Question about Canon PowerShot SX10 IS Digital Camera
LMy camera says it has a "Lense Error" and shuts off.
Lense error
    President:
  • 1,382 Answers
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Posted on Jul 17, 2010
When you turn the camera on the lense opens and the camera shuts off with the lense still open. I turn on again and the lense closes and then shuts off.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 30, 2011 | Pentax Optio 60 Digital Camera
Lense error, restart camera problem
If it's "lens error", then check your lens for damage or being jammed.
If it's "lense error", then I don't know what a lense is.
Dec 30, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My digital camera says lense error when I turn it on.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 15, 2010 | GE Cameras
My EX-S5 says lense error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 10, 2009 | Casio Exilim EX-S600 Digital Camera
Lense error
I had the same problem with my Nikon coolpix camera. Fortunately, I found a very strange solution from google.com :
"Hit the camera on the palm of your hand a few times (hit the side of the camera , not the lens). Try it slow at first, if it does not work try to hit it harder (but gently). "
I'm not sure if it will work with an Olympus camera and if this is a permanent solution ( a co-worker borrowed and lost my camera after a few months!!) . Also, there is a risk that you will permanently damage the camera. If your camera is under warrany send it for repair.
May 01, 2008 | Olympus Camedia C-730 Digital Camera
Lense error
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Aug 18, 2007 | Nikon COOLPIX S8 Digital Camera
Camera lense stuck in
Gear box problem ( not so expensive to repair ) or lens impacted ( this type of problem can be sorted out only by replacing the entire lens unit and is often uneconomical ).
Apr 23, 2007 | Vivitar ViviCam 5385 Digital Camera
Canon PowerShot SX10 IS Digital Camera Logo
184 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
