Question about Kenmore 47081 Front Load Washer
My Kenmore Elite model 47086 washing machine displays error code F70. Does anyone know what this means or how to fix?
  • 15,935 Answers
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
I got an F70 code . After unplugging the machine and then plugging it back in, I now get an F71 code. What to do?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Oct 16, 2010 | Kenmore Elite HE5t Washer
I have gotten F70 and F71 messages and the door will not open. What do I do about this?
Hi.
Regards.
Ginko.
Jun 23, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore ELITE HE 5t 47086 frontload errror code F70
Feb 26, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3 problem code F70 - what does this mean
F 70 error code indicates some kind of communication problem between the component electronics and the control electronics. Before calling a technician I suggest disconnecting power to the machine for about 30 minutes, reconnect it, and try again.
Jun 23, 2009 | Kenmore Washing Machines
Kenmore Elite HE5 inoperable and F70 error code.
HI, this error code represent a major control issue within the main control. simply replacing the main control will fix this issue. the logic chips are damaged.
May 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Washing machine error codes
I am getting F35 error code. What is the problem?
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3t
maybe a false code if so may mean new control bd ..tech sheet is behind bottom panel with all fault codes if not on there code is a glitch in control
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite eletric dryer model 8708
I've never heard of an F70 I have heard of an F07 which is possibly a motor controller error.
Nov 28, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 47081 Front Load Washer Logo
206 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
