Question about Oster 76076-010 Hair Trimmer
The hinge screws on my Oster 76 keep coming loose. I added a lock washer but that doesnt help either
  • jetace51 Jul 01, 2017
    I have fixed a number of these. The screws are simple 6-32 pan heads and the fact that there is clearance between the hinge mechanism mounting hole and screw allows the screws to work loose. I replaced the pan head screws with 6-32 X3/8 flat head screws. The flat head screws fill the void and eliminate the side play. Thus ending the problem of loosening screws.
  • 193 Answers
Is it the screws undoing or the brass inserts coming out of the body housing, if the screws are tight try leering the hinge away from the body if it pulls out then you will need a new body housing.
Posted on Sep 26, 2017
    Top Expert:
  • Oster Master
  • 16,912 Answers
Try some thread locker, loctite etc
Posted on Jul 01, 2017
5 Suggested Answers
SOURCE: oster 76
There can also be a problem with the switch, which can be gotten to by unscrewing the the 2 screws at the end of the clipper . . .you must then test (with the thing unplugged!!!!!!!!!) to see if the switch wires are good or if the switch is broken by flipping the switch and or the toggle and then checking the wires with an ohm meter (easily available from radio shack or ?? for under 10 bucks or any kid who's into electronics. If the switch is good, when its turned on resistance goes to 0, if bad th switch shoes infinite resistance on or off . . .
If it hums and the motor is turning, but the blades don't move you need to replace the gear and or lever . . see this diagram
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
Posted on Mar 11, 2008
  • 22 Answers
SOURCE: replacing a cord on an oster 76
Very simple task. The part is under $3. The schematic and parts list is located in the link.
http://www.clipperrepair.com/parts.htm?mid=106
Posted on Feb 02, 2009
SOURCE: Simple question: Are the Oster 76 2-speed, the
well the 76 and the golden a5 are almost the same the name plates are different and the 76 uses a toggle switch but the a5 uses a rocker switch. not sure about the crewmaster sorry.
Posted on Sep 27, 2010
SOURCE: my oster 76 clippers will kick out the two screws
do the screws undo or do the brass inserts pull out of the body housing which the retaining screws fit into.
if the screws undo put some thread lock on the threads.
if its the brass inserts you will need to replace the mainbody.
Posted on Nov 23, 2010
My oster 76 wont cut the hinge pops up everytime i turn it on i made sure the screws were on tight and still nothing Is there anything that needs to be replaced
If the hinge will pull up with your finger nails then it will need replacing. The hinge should be tight enough to hold the blade onto the clipper. Some models are fitted with a 'Latch' which should be pushed to release the blade if this is fitted and the release does not need to be pushed then a new latch needs to be fitted.
Mar 23, 2014 | Health & Beauty
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
My oster 76 clippers will kick out the two screws that hold the blade holder on
Jan 23, 2010 | Oster 76076-010 Hair Trimmer
One od the two blade holder screw grommets has come loose from the housing/case. Need to replace. Need parts diagram.
Oster has their own website. Also some areas even have a shop to take your oster too. You might be able to get the screw there or a new plate. For if it keeps coming loose then it might be stripped.
Jan 01, 2010 | Oster 76076-010 Hair Trimmer
Blade doesn't seem to seat properly - more of a gap - and is noisier. Trimmer "ploughs" thru a small amount of fur and then catches.
Oster clippers have two screws retaining the hinge assembly make sure that these are tight the can come loose, also check that the hinge assembly has not lifted away from the body of the clipper, there are two brass inserts which the hinge assembly screws into, they part of the molding occasionally they can pull out causing bad vibrations and poor clipping.
If this is the case you will require a new main body which is a little more technical to replace.
Nov 28, 2009 | Oster Golden A5 2-Speed Universal Motor...
I took the blade off my oster golden clipper but cant get it back on. HELP!!
Open the hinge, do have a locking hinge push the lock upward and open the hinge, with finger.
Nov 03, 2009 | Oster 76076-010 Hair Trimmer
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
The shaving blades came loose and fell off my sunbeam shaver, how do i put them back on?
Make sure the clippers are running.
Make sure the hinge (the bit you put the blade on) is open, if it is not, prize it open with a flat head screwdriver.
With the hinge open and facing you, slide the blade on the hinge with the blade number/size facing you. Snap the hinge shut.
Jan 27, 2009 | Sunbeam Oster Blade 918-306 Size Texturing...
Where do you put the two little springs, and what do they do? My blades have started to rattle on clipper. Oster turbo clippers.
The springs probably go with the carbon brushes, to hold them in. To find the brushes, use a dime to unscrew the two circles on the side of the clippers.
The rattling could be from loose screws on the blade hinge. My turbo clippers did the same thing. The blades rattle if the screws are even slightly loose.
Nov 12, 2008 | Oster 76076-010 Hair Trimmer
Temp too high
lamgrimes9,
Welcome to Fizya.,
You said, your Oster wine refrig won't lower its temperature below 76 degrees. I have it for about 5 months, and it worked fine all this time with a setting of 50 degrees. Now it refuses to lower its temp. It reverts back to 76 everytime. Can someone give me any ideas about what is wrong? FYI Mine did not come with an owner's manual.
Sounds like the Thermostat is bad.
http://www.oster.com/CustService.aspx?content=manual
The tel # in your Oster Manual is a recording and will not help you!
But New appliances are under Factory warranty and are fixed or replaced no cost to the customer!you are under
http://www.oster.com/CustService.aspx?content=center
Let me know how it goes.
Huuum
Please leave a rating.
Oct 05, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster 76076-010 Hair Trimmer Logo
1,631 people viewed this question
Top Oster Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Chuck
Mohamed Ismail
Mohamed Ismail
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
