Question about Acer Aspire 3680 Laptop
Networking my 2 computers is connected in router, one is connected properly on net.. another one is connected but i cannot browse the site.. i dont understand why.. im using asus RX3041. can u tell me what will i do with these.. both xp. thanks
  • 4 Answers
Perhaps more details??
Posted on May 09, 2008
Internet not working
Make sure the router is set to DHCP to avoid any IP conflicts. This may be caused by connecting a switch before the router and blocking the routing table.
Jun 11, 2013 | D-Link Computers & Internet
Where can I find my WPE or WPA passphrase to hook up my roku thru my cisco
using internet explorer browse to http://192.168.1.1
if u dont remember the default login it is blank and the password is admin
go to wireless button and click on wireless security.
the passphase will be display there if u have it setup as WEP or WPA.
Mar 28, 2011 | Cisco - Linksys Wireless-n Home Router -...
I can not browse: http//192.168.10.1
Most routers have a default address on a local network of 192.168.1.1. Try connecting to that first.
Sep 21, 2010 | Trendware TRENDnet TEW-432BRP Cable/DSL...
I've a problem with using the WLAN with nokia
This may be a problem with your router. Routers have a feature where you can control which computers can access the network using their physical address. This is called the Media Access Control (MAC) address. Every wireless card and network card in the world has their own unique address and is represented in hexadecimal format.
You'll need to notify your router of your phone's MAC address. On my netgear router, I access the router through a browser on a computer connected to it by typing www.routerlogin.net (i think... it varies with different routers) or the gateway ip address e.g. 192.168.1.1. Find the option for MAC address management, in my netgear it's called Access Control (i think) and there should also be an option to add MAC addresses. Add in your phone's mac address and try again.
Your phone's MAC address should be located on the box it came in or under the battery of the phone. The MAC address is in the format 00:A1:B2:C3:D4:E5:F6:7A.
Good luck
Feb 17, 2010 | Nokia 5800 XpressMusic Smartphone
Unable to connect with dlink300 router
You must configure first its settings both on your network card and router. See you manual.
First you must connect your internet directly to the computer then get its DNS settings, jot it down. Then connect the router lanport1 to lan card port of your computer using LAN cable. Under lan properties goto TCP/IP settings input the default IPaddress 192.168.0.1 of the router then its subnet mask commonly 255.255.255.0, the router's default gateway, input the DNS settings of your ISP 2 of the set.
Then goto default router's utility web. Open internet explorer, key in router's ip add 192.168.0.1 you should go to router's configuration log in user = admin, pass = just hit enter. Set your time and date then save. You could also test its connection by pinging the IP address of router. on windows DOS. Type ping 192.168.0.1 you should get 4 lines.
If everything is set. Connect the internet cable(UTP/LAN cable) to its WAN port of the router then test to browse the internet. If not then change the DNS settings with the remaining set (on Lan setting).
If I miss something just leave a comment.
May 22, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Modem and d link
Hello there,
Your internet connection should be setup properly in order for the router to give connectivity to both your computer.
You must contact your ISP and ask them for the IP's and put it in the router.
Apr 05, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Router not allowing connection to sites
Turn off the router's firewall or allow for exceptions. Most downloads and other software than browsing use additional ports that the firewall is not allowing to pass thru.
Oct 01, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
My Belkin Wireless G Plus MIMO Router has intermitint connection with the wired computer
the inter net light should blinks dont worry>
delete all teh temp cookies and files and clear history>and change the ether net cable
change the dns to global like
start-->control panel-->network conn-->right click on local area conn-->click on properties-->and highlight tcp/ip-->click on properties-->and select use the current following dns
type
DNS 1) 4.2.2.1
DNS 2) 4.2.2.2
click ok>and restart the pc and rate me solved if its help full thx
Oct 30, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Acer Aspire 3680 Laptop Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
