Question about Kitchen Ranges
Oven pilot light won't light
It was working fine and then my husband accidently sawed the propane pipe outside when building a deck. The range was set up so that one oven light was the only light that stayed on continuously. We needed matches to light the stove top which was fine with me. The strange thing is that after the pipe was repaired, the stove top continued to work with a match but the oven pilot light never came back on. Of course, we tried to light it, but no gas seems to be coming to the oven pilot?????? Help
Kenmore gas range (model 72221): Pilot light went out and could not be re-lit. No gas seems to be flowing to pilot. The stove top works fine, so there is gas available. Looked for a "button on safety valve", as per suggestion of someone who solved a similar problem on a different oven, but no button or valve could be found. Unplugged the power cord for a few minutes to see if valve would "reset" but problem remained.
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Posted on Apr 21, 2008
2 Suggested Answers
SOURCE: oven pilot light won't light
you must push and hold the button on the bottom fo the safety valve until the thermocouple is warm enough to keep the safety valve open. @ 25 - 30 seconds
Posted on Feb 05, 2008
I was using my oven when all of a sudden there was a loud whoosh sound. Since I use propane I immediately turned off the oven.
Hi, it sounds like you may have a gas leak some where else on your oven probably from the supply pipe . It looks like it is building up then its been ignited so you get a whoosh. Best get it checked out.
Jan 30, 2016 | Kitchen Ranges
I have an arr3140ss American gas range. Just recently installed new burner and igniter.Roasted and baked all last week no problem todayI turned on the overn abd got up to 550 for pizza. put pizza in
Sometimes the pilot light goes out on this type of oven. This could be caused by a draft, or sudden jolt. Even if the top burner is working, the bottom won't go on until the pilot is lit. Check your manufacturers' instructions for locating and re-lighting the pilot.
Best of luck.
Nov 30, 2014 | Kitchen Ranges
We just converted a brand new natural gas kenmore range to propane and followed the instructions to a tee doing it. The burners are fine and work great, no smell. When the oven is started it smells li
On the pressure regulator there is a small cap this turns or unscrews and inside there is a part that has to turned around to convert to propane. They are fairly easy to do. Access to the regulator is usually the hardest part. If this is not done the pressure to the burner will not be correct and you will not get completed combustion of the gas. This could cause Carbon Monoxide issues and soot build up.
Oct 01, 2014 | Kitchen Ranges
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Oven pilot light won't light. Stove burners work fine.
if you have a pilot flame oven replace your thermocouple
if you have a newer oven you will have an ignitor
please advise me on whitch type of oven you have
Feb 05, 2013 | General Electric ge JGBS04BPW wb1k5 Oven...
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
I noticed soot in my lp gas oven that had been clean. concerned when it started to ruin my food I decided to run the self cleaning cycle again. My whole house filled with toxic soot. My eyes were on fire...
Normally soot is from a range that hasn't been converted for the gas type, like natural or propane. It may be set up for natural when you're on propane or visa versa. Has this range ever worked properly without sooting?
Sep 20, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven won't light , but broiler works fine
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 22, 2010 | Kitchen Ranges
I just got my (new to me) pre-1990 Wolf 36'' range connected (by a certified pro). 4 burners, 12'' fry top/charbroiler/cheesemelter thingie on left, 4 burners on right, 29'' oven - propane. It has not been...
the oven pilot has 2 setting first setting is for you to light small flame, should not be all yellow if it is it has a dirty orifice inside the pilot hood, you can remove this by disconnecting the pilot line from the hood and removing orifice for cleaning, just rub it with a cloth.once clean and replaced you light pilot and check it out. if its ok turn on oven and secondary pilot will ignite that why it got bigger!! this heats a flame sensor to allow 100% safty vavle to open to let gas into burner so yuo can cook.
Feb 02, 2010 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
Kitchen Ranges Logo
712 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
