Question about Refrigerators
I have FRT18B5AW7, the freezer workes fine but is frosting. The refrigirator is getting warm and all food is getting spoiled. This might some defrost problem. What is exact problem. where defrost timer, heater and theormostat located. Also give me clue how to open and fix this system thanks
  • by9591 Apr 22, 2008
    This not new fridge. It worked well for 4 year. I talked one of the tech, he said that is to do with defrost unit.
  • 123 Answers
Is this fridge new?
Does it matter how cold you crank the dial on the fridge -- does it just stay the same temp?
If so, i had this problem with my new fridge.
The manufacturer did not connect the fan before shipping it out. Therefore, the cold air collected in the freezer (alcohol would freeze to sluch) but the fridge stayed the same temp (all the food would go bad).
Since it was still under warranty they fixed it.
Repair man came out, took the freezer apart from the inside and rehooked up the fan. Has worked great ever since.
If this isn't a new fridge than my guess is that the fan has stopped working and might need to be replaced.
Hope this helps.
Good Luck.
Posted on Apr 21, 2008
My Vitrifrigo DP2600 fridge now gets very hot along the front divide between the fridge and freezer. What could cause this? How can it be fixed?
Seems like your self defrost mechanism is fubar. Check the defrost element and make sure that it is not open and that the timer is working. I parts needed go here Search Over 2 1 Million Appliance Parts
Sep 11, 2017 | Frost Refrigerators
Hotpoint refridgeerator side by side fan not working nor does the compressor?
First thing I'd do is defrost it completely, that means turning it off for a few hours with door open & letting the ice melt, you could be getting a buildup of ice in your freezer jamming the fan before the automatic defrost has time to clear it. Also check that the seals are sealing completely, (that can allow frost to form in freezer), if not use a hair dryer to soften them (gently) & mould them back into line.
Nov 19, 2014 | Hotpoint HSS25GFP Side by Side...
Side by side whirpool freezer not cooling how to check for defrost problem
The first signs of a defrost problem in a side by side are the fresh food section warms enough to spoil milk and bread. The back wall of the freezer will show frost buildup like in this photo HERE. If you have the frost building in the back of freezer then behind that wall you will most likely see this HERE Look around the fresh food section door frame for a model number like in the photo below.
8d69e0c5-292d-48ae-bd68-761cc9aaef30.jpgRepair Clinic
If the problem is a frost related problem you will need to know what the model number is to decide just what type of defrost componentes your model will need. Decribe your problem a little better and I will tell you what you need to do from there. Just make sure someone has the model number because your model may have electronic defrost controls or a simple defrost timer. The defrost element could be the only problem. Tell me what the temperature is in freezer and what type of frost pattern you have, Sea Breeze
Apr 01, 2013 | Whirlpool Refrigerators
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
I have a Kenmore side by side refrig. and the freezer side keeps getting full of frost, and the refrig. side is barely cold, and keeps spoiling food. I've had a tech come out and check things out and...
Either your defrost element or timer is bad or your fridge is low on freon. Frost is a sign of outside air getting in but it can also be a sign of the defrost heating element not kicking in and the defrost timer turns it on for a few minutes each day and a defrost limit keeps it from getting two warm during the defrost cycle. good luck hope this helps
Aug 17, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The refridgerator is not getting cold
sometimes when the air flow is restricted cold air migrates back into the bottom of the fresh food side and could freeze the dispenser resevoir which is behind the crisper drawers. Also, just defrosting the freezer is only treating the symptom. Something malfunctione to allow the frost to build up. Either the heater, defrost limiter or defrost timer.
May 05, 2010 | GE GSS20IEP Side by Side Refrigerator
Freezer wrk OK but temperature in the bottom fridge not cold
If you have a frost build up on the interior back wall of the freezer, you have a defrost issue. This would include a bad defrost control, bad heater or terminator.
If there is not a frost build up then you may have a bad evaporator fan motor.
Apr 28, 2009 | Frigidaire FRT17G4B Top Freezer...
Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Fridge getting warm, defost not properly working...
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Danby Designer DAR1102W Refrigerator
Ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Aug 10, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
