Question about Buck Ford F250 F350 2002 02 Radio/stereo Wire/wiring Harness
I am baffled as far as wireing the new harness to the old wires in my '03 F-150 stereo they have several wire of the same color 4 black wires 2 purple and black wires ect i need help.
  • glosee2338 Jul 17, 2010
    this seems like a good answer im gonna give it a shot
    Master:
  • 497 Answers
Did you happen to look into buying a wire harness adapter? The sell them fairly cheap at Auto Parts Stores. (approx. $20-$25) It is very easy, as well as making sure it is correct. Otherwise you are taking risks of many types. Such as, electrical issues, sound issues, etc. Just a suggestion.
Posted on Jul 17, 2010
    President:
  • 670 Answers
Radio 12v: white/yellow + radio harness
Radio Ground: black/light blue - radio harness
Radio Ignition: black/pink + radio harness
Radio Illumination: red/black (dimmer) + radio harness
LF Speaker: orange/light green (+) - light blue/white (-)
RF Speaker: white/llight green (+) - green/orange(-)
LR Speaker: gray/light blue (+) - tan/yel (-)
RR Speaker: orange/red (+) - brown/pnk (-)
Can't say for sure but the constant, ground, and ignition wire colors. If those aren't present, look for the following:
12v Constant: Green/Violet or Green/Black
12v Ignition: Pink/Black
Ground: Black/Green
Hope this helps.
    simplify please and all the wires that u mentioned are there plus more and alot of the wires resemble each other should i pay $60 to get it installed professionally?
  • Stephen Lam Jul 17, 2010
    These wires that are used to power the radio and connect up to the speakers. Since a lot of the wires look similar you should verify each wire by using a meter before connecting your equipment. If this is too difficult for you to do, then the best option would to have your equipment to be professionally installed.
How do i know which wires go to my new head unit?
Probably need a new wiring harness for your vehicle model. Crutchfield.com is a good place because they will help you out with the wiring.
Jan 04, 2016 | Pioneer Car Audio & Video
I am putting in a new stereo system and I need to know what color wires go to the speakers
If your installing a new stereo deck you should get a wire harness from walmart $10-$20..
this will make it easy work!! the harness will have labeled wires.
If you cut the wires then i need the make and year of the car to help more.
On the new deck most have the same colors..
the 2 white.. front left
greens rear left
grays front right
violet rear left
remember the wires with the black line is the - ground
Jul 14, 2011 | Car Audio & Video
I've just purchased a new stereo (VR3 CD/MP3 player) for my 2005 Dodge Ram 1500. Where can I find a audio wire diagram for the wire harness? The wires on the new stereo are all marked; however, the wires...
1.Look on the top of the old deck
2.red wire power
3.black ground
4.yellow wire memory
Than you can try and do it from the sound coming out of the sperkers
Apr 17, 2010 | 2005 Dodge Ram 1500
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
IM TRYING TO HARDWIRE A CAR STEREO TO 97 JAGUAR
Try going to the nearest Walmart. They have cable harness adapters for all Makes of Cars there. You need to find the one that goes to your car then you will need some **** splices, and a crimping tool. You have to connect the wires from the cable harness to the wires that come from the back of the new car stereo you're wanting to install. You may also need a dash kit which they also sell at Walmart for cars. The wiring is pretty easy, red to red, black to black, the wires with a color and a stipe are the speaker wires. The ones with a black stripe are the neg. and the solid colors are positive. Ex. purple/puple with back stipe. There will be 2 sets of speaker wires for every speaker in the car either 4 or 6. Try that out and see how it goes.
Jun 06, 2009 | Car Audio & Video
No power
Red is power (+12v)
Black is negative
Orange or Yellow is memory
Blue is for amplifer turn on signal
Then there will be 4 or 6 pairs wires with the same color which are the speaker wires. The solid colors are positive, the solid with a black stripe are negative.
You can get a cable harness for your car from Walmart and then all you need to do is match all the wires color for color to each other from the cable harness to the new stereo wires with **** splices and a crimping tool which you can also get from Walmart and that's it. Then all you need to do is connect the two old connector from the old car stereo to the new cable harness connector which is made for your car and there you go. After that you may need a dash kit which you can also get at Walmart..Hope this helps.
May 09, 2009 | Car Audio & Video
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
I can't find a wiring diagram for my car.
Any car stereo shop can help you. Be nice to them,they can help you, maybe charge a few bucks. Keep the faith.
Feb 04, 2009 | Hyundai Motor 2000 Tiburon
Stereo wireing
go to advanced auto parts and buy a connector for your car. just go and give them year, model and make and when you get it connect the same color wires from the stereo to the stereo harness. all of the colors are the same.
Jan 07, 2009 | 1998 Oldsmobile Intrigue
What are the stereo wiring color codes for a 1991 Toyota camry?
Constant 12V+                 Blue/Yellow  Switched 12V+                             Gray  Ground                                         Brown  Illumination +                                Green  Dimmer n/a  Antenna Trigger                             Black/Red  Antenna Driver's Pillar  Front Speakers                             3 1/2" Dash Left Front (+)                                 Pink  Left Front (-)                                  Purple  Right Front (+)                               Light Green  Right Front (-)                                Blue  Rear Speakers                               5 1/4" Rear Deck Left Rear (+)                                  Black  Left Rear (-)                                   Yellow  Right Rear (+)                                Red  Right Rear (-)                                 White
Jan 04, 2009 | 1991 Toyota Camry
Buck Ford F250 F350 2002 02 Radio/stereo Wire/wiring Harness Logo
61 people viewed this question
Top Buck Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
