Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Change blades on riding mower
How do you access the blades to change them
    Sniper:
  • 56 Answers
Your owner's manual should give you full instructions on removing the mowing deck from your tractor....once it is off, should be a simple matter of turning the deck upright and removing the bolts which hold the blades to the spindles and replacing the blades..... ;-D
Posted on Jul 17, 2010
How do i change the blades on a 42in zoom z turn
raise the front of the mower to gain access to the underside where the blades are, using the right size wrench undo the bolt or bolts that hold the blades on and remove them from the mower, replace the blades and tighten the bolts to the required torque, lower the mower to the ground and take it for a test run.
May 19, 2014 | Ariens Zoom 42 In 165 HP Briggs Stratton...
How do you change the blades on a massey ferguson 42/40 ride on mower
I sometimes just raise the front end and use a small side grinder on the blades --- use eye protection and leather gloves
Mar 24, 2014 | Garden
I have a Brute by Briggs Stratton 21hp driveable lawnmower. How do you change the blades?
JUST RAISE THE MOWER TO HIGHEST POSITON TO ALLOW YOU ACCESS TO BLADES
REMOVE BOLT AND BLADE AND INSTALL NEW OR SHARPENED BLADE
ENSURE IGNITION SWITCH IS OF
Sep 02, 2011 | Briggs & Stratton Garden
How do you set the mower blade height on a riding mower. The mower deck is set by the height adjuster but how about the blade
The blade height is not adjustable on any of the tractors I have worked on or owned. The blade seats against a shoulder on a spindle and held in place by a nut. Sometimes replacement blades are not shaped the same as the original and changes the blade cuttnig height but other than in those circustances there is no adjustment.
Jun 18, 2010 | Garden
42 deck craftsman riding mower. how do you get blades off? md 91721880.
On most riding lawnmowers, you can remove the blades reaching underneath the deck while the deck is set to its highest position. This may not be possible on lawnmowers with three blades; however, most 42 inch mowers have two blades.
The blades are usually held on with either one or two bolts (on each blade). Oftentimes, too, there is a lock washer underneath the bolt.
If you have auto ramps, it might help to push the front end of the mower up on the ramps. This can give you more room to access the blade bolts.
If the blades have not been removed before, those bolts can be on really tight. You might need to use some kind of breaker bar on your wrench to give you more leverage.
Oct 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a murray riding mower with twin blades..how to change
take a socket rench with 2 feet pipe....slide the rench handle to the pipe and that well give you enough power to turn you have to hold the blade with something from turning .....ometime you can hold it with a towel
Oct 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you change the blades on a 40" riding lawnmower by murray?
Raise up the mower to give yourself access to the blades from the bottom side of the deck. Using a breaker bar or long ratchet and socket, remove the nut (either 7/8 or 15/16 can't remember which) and large flat washer from the shaft. Install the new blades in the reverse order.
If the blades turn while you are trying to "break" them free, you can use a small 2x4 block of wood or a c-clamp on the side of the deck to hold the blade from turning until the nut is freed up
Sep 26, 2009 | Garden
Riding mower will barely move
Sounds like it time for a tuneup. Air filter changed, Spark plugs replace and oil changed, plus sharpen the blades while you are at it.
Sep 26, 2009 | Mtd 22" Yard Machine Push Mower
Changing blades on riding mower
Must be able to get to underneath side of deck obviously. If you do not have access to impact tools, it is usually easiest to remove the deck as you must keep the blades from turning. Place a block of wood to where it will jam the blade while attempting to turn the nut. (7/8" socket or wrench). Usually very tight, try some penetrating oil to help.
May 18, 2009 | Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
322 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Poulan Garden Expert? Answer questions, earn points and help others
