Question about Gateway ML6720 ML6721 ML6725 Keyboard V030946FS1
Need help removing and replacing keyboard on gateway ml6720 laptop. Removed to plastic piece above the keyboard and expected my solutions to be obvious, but they are not.
    President:
  • 567 Answers
Hi there you need to remove the screws that keep the keyboard in place, look at the bottom of the laptop for two screws you they should have a keyboard symbol to identify them.
Posted on Jul 17, 2010
  • Hilton Bristol Jul 17, 2010
    I am please to know the problem is solved
Can the gateway ml6720 realtek lan driver be used with the Ml6721?
Probably yes, I would go directly to the Realtek site and download it direct from the source. Use the newest driver.
Jun 04, 2014 | Gateway ML6720 ML6721 ML6725 Keyboard...
I am attempting to replace the Samsung rf510 keyboard. How do I remove the existing keyboard o replace it with the new one. As can be seen from the video, I have removed almost everything already
To remove this the fasteners are on the top. that pad above the numbers where your speakers probably are comes off. under that is three or four screws holding the keypad down.
Oct 11, 2012 | Computers & Internet
Need to remove a keyboard from a Fujitsu model N6110 laptop to clean it from spilled wine. Which screws on back need to be unscrewed to allow this? And are there any catches on the front to remove?
remove-keyboard-fujitsu-laptop-800x800.jpg Remove the Keyboard on a Fujitsu Laptop
Fujitsu makes several series of laptops, with multiple models in each series. Some Fujitsu keyboards are attached with only a few tabs and can be removed with little hassle, but other laptops require more steps to remove the keyboards.
Difficulty:Moderate Instructions Things You'll Need
  • Flat, hard piece of plastic
  • 1Prepare a clean and organized workspace.
  • 2Turn the laptop off. Turn the laptop over and slide the battery switch to pop out the battery.
  • 3Turn the laptop back over and remove the keyboard bezel, the thin piece of plastic directly above the keyboard, by prying it up with a small flat object, such as a hard piece of thin plastic.
  • 4Lift up the keyboard and flip it over to rest on the mouse/palm rest.
  • 5Disconnect the motherboard connection by carefully pulling down on the two tabs on either side of the connector. After the connection is unlocked, gently pull the cable to disconnect it.
  • 6Remove the keyboard.
Tips & Warnings
  • Discharge any static electricity by touching a metallic surface before working with your computer, to avoid damaging sensitive circuits.
May 20, 2011 | Fujitsu Siemens LifeBook N6110 Notebook
How do i remove the keyboard on a toshiba M55-S3314 laptop?
You will need to use a pocket knife, or flat object to pry up and remove the plastic strip above the keyboard first. I'm pretty sure it is held in place by pressure only, no screws yet (see NOTE below). Once this piece is removed, it exposes two screws that hold the keyboard in place. Remove these screws, and you should be able to lift the keyboard from the laptop. Be careful, as the keyboard is still connected to the motherboard by a ribbon cable that needs to be disconnected. Once you release this cable from the motherboard, you should be clear to separate the keyboard from the Toshiba.
NOTE, if you are having trouble removing the plastic strip from above the keyboard, flip the laptop over and remove the battery. Look for any screws that may be holding it in place and remove those first.
Jul 21, 2010 | Toshiba Satellite M55-S3314 Laptop
I ordered a new keyboard for my laptop gateway 7626gx how do I install it to replace the old one?
Not sure about your particular machine, but MOST of the laptops have a few screws from the bottom securing the little filler panel between the keyboard and the LCD screen. When removing screws be CAREFUL to note the length as they often have varying lengths and you don't want to put wrong length in any place. Sometimes the panels snap into place with plastic tabs and a gentle pry is needed. Above some of the keyboards one will find a couple indents for placing a screwdriver to gently pry the latches undone.
Once the filler is removed, there often ia a couple of screws retaining the keyboard by small tabs. After that there will be a very TENDER ribbon like cable which must be unplugged. Sometimes the connector has a little plastic thing to slide to unlock it.
replacing consists of reversing the order.
Feb 10, 2010 | Gateway 7426GX Notebook
Im trying to replace the dc jack on a gateway mx6930. I need help removing the case to get at this. You know I removed all visable screws from the case, started prying, and stoped as not to break anything....
yes you need to pull ALL parts HDD, dvd drive,....
then turn it over and pry loos the cover above the keyboard you should then be able to remove the keyboard
Jun 08, 2009 | Gateway MX6931 Notebook
Gateway CX2620 Swivel Screen Laptop
This is the worst solution I've ever heard. This guy is trying to steer you wrong I'm pretty sure. There is zero point in removing all the screws from under the batter/ zero point to removing the area around the power button. Absolute BS. The only part to remove is the part just above the top of the keyboard (silver strip with some black). Then by removing that you can pry the swivel black plastic cover off. Whatever you do.. do not follow Scott's writeup here. I'm telling you. It's sad it's stayed up so long.. so had to warn.
Dec 10, 2008 | Gateway Convertible CX2620 Notebook
I'm upgrading Ram Compaq R3200 laptop
Found my solution. Was under keyboard. Required opening laptop as far as possible, removing 3 screws from the back that hold the piece of plastic just above the keyboard. With flathead screwdriver lift the right corner of the plastic piece then, with the same screwdriver lift the top center of the plastic piece to remove the piece entirely. Unscrew the 4 screws that hold the keyboard (across the top) and lay they keyboard forward (toward you). THERE is the Ram.
May 22, 2008 | HP Pavilion ZV5000 ZX5000 Compaq R3000t...
Gateway ML6720 ML6721 ML6725 Keyboard V030946FS1 Logo
151 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
