Question about HP Pavilion a305w (DM181AR) PC Desktop
Have an hp a305w pavillion powers up but nothing on the screen, tried f10 an nothing happened. Its as if the monitor isn't receiving a signal.
  • 78 Answers
Disconnect all cables, remove all cards and memory. Reinstall one stick of ram, power cord, video cable and keyboard. If that works reinstall other components one at a time. I found a hp a1600n at the dump. Brought it home, had same problem, tried this. A memory stick was loose. Resetting it fixed it. I am typing on it now. You might try the memory first. A chip could have gone bad.Are you using the board video or a video card?
Posted on Jul 17, 2010
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
Was just wondering because i tried one method but didn't work for me on my hp pavilion a305w, but my question is, can hp pavilion a305w boot from usbs?
unfortunately the hp pavillion a305w bios would have to support it. you would have to go into the bios on set uo and select that boot option. but unfortunately they do not have the option to boot from usb
Jan 08, 2011 | Computers & Internet
What are the appropriate steps to connect an external monitor to an HP Pavillion DV2000? When I try, nothing appears on the external screen... Thanks, RF
One of the function keys has a small monitor screen icon. Press that key while holding the Fn key, and you will enable the external monitor connector. These laptops don't automatically sense when you've connected an external monitor. On some models, the first press enables the external monitor and shuts off the laptop screen. If that happens, press the keys again and the laptop screen will come back on.
Oct 14, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Hp screen wont start up i just get the blue hp screen f10 = start up esc= boot menu f11=system recovery f9 = dignoses when i pree these buttonms nothing happens tried unplugging everything and still...
If pressing F11 ("system recovery") does nothing, then your disk-drive, which contains a "system recovery partition" is inaccessible,
i.e., your disk-drive has failed.
You'll need to buy a new disk-drive, install it, and use the original "System Restore" set of CD/DVD disks to reinstall Windows onto the new disk-drive.
Oct 11, 2010 | HP TouchSmart IQ770 PC Desktop
HP Pavillion zd8000 won't power up
Try attaching a normal VGA desktop monitor to it. There should be a plug either on the sides or the back of the laptop. A blue one. That way you'll be sure.
Apr 17, 2010 | HP Computers & Internet
HP Pavillion won't bring monitor back from sleep mode
hi...if u can read " no input signal" from ur screen, this means that ur monitor is ok..
Look if u have power buttons on ur keyboard.. try to wake it from there.. some pc may have shortcut keys to bring back the pc... look @ ur pc docs on the internet for more info...
However if it's a hardware issue, it may be that ur RAM memory needs to be cleaned
Feb 01, 2010 | HP Computers & Internet
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
Pavillion laptop is not booting.
Try to boot the notebook with F8 Key. (Safe Mode)
Also try to go into the BIOS setting and change there --> Power and Boot Priority.
For BIOS try: ESC, DEL or F2 keys.
Regards
Ellin
Sep 28, 2008 | Computers & Internet
HP desktop monitor problem
hi try this ,,,
  1. Ensure the video cable is connected (and connected to the correct video port).
  2. Turn off the monitor using the monitor's power button and then restart the monitor.
  3. Cycle the power on the monitor as follows:
  4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
  5. Unplug the power cord.
  6. Wait 5 seconds.
  7. Plug in the power cord.
  8. Press the power button on the monitor to turn on the monitor. One of two things happens:
    1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
    2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
    3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
      • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
      • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
      hope it will work for u .. little_angel
Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
HP Pavilion a305w (DM181AR) PC Desktop Logo
119 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
