Question about Kitchen Ranges
I have Bradford White water heater model # m440t6fbn5 with a unitrol electric pilot light the serial number : ae4675620 DASH NO:-394 WITH A 40 GALLON TANK. The pilot will not stay lit. Got in shower and water was warm not hot. Checked water heater and no flame. Pilot lights and stays lit but wont stay lit when turning knob to on position. What caused flame to go out and pilot not to stay lit. How can i fix it? Thanks
  • stephen bruno
    stephen bruno Jul 19, 2010
    I have Bradford White water heater model # m440t6fbn5 with a unitrol electric pilot light the serial number : ae4675620 DASH NO:-394 WITH A 40 GALLON TANK. The pilot will not stay lit. Got in shower and water was warm not hot. Checked water heater and no flame. Pilot lights and stays lit but wont stay lit when turning knob to on position. What causes pilot flame to go out. How can i fix it?
    the pilot light goes out as soon as you let off the button. i held it for 1 minute- 2 minutes and 3 minutes and it went off as soon as i let off of it each time.
    Thanks
  • stephen bruno
    Again thanks so much. You were right on the money and your link to the manual made it easy to FIX the problem. Your advice awhile back about an E4OD transmission was right also.
    Have an Outstanding DAY!
  • 2,272 Answers
It has a hot surface ignition.the hot surface ignites if the blower is exhausting.The hot surface will go out if the flame sensor isn't detecting flame.Besides all this that water heater has a 6 year warranty.If its a old heater and you just put in a new thermo couple.the problem is still the flame sensor.If you scratch the scale off the flame sensor and thermocouple with a knife its ok,don't sand with sandpaper etc.If thermocouple is not replaced then check the thermocouple too. -------- if still you want to confirm what is the exact fault.before replacing any part.Its advisable that you get each part checked mentioned as per service manual.In owners manual there is nothing listed about checking the internal part .But in service manual all procedure is mentioned in detail. to get service manual.Just click on the link below. http://www.bradfordwhite.com/images/shared/pdfs/manuals/44943A.pdf check as per service manual.----------------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 19, 2010
  • 1,476 Answers
Your gas control valve is bad and needs to be replaced more than likely.
When the unit calls for heat watch to make sure that the pilot light gets larger. If it does then the pilot circuit is OK. You could have a bad thermal valve but more than likely the main gas valve is defective.
After the pilot light gets larger count to 5 and if the main gas valve does not turn on the main gas valve/control box is bad and needs repalced. If you are not sure of the procedure you should hire a competent technician to replace the unit.
Let me know if you need more help. Thanks for using FixYa and for the great rating!!!!!
hardrocko
Posted on Jul 17, 2010
  • stephen bruno
    stephen bruno Jul 17, 2010
    the pilot light goes out as soon as you let off the button. i held it for 1- 2 and 3 minutes and it went off as soon as i let off of it.
How do I light my hot water heater?
It is pretty easy - make sure gas valve is open, change control know to pilot. Press the ignitor a few times and once pilot lights up switch control to warm or hot position.
See instructions by downloading manual for MI-403SF6BN from this site
Bradford White Water Heaters Built to be the best
Sep 15, 2014 | Bradford White Bradford MI403S6FBN-337 40...
How do you light the pilot light?
Hello, You cant light a pilot light on an electic water heater. All you can do it have electrician make sure it is wired in correctly and have him show you the correct breaker or fuse for the water heater.
May 19, 2014 | Bradford White M250S6DS2 50 gallon 240v...
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instructions
1) Copy following links to identify gas control valve and read ignition procedure, and access service manual for your product:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Honeywell gas control used on recent Bradford White gas water heaters has red knob that rotates to pilot. Press and hold red knob. Then push red igniter button until status light changes.
Feb 11, 2013 | Bradford White Bradford MI30T6FBN-337 30...
Bradford-white water heater wont heat water.the blower motor hums but wont blow.also,pilot light wont light,is this just a safety feature?
Water heater is not identified and gas valve is not known.
Review options below:
1) Add a comment and describe what gas control valve is on the water heater, and model number from label on side of unit. Include what you have tried so far.
2) Try unplugging water heater and see if water heater resets.
Disconnect blower from gas valve, then plug blower in to see it it operates.
This will eliminate or include blower as suspect.
3) Open following link to download service and product manuals to help troubleshoot exact model.
http://www.bradfordwhite.com/documentation/residential/gas.asp
4) Open following link to identify gas valve.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Oct 04, 2011 | Fasco Bradford White Hot Water Heater...
My fan on top of my bradford white water heater model mitw40L6en13 went out. What kind of of exhaust/blower should i get to replace it? Thank you
Contact Bradford White and ask which blower is correct:
http://www.bradfordwhite.com/supportserv.asp
Get model number and serial number from label located on side of tank.
This information will help BW find exact information for your product.
Jul 28, 2011 | Fasco Bradford White Hot Water Heater...
I have a bradford white 40 gal gaswater heater.the pilot will not stay lit.after i light it it fires right up and runs untill it reaches the set temp.then needs to be relit
just the week i repaired a b/w w/ same problem need to replace the temperature control (part where all the lil tubes connect and button where pilot is...shud be on 800 number on w/h or go online www.bradfordwhite.com and enter serial no. might still be under warrnty if not probably cheapr to get new water heater
Nov 18, 2010 | Water Heaters
Kitchen Ranges Logo
528 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
