Question about Gaggia Baby Espresso Machine
Baby gaggia wont pump - Gaggia Baby Espresso Machine
  • sem8 Jan 06, 2009
    machine no pumping at all.
    no cirquit connection between the two connections of the pump.
    pump is broken (burnt).
    need a new-pump.
    pump: EATON 240v~70w mod:CP2
    Problem Solver:
  • 15 Answers
The pump may only have lost its prime. To prime the pump:
Fill an ear syringe (available at most pharmacies) with water. Insert the business end of the syringe securely in the tube that normally takes up water from the reservoir. As you squeeze the syringe bulb, flip the brew switch on. If you see movement of water in the tube, and hear a change in the sound the pump is making, flip the brew switch off, remove the syringe, and put the tube back in the filled reservoir. Now flip the brew switch on, and see if the pump can draw water on its own. Repeat several times if necessary. If the pump still won't pull water, then it must be replaced.
www.espressosolamente.com
Posted on Jun 14, 2008
Fixed mine with a syringe of vinegar and hot water, several 10 ml injections into long line that goes into tank, turn on pump. if movement inside the hose that goes to the tank, turn off. and repeat several times, eventually using a big Mardi Grad cup full of the solution before transferring to the water tank. Don't give up!
Posted on Jul 18, 2013
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: no water coming through group head
Remove the shower screen and clean. If shower is clean then line to head is clogged.
Posted on Jun 19, 2009
  • 1089 Answers
SOURCE: My baby gaggia dose (brand new out of the box) leaks
HI
Call who ever you bought it from and have them diagnose the problem. I think you have a disconnected hose or something worse.
Posted on Nov 18, 2009
Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Nov 26, 2009 | Gaggia Baby Espresso Machine
HI
Nov 18, 2009 | Gaggia Baby Espresso Machine
The pump isn't pumping. The machine is making the
Hi
There are no diaphrams in high pressure pumps. They use a small piston and check valves that can become stuck. Some can be fixed but that old it might be better to get a new pump. You can sometimes find them on ebay.
Oct 14, 2009 | Gaggia Baby Espresso Machine
Baby Gaggia Dose leaks
On the gaggia clascic there are 2 hoses in the back above the drain tray, are those in the water reservoir? If yes then there is a broken hose on the in side of the machine.
Aug 12, 2009 | Gaggia Baby Espresso Machine
No water coming through group head
Jun 18, 2009 | Gaggia Baby Espresso Machine
My Gaggia Baby C coffee maker has stopped pumping water
From what you have asked the only thing I can suggest is that the pump needs to be replaced. Do you hear the pump vibrating? The lines from the pump may be blocked. Have you tried to descale the machine.
Jun 06, 2009 | Gaggia Baby Espresso Machine
Gaggia baby dose solenoid valve
You may get this part from EBay for around $45/£38 a small "How to" below ">
Dec 04, 2008 | Gaggia Baby Espresso Machine
Gaggia baby dose d (circa 2007) wont dispense water? pump?
Sounds like it needs descaling - not the normal descaling but inside the pump head!
Oct 25, 2008 | Gaggia Baby Espresso Machine
Gaggia Baby Espresso Machine Logo
1,079 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
