to the third connector.
Mar 03, 2010 | Dell Optiplex GX260 Refurbished Intel...
After installing cd-rom i turned computer on and it says i need to change the stand alone slave drive master
I think that the problem here may be that the Jumper on the CD-ROM needs adjusting. The Jumper is a tiny piece of plastic at the rear of the hardware in question.
There will be a diagram on the top, or rear of the CD-ROM, with a choice of 3 settings. If it is a solitary Optical drive then place the Jumper in the 'C' position.
If it is a Slave, or secondary drive, then place the Jumper in the 'S' position & if it is a Primary or Master drive the it is to be placed in the 'M' position, respectively.
I hope that this sees an end to your dillema & lots of luck.
Kindest regards,
Ste
Jan 31, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
I'm trying to install a DVD burner into my Dell GX520 (mini tower) and can't work it out ... can anyone help?
If you install the DVD drive on the same IDE cable as the hard drive using the second connector, then the jumper on the DVD burner has to be set to SLAVE.
If you elect to install the DVD burner on the cable which is connected to the second IDE controller (this is the preferred way), then the jumper setting can be set to either MASTER or SLAVE provided there are no other devices on this cable.
When the computer boots up go into the BIOS configuration to see if the BIOS detects the DVD burner, if not then the jumper settings on the DVD burner is not correct.
Oct 09, 2009 | Dell Optiplex GX520 Desktop PC - Intel...
Hi all i have a asusp4p800 motherboard that was on and working till i shut it off to add more mem,and new video card,now when it boots up it wil stop at the asus bios screen unless i unplug the hard drive...
hallo friend
you should remove hdd ID cabals and after that hard disk jumper chak first jumper Hdd master and sacud jumper cd-rom jumper slave
so please chake hear
Aug 15, 2009 | ASUS Computers & Internet
Dvd dont show in my computer
check your IDE or sata connected properly inside your CPU...
Jun 18, 2009 | Acer Benq 16x DVD and 40x CD-ROM Internal...
2 primary ides 2 secondary ides
Ok.... The Primary IDE Should be configured so that your Primary Hard Drive is Set To Master (the jumper pins must be set to the same, each drive has a guide on top or back, or it's written above or below the jumper pins on the back of the drive.
Primary = Hard Disk 0 (Your Main Hard Drive)...This one is to be set as Master and plugged to the END of the IDE Cable....Another Hard Disk / Drive can be connected as Slave (sometimes Cable Select Will Work depending on the motherboard). Remember The Jumper pins on the Drives!
Secondary= One drive must be set as Master, The other as Slave.
That Should do it.
Go into your bios setup screen, go to the boot configuration and set it up so that your boot order goes as follows:
1. Floppy Disc Drive
or........
1. Optical Drive (cd or dvd)
2. Hard Disc 0 (this will be named whatever your Hard drive model number is)
3. Hard Disc 1 (this is the second hard drive, if you want it to be bootable, it's your choice, if not, then set it up to boot off your secondary optical drive,
Make Sure that under IDE devices menu, everything is detected correctly.
Now Save Settings and Exit.
That should do it
Apr 21, 2009 | Computers & Internet
1st and 2d eide conector on mobo
Hi, Does not really matter whether slave via jumper or cable select on the secondary IDE. Your mb will boot to whatever HD you set it at in the BIOS/CMOS as the first boot device. The 3rd drive will be recognized as secondary whatever and if your CMOS/BIOS is set right it will boot from the primary master on IDE1. Good luck and kind regards.
Oct 09, 2007 | Computers & Internet
LG GSA-H42N 18x DVD RW DL IDE Drive (Black) Burner Logo
35 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
