Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Changed lamp and TV won't turn on, power light flashes 3 times
Just changed the lamp yesterday on the Sony WEGA KV-27HS420 HD TV, worked immediately after change, then wouldn't turn on the next day. Adjusted some cords, came on for about 1 hr, then went out again. Power light is red and flashes 3 times, no response now.
  • 10,594 Answers
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Posted on Jul 17, 2010
  • Shahid Electronics
    Shahid Electronics Jul 17, 2010
    Wait, is it Sony KV-27HS420 tv or any other model?
    KV-27HS420 is CRT tv that does not have any lamp inside. KDF-42WE655 is dlp tv that has lamp.
I have a sony trinitron 35" television model kv-32FS100 chasis BA50. When the television is turned off it takes 2 to 3 weeks to power back on. there is a red light that blinks and stops. what can i do...
there could be 2 issues with your TV one is the lamp and the other one is thew power supply board or if you have a click sound in the back is going to be a ballast issue.
May 17, 2014 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony KV-30HS420 stand by light flashes red 7 times
this is a lamp issue please replace the lamp this always happen and best thing is you don't' need a technician to help you yo can do it by your own
Mar 04, 2013 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Problem with the Sony FD Trinitron WEGA KV-27HS420 27" TV WHEN TV IS TURNED ON IT SHUTS itself off in a second or two and a light on front blinks 6 times.
Most of the time this is caused by two ic chips on the circuit board, ic8001 and ic8002. These are components that can be replaced fairly reasonably. If you call a repairman it should cost 95-165 us dollars. However, this is just an educated guess. Good luck, Russmann.
Apr 29, 2011 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
WHEN TV IS TURNED ON IT IMMEDIATELY SHUTS ITSELF OFF. THERE IS A RED LIGHT FLASHING IN THE FRONT RIGHT CORNER BOTTON
The light is hte standby light and it should be blinking a repeating count. That count will indicate the defective circuit. Please post the count and confirm your model to be KV-27HS420 and we can look up the code and provide the probable repair solution.
Thanks,
Dan
Mar 02, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony BRAVIA 32 inch
I had the same problem with a old Sony TV.
To find out if the problem is temporary
  1. Turn off the television.
IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
If the light is still flashing the tv has stop working and you will need to buy a new one.
Dec 08, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
Follow the instructions from the image provide and see if that works, if it does not work; you have a hardware failure in your TV. The hardware failure could be the HOT or flyback transformer.
Let me know if you need further assistance.
Aug 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
668 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
