Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Can not connect to routers ip address. Shows up as available network but cannot log on to router
    Problem Solver:
  • 25 Answers
What is the default gateway when running 'ipconfig' from command prompt? Load this IP into internet explorer.
Any luck?
Posted on Aug 12, 2010
How to connect my self and make my IP address ?
you can set your laptop up to detect ip address automatically in its network settings. if you had provided the operating system it would have helped to narrow down how to do this. If you had told us how you plan to connect to the router this also would have been helpful. Are you connecting via blue cat5 ethernet cable or via wireless. If it is wireless your laptop should detect the wireless network and you can ask it to connect to it. If the wireless link is encrypted you need to log into the router via ethernet cable and look for the securirty settings on the wireless and find out what the encryption code is. Usually the router will use what is called an internal IP address range. the subnet is usually class c being 255.255.255.0 and the ip address default gateway IP address is usually either 10.0.0.1 or 198.168.0.1 and this can be put into the browser to log into the router. When you set the laptop to automatically obtain the IP address the Wireless Router has a DHCP server that manages the leases of IP addresses to computers connected to it. However if you are connecting the Wireless Router into an existing network with another router you will need to set the IP address to the next IP address eg 10.0.0.1 on existing router make second router 10.0.0.2> if you have a DCHP server on the wireless turn it off if you have a DCHP server on the existing router otherwise you have confusion as to which DHCP server to listen too on your network.Make sure the DHCP router does not allocate at least the first 10 addresses eg 10.0.0.1 to 10.0.0.10 to allow for the routers and printers on your network that may need dedicated IP addresses (Static IP addresses)
Feb 07, 2015 | D-Link dlinkgo Wireless N 150 Router...
How to connect digitech high powered wireless router YN-8330
You may have problems getting this device to register on you network due to the available subnet.
You need to check what IP address range your existing router uses first, then connect the digtech directly to a laptop via ethernet cable, go to the default address (192.1.0.1), log in using admin/admin and reconfigure the router address to one within the acceptable range of your router..
I just configured one of these on both a TP-Link router, and on a Thompson router.
For the TP-Link (Base IP 192.1.1.1) I set the digitech to 192.1.1.100 (easy for me to remember).
For the Thompson (Base IP 10.0.0.1) I set the digitech to 10.0.0.100 (same principle).
Note: you can use any IP that is within the network range of your router.
Also remember to write down the new device ID and put it in a safe place (email to yourself or stick on the back of the router)
Other than this, all config is like any other router.
Feb 04, 2014 | Music
Reset my apple password
If you mean the WIFI password for you broadband router do the following.
connect router to computer using Cat5 network cable.
type the make and model of your router and google it to find it's IP address.
enter IP address into bowser and you should be able to log and change the inscription key.
Pass words and Name for router logon are usually default unless you have changed them yourself and available on the web, if not you will have to reset the router to default.
You may also have a sticker on the router that shows this information.
Hope this helps.
Jan 22, 2014 | Computers & Internet
How do I determine actual threats to my network while reviewing my wireless/network Router's Event Log?
Logs are meant to see the activities handled by your router. However, to determine any threat you can check for the IP address of the devices you have connected to your router. You can determine if any one else is trying to access your router by their ip address only.
Note down the IP address for all the devices that you have connected to your router. Than match the your devices IP addresses with IP addresses you found in the logs.
Matching IP address: Means your devices accessing the router. Unmatched IP Address: Someone else's devices trying to access your router.
You can always add security by using WEP/WPA2 key security. For further security you can encrypt the keys.
Jul 06, 2011 | NetGear WNDR3700 Wireless Router
Cannot get wireless internet to work. Set up wireless connection. Icon shows connected, excellent strength. There is another computer icon next to it on the task bar however that shows a red X through it,...
find that ip of the router e.g 192.168.0.1 or something like that
gott to the lan network connection of pc
got tcip option
in ther enter the ip addree 192.168.0.xxx ( anything but ther router address)
subnet mansk 255.255.255.255.0
defualut gateway the routers ip address
primary dns router router ip address
leave the secondary ip blank
Mar 05, 2011 | Computers & Internet
Can't resolve a W010 connection error
Let put all not IP Address in Obtain. I put all IP ADDRESS manually. Usually this will cause to your internet connection drop. I encounter your problem before but i use DUAL WAN or 2 Internet Provider.
And i hope it's the same problem to me.
Aug 29, 2009 | Actiontec GT704WG Wireless Router...
Comuter gets a 168 private ip
enable DHCP on the router and you'll get the right ip adress
Aug 05, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Linksys WRT54GS shows that it connects, but doesn't really
How could I possibly be smarter than the Linksys tech?
Do your computers have fixed IP addresses or obtain DHCP from the main router? You need to know this because you also need to let one or the other serve DHCP. If it were my system, I'd let the main router serve and the access points just exist.
For that to happen, you need to pick a fixed IP address outside of the IP addresses that can be assigned by your equipment, or pick one that is unused by your network devices.
Unplug the WAN cord from the Linksys and set your computer to 192.168.0.5 or 1.5, depending on what the Linksys does by default. Log into the Linksys and make it use a fixed IP address on the WAN side to whatever you need. Now, as I said above, I'd trun OFF LAN DHCP so it gets DHCP from your network router.
Now reset your laptop to use DHCP, power down the Linksys and plug it into the netrwork and power it up. From any computer on your network, you should be able to go to the router's fixed IP address and be looking at the login screen. Log in, change your password, and you should be up and running :-)
Note that there are a TON of variations on this theme, so don't despair if it fails to work. The key is knowing what your network requires.
Carl
Jan 14, 2009 | Linksys Wireless-G WRT54GS Router...
New computer hung at "Acquiring network address"
Verify that the DHCP feature of the router is enabled. Alternately, you may want to set the PC to use static IP configurations rather than "Obtain an IP address automatically". Sometimes WinXP WiFi configuration messes connections when none WEP or WPA is used.
You may want to fix set your PC's WiFi config to IP Add:192.168.1.2; Subnet Mask: 255.255.255.0 and Default Gateway: 192.168..1 (that is of course assuming that your NetGear RangeMax WPN824 Router uses the 192.168.0.1 IP add).
If this still does not work, pls post back so we can figure out tricking the WinXP WiFGi config to connect.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 02, 2007 | NetGear RangeMax WPN824 Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
