Question about Sharp R-202EW Microwave Oven
Sharp R-1450 micro over range removal
Hello, how do I remove the microwave after I unplug it? Where are the anchoring screws? My cabinets don't appear to have bolts holding the micro in place.
Thanks much
  • wja3rd Mar 24, 2009
    How do I remove a Sharp Model R 1450 microwave?
  • Peterl218 May 11, 2010
    Thanks.
    How do I remove the microwave's outer shell?
  • Sharp Master
  • 9,098 Answers
Those specific installation instructions are no longer available, but I have a couple for other models that may be close enough to help.
I have uploaded them here and here.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 21, 2008
Try removing the filters beneath the microwave. You'll find a large screw at roughly a 45 degree angle on each side. These screws bolt the microwave to the mounting panel in the rear.
Posted on Jan 02, 2009
How to remove microwave ffrom holiday rambler rv
Normally the outside shroud, has screws to remove, then microwave slides out. Be sure to unplug before trying to remove it.
Oct 11, 2011 | Sharp R-930AK Convection/Microwave Oven
My fridgidaire microwave just completely lost all power out of the blue. Could it be a blown fuse in the microwave itself?
It very well could be a blown fuse. I assume you checked power at the plug and checked the breaker. Also I assume and over the range micro. To get to the fuse you need remove the grille above the door then you should see a screw holding the control panel in place. Remove that screw and tip the panel out and you should see the fuse ( sometimes two) just inside the cabinet. remember to unplug or turn off the breaker before doing any repairs. you can goto - http://www.searspartsdirect.com/partsdirect/index.action - to find a parts breakdown and order parts. Good Luck
Mar 14, 2011 | Frigidaire Microwave Ovens
How do i remove an old oven
It is much easier for two people to remove the microhood. If attempting alone, please move the range out so you can get under the micro to support the weight. If the range stays in place, protect the top from damage.
1. make a landing site to the side, to protect the floor when putting the micro down after removal.
2. Disconnect the power cord in the cabinet above.
3. loosen the two screws in the bottom front corners of the cabinet above. When removed the front of the micro will drop, be ready for the weight. Busy times, tools in hands microwave coming down in front.
4. tilt the front down. pull the cord out of the upper cabinet.
5. with micro still tilted down in front, lift the back of the unit upward to free it from the wall plate.
6. remove the fasteners in the wall plate and remove.
Congrats, begin celebration.
Jul 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I remove my Hotpoint microwave RVM 44004? Two bolts visible from the cabinet down into the microwave. Removed them with zero result. No other fasteners visible in top or side cabinets.
1. make a landing site to the side to protect the floor when putting the micro down after removal.
Jan 20, 2010 | Hotpoint RVM1435 Microwave Oven
How do you un-install a kenmore 665.61639100 microwave?
the link below will take you to the installation instructions if needed.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0211226.pdf
Dec 26, 2009 | Kenmore 62642 / 62644 / 62649 Microwave...
Removing sharp R1831 over the counter convection microwave
the two long rectangular rod should slide down 1" to 1.5" unlocks the back plate and then it will slide forward and come off the wall.. hope it helps
Sep 19, 2009 | Microwave Ovens
How do i remove sharp microwave from wall model
The only problem that ricksterboy doesn't list, is there are also two screws located underneath as well. You have to take off the filter screens to find them. They secure into steel supports inside the microwave.
No getting the micro off the wall w/o removing them, or using a sledge hammer...which after all the time we used trying to get the thing off the wall, seemed like a good theraputic option.
Lucky we took off the vent cover and discovered the additional anchors.
Aug 22, 2009 | Sharp Microwave Ovens
How to get sharp r-1440 disassembled from under
Probably don't need this anymore, but there is another post, which we added to. Hope you had success.
Be sure to unplug first.
It is mounted on a steel bracket which the micro was tiled into place on. The bracket covers the entire area of the wall where the micro sits.
Basically, two screws in the bottom of the overhead cabinet, and two more screws located in the venting area of the microwave (under). Take the vent filter covers off each side, and remove one screw on each side carefully. If you take the fan cover off in the top front, you can see the steel support on the left.
Two people: The micro is then lifted up and off the support slightly, and then tilt forward to remove.
Jul 15, 2009 | Sharp Microwave Ovens
How to remove maytag microwave over the stove about 10 yr old
There is a considerable amount of weight to lower. It is an easier removal with the range pulled out and moved to the side. If you choose to move the range, be sure to protect the floor. Unplug the microwave. The plug should be in the cabinet above the range. There are two screws in the cabinet above that screw down into the top and support the front. These are the only fasteners that hold the machine directly. An assistant would be nice to have to help with the weight. While supporting the microwave, remove the two screws and slowly lower the front of the microwave pulling the cord out of the cabinet above as you go. Once the cord is free, tilt the machine down in front until the back can be lifted up off the plate that is fastened to the wall.
Jul 12, 2009 | Maytag MMV4205 Microwave Oven
REMOVING A RANGE MICOWAVE OVEN
Look inside the cabinets to see if there are any screws, as they act as anchor support, in supplement to the mounting bracket at the back of the microwave which supports most of the weight.
Jan 21, 2009 | Whirlpool MH1150XM Convection/Microwave...
Open Questions:
Sharp R-202EW Microwave Oven Logo
338 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
