Question about Epson Perfection V200 Flatbed Scanner
Filmy appearance and spots under glass on Epsom V200
  • 78 Answers
Operating heat vaporizes some lubrication grease that condenses on the glass. The glass is removable and can be cleaned like ordinary glass.
Posted on Jul 17, 2010
I have a Maytag glass top range. Almost from the first use, a spot appeared on a back burner, looked like water under the glass; It has steadily grown to nearly half the burner size. On a big front...
The problem you have is most likely due to a defect in the glass top. Contact Maytag and demand a new top. The defect can cause the top to burst and cause serious injury. You should contact maytag in writing, with a copy to the United States Consumer Product Safety Commission.
Feb 10, 2011 | Maytag Kitchen Ranges
Tip
How to Clean Scanner Glass
Steps how to clean scanner glass
1. Unplug the power cord.
2. Clean the outer case with a cloth dampened with a mild detergent and water.
3. If the document table glass gets dirty, clean it with a soft dry cloth. If the glass is stained with grease or some other hard-to-remove material, use a small amount of glass cleaner and a soft cloth to remove it. Wipe off all remaining liquid.
4. Ensure that there is no dust on the glass of the document table. Dust can cause white spots in your scanned images.
*** CAUTION: Do not press on the document table glass too hard.
5. Be careful not to scratch or damage the document table glass, and do not use a hard or abrasive brush to clean it. A damaged glass surface can decrease the scanning quality.
6. Never use alcohol, paint thinner or corrosive solvent to clean the scanner. These chemicals can damage the scanner components as well as the case.
7. Be careful not to spill liquid into the scanner mechanism or electronic components. This could permanently damage the mechanism and circuitry.
8. Do not spray lubricants inside the scanner.
9. Never open the scanner case.
***NOTE: Wipe the inside of the document cover and the scanner's document table before scanning transparencies.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
Cycle timer displays very different times for cycle, cleaning is not particularly good. Problems related? glasses appear filmy, even when rinse agent is used.
your dishwasher uses an optical sensor to constantly monitor the water turbidity or cleanliness if it detects the water is cloudy it will extend the wash time and vice versa there are several reasons for cloudy glasses check to see if they taste salty,or if the cloudiness washes off,this usually happens when the baskets are loaded badly and the detergents/temps are not set correctly.
Nov 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Just changed all cartridgages and photo quality is still bad
scanning
Spots on a scanned
- Glossy photo (original)
- In the high humidity
environment
When a glossy photo is
strongly pressed on the
platen glass, the photo
will stick to the glass,
and the stuck points are
scanned as spots.
- Do not strongly press
the photo on the platen
glass.
- Clean the platen glass
(to eliminate any
moisture).
- Spots appear on
the scanned
image, though
there is no such
spots on the
original
document.
Oct 13, 2009 | Canon Pixma MP500 All-In-One InkJet...
White Filmy residue
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Jun 28, 2009 | Maytag MDB8551 Built-in Dishwasher
Dishwasher still turns on but stopped cleaning dishes.
Hey, Matt
If the "soap" left on the dishes is a filmy residue, especially on the glasses, you probably have a failed heating element. The heating element is not only used for drying cycle, but also during the wash cycle to "activate" the detergent.
If the residue is not a film-type stuff, suspect a blockage in the sump/impeller/wash pump area. Check also for blocked holes in the wash arms.
Good Luck! Please report back what you find, OK?
May 07, 2009 | Dishwashers
Very filmy looking glasses
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jan 31, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
Filmy appearance and spots on the underneath of glass
Today I opened my V200 without much problems. First unscrew the two screws under the lid. Then turn the V200 upside down. Lift the base plate up, gently, beginning at the back (a little twisting is needed). Take care not to force anything. It took me 10 minutes. Fold everything open like a suitcase, then clean the glass inside...
To close again start with the front (sort of click system)
Jan 17, 2009 | Epson Perfection V200 Flatbed Scanner
REPLACE BATTERY
Just behind the wheel there are three raised lines in the plastic, just press down on this spot and slide the top back away from the wheel and replace the two AA batteries within. Life should be this easy.
Jul 13, 2008 | Logitech 931409-0403 V200 Cordless Ntbk...
Washing leaves spots
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you're using and adjusting your hot water heater's water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water. First you'll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, you can wash the glass with warm water and concentrated dishwasher detergent or use a high-phosphate detergent (such as Glass Magic) according to label directions. If film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature. See "Doesn't wash well," above. Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn't anything you can do to make it clear again. But you can avoid future etching by taking these steps: 1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don't use extra hot settings, such as "Power Scrub" and use "Energy Saver" dry cycle. 2) Adjust detergent amount. 3) Don't pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
Epson Perfection V200 Flatbed Scanner Logo
616 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
