Question about John Deere Garden
We were wondering the torque on the head bolts on a Kohler motor for a lawn mower.
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly. These torques are from the Kohler Service manual for the
CV11-16,
CV460-465,
CV490-495
engine.
There are 5 bolts.... as you look at the bolts there should be 3 on the left side
Bolt 1 is the center (offset bolt)
Bolt 2 is upper right
Bolt 3 bottom left
Bolt 4 upper left
Bolt 5 lower right.
Torque them in the sequence above... to 15 Ft lbs. or 180 inch lbs
reset your torque wrench and then torque them to 30 Ft lbs or 360 inch lbs.
Rocker arms center nuts (called mounting screws) are first torqued to 55 inch lbs then to 100 inch lbs.
Then to set the valve lash you back off the set screw lock nut torque and set the valve lash to .003 - .005 final set screw lock nut torque is 65 inch lbs. Engine must be at TDC i.e piston all the way to the top to make the correct adjustments.
Thanks for using FixYa.
Kelly
Posted on Jul 17, 2010
  • Kelly
    Kelly Jul 17, 2010
    On the larger 4 bolt head engines the initial torque is 200 inch lbs with final torque being 370 inch lbs.
    Kelly
Cyl head torque 6.75 kohler
snugg it tight then give quarter turn to tork thats how lawn mower shops do it because its fast
Aug 28, 2014 | Garden
What is the head bolt torque specs for a Kohler Pro 25HP V-Twin engine?
Go here and look up your engine model
Owners Service Manuals
Here is a Manual for the Kohler Command Pro CV26
http://www.kohlerengines.com/onlinecatalog/pdf/24_690_02_EN.pdf
The picture shows the torques of the Kohler Command Pro
Aug 19, 2014 | Craftsman Garden
26hp kohler engine started smoking suddenly. still runs good.whaat would cause this problem.
Head gasket blown. This is a very common issue with these V twin Kohler engines. There is a kit you can order from Kohler that includes gaskets and new improved head bolts. Simple hand tools is all that is needed. You will need an inch pound torque wrench. Torque specs are included in the kit.
Jul 23, 2014 | Craftsman Garden
Why is my 2012 21hp sears 42" lawn tractor blowing smoke
If it is a V twin Kohler engine, you may have a blown head gasket. It is a common issue. Great engine but has this one issue. Kohler has a head gasket kit with improved head bolts. Torque specs are included. You will need a inch pound torque wrench and common hand tools.
Jun 14, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
What are the valve settings for a 20hp Kohler lawn mower engine?
I take it that this is a CV or CH type motor with hydraulic lifters. If so, then torque the bolts on the rocker arms to 100 inch lbs. Everything else should be correct.
Apr 27, 2010 | Garden
Riding mower engine loud and smoking.
take it to a reputable shop and have them check it over - courage engines had a problem when they first came out - the bolts in the cover plate were not torqued properly and when they come loose, the torque of the engine turning will crack the block - this should be a warranty condition if the block is cracked - just make sure the shop is a kohler warranty station
Aug 27, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
385 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
