Question about Tomtom GO 720 GPS Receiver
Tomtom go720 What do I need to do to install tomtom go 720 on windows vista business. The driver software failed to install.
I uninstalled the software and started again, this time it worked well.
Posted on Apr 22, 2008
I have forgot my password on tomtom go720 how do
OK remove the Battery from inside, and look for a little "Hole" and push a ... say, a straightened Paper Clip and press it, hold for a second or so, & reassemble. You should be all good.
Feb 12, 2010 | Tomtom GO 720 GPS Receiver
My computer wont detect my tom tom go
go to tomtom's website and manually download their software. Save it to your HD and run it.
The program should automaticly load the correct drivers and will prompt you when to connect the GPS.
TAKE NOTE of how long you are allowed to get free map updates and make sure you do update the maps before that time expires.
also with my GO720 I skipped an update so instead of the update costing $49 they now want double that because my maps are 2 revisions old.
Dec 27, 2009 | Tomtom GO 720 GPS Receiver
I HAVE A TOM TOM GO 720 I SWITCH IT ON NO PROBLEM BUT WITHIN 30 SECONDS BATTERY WITH A YELLOW I IN A TRIANGLE COMES UP AND GOES OFF
The GO 720 charges quite slowly when attached to the in-vehicle cigarette lighter cord. If you have a USB attachment (that allows you to connect the GO720 to your computer) just insert the GO720 into the USB cradle - you don't have to turn it on - and let it sit there for about 10 hours. You should see the green light on the GO720 indicating that power is being received. In fact, I don't think you even need to turn on the computer, as power is always fed to the USB circuit. If you see the green light, then the GO720 is being charged. I think your GPS just needs a good charge.
Nov 22, 2009 | Tomtom GO 720 GPS Receiver
Error code with softward
Hi Guys,
If you are using tomtom home 1.5 and also have tomtom home 2.5 installed, you will need to remove one of the versions of home from your computer because both versions of home use the same folder tomtom that is stored in my documents.
If you are using the tomtom go720 device, uninstall tomtom home (without the number 2 at the end)
tomtom home 1.5 with the options menu on the left hand side is not needed for your device since it has been for PDA use only.
Hope this helps
Thanks,
Pabs
Dec 28, 2008 | Tomtom GO 720 GPS Receiver
Where do I find my promotion code for my tom tom go720
if you are refferring to the promotion code that appears in the tom tom home software that is no longer used it was to help with the map guarntee but that has been changed
Dec 26, 2008 | Tomtom GO 720 GPS Receiver
Tomtom stuttering
TomTom Home now has a fix which corrects the stuttering problems with the computer voice needed for the 'text to speech' function on the GO720. Simply plug your device into your computer and have it connect with your computer. You should automatically see a large fix available which will correct the problem. Download it as I did, and the problem is corrected.
Nov 30, 2008 | Tomtom GO 720 GPS Receiver
Tom tom go 720 product code
The Go720 do not use a product code, if the map are version 7xx
If the map you are trying to install is version 6xx, then you need to activate.
For references and How Ho, visit:
http://www.tomtom.com/support/index.php?Language=4&query=productcode&FID=2150
Apr 14, 2008 | Tomtom GO 700 GPS Receiver
Downloading Free Maps for TomTom GO 720
I want dowloading free maps for tom tom go 720
Apr 02, 2008 | Tomtom GO 720 GPS Receiver
Tomtom GO 720 GPS Receiver Logo
813 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
