Question about RCA Televison & Video
I need picture tube for RCA P60755AT - RCA Televison & Video
  • RCA Master
  • 8,617 Answers
You should be able to get one from www.tvrepairworld.com
Posted on Jul 17, 2010
JUST LOOKING FOR INSTRUCTIONS ON CHANGING THE LAMP.
the d52w20 rca model rca itc22 chasis is a 3 picture tube television.... it has no bulbs... do you mean to change a picture tube?
Feb 28, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need picture tube replaced for rca television not
You have to get the exact type no. of the picture tube. Better buy a new TV. Picture tube will be expensive and no guarantee whether it will have sharp image l after replacement.
Apr 01, 2010 | Televison & Video
Bad picture tube
Sounds like the sweep is going out. Probably cheaper to buy a new TV than repair.
Feb 14, 2010 | RCA TruFlat 27F520T 27" TV
RCA hdtv sound but no picture
sounds more like a vertical problem since the audio still works. If it were multiple green lines then I would say green tube but the tube will usually shut a set down and it will be dead no audio. Try replacing the audio output IC
Jul 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture no sound
High voltage Trippler is bad or shorted tube or need to replace FET ,startup Kit it has 16pin ic/ 4capacitors /resistors /everything you need to repair that circuit.So your tv is 15yrs old cost of replacing tubes 300.00 per tube.plus labor 190.00 and up ?
Dec 18, 2008 | RCA P52926 52" Rear Projection Television
No input from cable connection
Sounds likely you have a bad tuner. If you have a cable box with your cable service and it is upgraded for video and audio rca jacks output you can run red white and yellow wires to tv input where the DVD is connected or additional jacks if available. This bypasses the tuner
Jan 01, 2008 | Televison & Video
Picture tube
Both are generic tubes.....should swap if pin basing is the same.......T.
Oct 31, 2007 | Televison & Video
Rca 60'' p60928
The set does not have a blue lamp. The set has a blue picture tube. I have found that the best RCA parts distributor is Union Electronics at 1-800-648-6657. The picture tubes in projection sets are very fragile and dangerous to handle. The new picture tube will come dry, so the lens assembly and seal will have to be assembled onto the new tube and then filled with fresh coolant. The set will then need a complete realignment, everything from screen and focus voltages, bias and drive, yoke and ring position to convergence circuits. If you have no experience in any of the above, do not attempt to replace a picture tube. Allow a qualified tech to handle it for you.
Aug 28, 2007 | RCA P52926 52" Rear Projection Television
RCA Model # 20F510TD TV/DVD
What makes you think the picture tube is bad? What exactly are the symptoms you see? The RCA 20 inch picture tube is a good quality long lasting tube and I doubt I have ever seen a bad one.
Jul 03, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
Will not turn on
this sound is the power supply trying to fire,leaky caps notholding proper b+ voltage.you can check the error codes once the set does fire to view the fault code and narrow it what section is possibly at fault.rca sets take three tries then you out feature. thats why when it does fire check the codes,get a service manual also to help you out.
May 20, 2007 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
67 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
