Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a 14.5hp craftsman lawn tractor, model 917270514 that is VERY difficult to shift in or out of gear. This mower is about 11yrs old.I can't locate a plug of any type to check the fluid level in the rearend, transmission. Vince
    Scholar:
  • 110 Answers
Assuming you have a MANUAL (IE non-hydro) transmission ....
Can you shift with the engine OFF? If so, the problem is a dragging dirve belt transmitting power even though the clutch pedal is depressed. Check the adjustment, and that you have FULL travel on the pedal.
If you CAN'T shift with the engine off, then either the linkage is jammed/stiff, or there's an internal trans fault.
If you DO have a hydro trans, disconnect the linkage at the trans and attempt to move the lever on the side of the trans with vise-grips or similar. If you can move it without much effort, the linkage is siezed, if not, then internal trans fault.
Posted on Jul 17, 2010
Testimonial: "Thanks for the info. I thought it might be in the trans. but I was hoping there was a way to check the fluid. I can't find a plug or filler cap. And no, I don't have the manual. Vince"
I have the same mower. A bunch of these transmissions seize up and rather than tear down the transmission I drilled a small hole in the transmission case and installed a self tapping screw to reseal it. I put as much gear lube in it as I could get it to hold. I have heard of other people installing a zert and filling the case with wheel bearing grease. I tilted it forward and worked the shifting lever back and forth many times until it started to loosen a bit. I have been using it for the past three years with no problems.
Posted on Dec 03, 2011
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
Craftsman lawn tractor won't shift into gear
have you removed a rear tire recently? If so, you may have pushed the square key that locks the rim to the axle out
May 20, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gear shift lever is loose and mower will not move. this is on a craftsman lt1000.
Trace back the linkage from the shift lever to the transaxle to see if the linkage has come apart. If it is a manual, then I know the linkage connects to the transaxle on the top, forward, left of center. There is a retaining bolt (i think bolt, been a long time) that attaches the linkage to the transaxle. If this has backed out very much the linkage is not going to shift gears on the transaxle.
I hope this helps.
Jul 28, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower stuck in 3rd gear
you have a broken shifting fork in the transaxle, i know this, i just replaced one on a mower that was stuck in third gear...
Apr 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lt1000 rider 42 in deck is stuck in gear and wont go into neutral. so i cant get it started.
this happens when lawnmower is cut off in gear try this mash clutch and shake mower forward and backwards while trying to shift into neutral
Sep 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Tractor will not go in forward gear, only reverse.
Try rocking the mower forward and backward while you try to shift it.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
829 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
