Question about Bazooka RS104 Car Subwoofer
I have an MTX1000xd and two Bazooka RS104DV's what wiring config?
I have an MTX1000xd and two Bazooka RS104DV what is the best wiring configuration, series or parallel. Also which will give me the highest output?
    Genius:
  • 1,340 Answers
Parallel will give you higher output but if you're hooking up all 3 you better use some very thick wire.Are you hooking these up to amp(s)?Sounds like a fuse is going to blow eventually too.
Good luck bro'!
Posted on Jul 26, 2010
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
My cisco 4503 keeps losing it's configuration file.. any ideas why this is happening? thx.
The case gives me hints towards the configuration register value which is not set to proper value, so the switch is not checking the the saved configuration in the config file.
Please do the below steps.
1. Log into the switch
2. Come to enable prompt
3. Typein the below commands
config t
end
write memory
The find an example of the prompt and the commands below
Switch# config t
Enter configuration commands, one per line. End with CNTRL/Z.
Switch(config)#config-register 0x2142
Switch(config)#end
Switch#write memory
After this you can configure your switch as per your requirement and then save the config by typing write memory
Now you can reboot your switch and the switch will come up with the configuration as you set.
Best Regards
Nov 06, 2010 | Cisco Catalyst 4503 (WS-C4503) 12x1000...
How to counfugre asa 5505 cisco Router
Use the Cisco ASDM or SDM software, that will give you an easy graphical interface to configure the ASA. One of them would have been shipped with the device.
Don't forget the ASA has to pre-configured, just a simple config. Have HTTPS enabled and telnet/SSH helps as well if you dont have a serial port or the console cable.
Cisco's website will give you quite a lot of info for free...
Jan 18, 2010 | Cisco ASA 5505 Firewall
I wanted to configure a system suitable for flight simulator so what can be the better config..
just read minimum configuration for that game, and you build it for required configuration, or above that. ( i will go above) i dip pends how much money you are willing to spend. I am right now of making configuration for my little brother, and i am thinking to go with dual core - for processor ( intel will be the choice above 2.8 ghz) 4 ddr 2 g ram, and some graphic of 512 mb ram... nvidia or ati... still got to do more research. Tell me how much money you are willing to spend and i will make you best config....
Apr 30, 2009 | Microsoft Flight Simulator X for Windows
Bazooka auto amp
remote wire is the blue wire maybe has white stripe that runs into stereo run from there to remote on amp as far as bass knob remote its common 1/4 stereo jack or a phono plug (looks like a phone jack)
Apr 19, 2009 | Bazooka ELA500.1 Car Audio Amplifier
Red Led Light on My Bazooka Ela300.1
Your amp went into a " Protection Mode "
this happens if you have blown something inside like a IC or something... if the amp have been dropped or bumped then its very likely to happen ... Check and see if your fuses are ok, if not then it would be best to let it be checked by a expert if its a IC or a cap inside
Cheers
Dec 18, 2007 | Bazooka ELA300.1 Car Audio Amplifier
What up with my subwoofer?
Sometimes the Bazooka tubes have an internal amp. I am not sure of this model but maybe you can Splice in directly to the Speaker Wire and bypass the AMP in the Tube if it has one
Feb 06, 2007 | Bazooka BT6014 Car Subwoofer
Bazooka RS104 Car Subwoofer Logo
168 people viewed this question
Top Bazooka Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
rd2xpld
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
