Question about Electrolux 1910 Bagless Upright Vacuum
Electrolux regency series upright. Clogged hose cant figure how to open body to access to clear hose.
2 Suggested Answers
  • 694 Answers
SOURCE: remove bottom of electrolux prolux upright vacuum.
You shouldn't have to remove disassemble the powerhead.
Lay vacuum on it's front. Between the tank and the powerhead is a black flex hose. Pull the end straight out from the powerhead. Then unscrew the tube from the tank using a clockwise turn. Remove the tube and visually check for clogs and splits. Clear or replace as needed.
If there's a clog in the powerhead behind the brush, this can be cleared using a wooden spoon handle or similar object.
If there's no clog in either place, there's a couple other possibilities. First, turn the vacuum back upright, open the hose flap, turn vacuum on, and place hand over opening to check for suction.
If there's a lack of suction, the bag needs replaced, the afterfilter beneath the bag needs cleaned, or the motor needs replaced.
If there is suction, put a coin in the opening inside the port and to the right as you're viewing the front of the vacuum. The coin should drop to the floor. A clog in thes section is unusual, but can happen.
If there is still no suction, take the vacuum to the nearest authorized Aerus Electrolux store for free diagnosis.
http://www.aerushome.com/storelocator/
Posted on Mar 11, 2011
How can I get a new case for my 1990 Electrolux Regency Model 1572E? My case has cracked in many places, the top has just broken away from the hinge and the catch to keep the vacuum cleaner upright n
Yes, the Regency casings had a tendency to just "crumble" after many years of use for some reason so that exact casing is no longer available unless you find one online. If that's the case, you're best bet is to just replace yours with a rebuilt one . A lot less costly in the long run. Hope it helps!
May 27, 2014 | Electrolux Vacuums
Tip
Electrolux Epic 6500: Trouble Shooting I
Electrolux Canister Vacuum Shuts Off During Use<br /> <br /> This actually cover several models of Aerus and Electrolux canister vacuums. Models covered include: 2100, Epic 6000, Epic 6500, Aerus Lux 5500, Aerus Lux 7000, and Aerus Lux Legacy. Be aware that some of these models may still be under warranty. Any disassembly of those machines will void the warranty. Use of non-genuine bags also voids the warranty. Use only Home Solutions Aerus/Electrolux bags.<br /> <br /> First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.<br /> <br /> Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.<br /> <br /> Check and clean screen at back of bag well.<br /> <br /> Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.<br /> <br /> Check and replace afterfilter if necessary. These should be replaced after every six bags.<br /> <br /> Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.<br /> <br /> Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.<br /> Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.<br /> <br /> If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.<br /> <br /> The store nearest you can be found by following the instructions at the below listed link:<br /> <a href="http://www.aerushome.com/storelocator/">http://www.aerushome.com/storelocator/</a><br />
on Dec 20, 2010 | Electrolux Epic 6500 Vacuum
Electrolux ZUA3820P vacuum cleaner - how to access motor for repair
Tricky but you need to lift the slider cover off that adjust Min & Max speed and you will find 2 screws underneath, then you need to slowly take of plactic cover around the inlet hose and you will find another 2 screws
Apr 11, 2012 | Electrolux Vacuums
I have Electrolux Versatility and have little suction power in the hose part,
Unplug the machine..now if you remove the attachment hose at the body of the vac and feel inside (to the right about an inch) their is a "suction cover" that rotates when the wand is removed (aka using atachments). The cover in your machine is NOT rotating correctly, so it does not get full suction. If you do get some suction from the hose then their is at least a 'small opening' because it has partially rotated. I was able to fix this problem by taking a large screwdriver (1.5 feet long, thick as a pen), inserting it into the small opening (on the suction cover, inside to the right at the top) and forcing the cover down all the way by lifting the screw driver up against the top of the body opening. Seems to have corrected the problem, but may reoccur. If you have NO suction at all then it has failed to rotate whatsoever, and Im not sure how to correct it.
picture of the suction cover part:
http://evacuumstore.com/p-3604-electrolux-versatility-el8502ab-cover-suction.aspx
Nice of that sales lady to provide zero help...
-Steve
May 05, 2011 | Electrolux EL8502 Versatility Bagless...
I have an electrolux epic 6500 sr. The change bag light came on, I changed the bag, now it won't run properly. If the bag is out and the hose attached it will run or if the bag is in and the hose is off...
First, if it runs without a bag, there's a problem with the bag lock-out switch or wiring. This needs to be replaced/repaired by an authorized Aerus Electrolux technician.
Mar 21, 2011 | Electrolux Epic 6500 Vacuum
Remove bottom of electrolux prolux upright vacuum. Hose is clogged.
Mar 11, 2011 | Electrolux Vacuums
I have an electrolux 2100 it wont turn on
Jan 05, 2011 | Electrolux Vacuums
Keeps opening as if the bag is full. HOw do I fix this.
Dec 28, 2010 | Electrolux Lux 5500 Canister Vacuum
There is no suction in the hose part, long part of hose is not cloged
To the guy below me...way to not even read the question....
-Steve
Nov 11, 2010 | Electrolux EL8502 Versatility Bagless...
Suction indicator is not spinning cant figure out what is clogged
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Aug 07, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
212 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
