Question about HP Computers & Internet
My hp pavillion laptop is having a problem with a mobile mouse usage. i know it's the laptop because a perfectly functional wireless mouse does not work on this laptop. could it be something with the usb ports themselves. i've tried it in all usb ports, doesn't work, the functional mouse as well. is there some way possible that the usb ports got ''turned off''? advise please..........thanks
  • HP Master
  • 4,924 Answers
It may be just a matter of a driver ...for example you have a 1.0 port and it need a 2.0 usb port ..so you will have to install the 2.0 usb driver ..if it is not installed...or maybe the laptop is not equipped with one ...but I doubt it ...Anyway ..first go to bios (press F2 on start ) and in there restore to optimal factory defaults ..and save changes with F10 ...
In this point you know for sure that your USB ports are enabled...Than run the driver for the mouse from the disk that came with it ...Usually it will be an Usb 2.0 driver too ..but if you have at least the windows XP on it ..this is already installed from the operation system ....
if all that are made..the only thing that remain to check and concentrate on is the pairing of the receiver and the mouse itself...just press that button ..and let them pair again ...
Posted on Jul 17, 2010
HP cq57-229wm laptop keyboard/mouse "taps" not working
The drivers for your keyboard and mouse may be corrupt. Try using a USB or Wireless set to navigate with your computer. Go to HP and find your computer. Support/Drivers download. Get the current software fix and establish usage of the devices on your laptop once again.
Jan 03, 2014 | Computers & Internet
How to connect to laptop
Using a wireless mouse with a laptop is a convenient way to avoid using the laptop's built in mouse.
Moreover, even if you use an external mouse, carrying a wireless mouse is easier than the wired version.
Here is how to use a wireless mouse with a laptop.
Ensure that your laptop is compatible with a wireless mouse.
Most wireless mice use Bluetooth technology.
Any Bluetooth enabled laptop can connect to a Bluetooth wireless mouse.
Unpack your mouse and insert batteries to the battery chamber.
While doing so, make sure that the positive side of the battery is inserted into the positive niche in the compartment.
Place the mouse in a way that makes it easy for you to use and less stressful for your fingers.
Use a wireless receiver if your laptop does not have an built in wireless receiver (either Bluetooth or 802.11b).
It should be kept at least eight inches away from the laptop or any other object that would cause any interference.
Insert the drivers, if any, for the mouse to function properly.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop.
If you do not have any free USB ports, simply use an external USB hub for more ports.
Apr 20, 2013 | HP Wireless Optical Mouse
Hp wireless keyboard not working
exact key board driver install then try
what keyboard model?
download load driver for keyboard
update keyboard driver
May 16, 2012 | HP Computers & Internet
Where is switch for HP Pavillion laptop wireless
it must be in front of your laptop, try to look closely this is a sliding switch
Jan 08, 2010 | HP Pavilion dv4275nr PC Notebook
How do I turn on my HP Pavillion dv4 laptop wireless router? There is no wireless button on the front/sides/top. It says you need to press a combinationof function keys. What is that combination?!!
(10) Wireless button Turns the wireless feature on or off, but does not create
a wireless connection.
NOTE: A wireless network must be set up in order to
establish a wireless connection.
Nov 29, 2009 | HP Pavilion dv7-1132nr Notebook PC
HP Pavillion ze4400 can this laptop use an external mouse & keyboard ?
Any external USB mouse can be connected to the system. As well as USB keyboard. Or specifically if you go through HP, the mouse part number is: NR152AA, and keyboard is GM321AA. As far as non-HP products you will need to check on compatibility on each. Hope this helps you in this question.
Jul 29, 2009 | Computers & Internet
Wireless mouse intermittent
try going into your control panel, go mouse/ settings change your mouse settings and get some air for computers clean everything on the mouse
May 18, 2017 | HP Wireless Optical Mouse
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
