Question about Dell OptiPlex GX110 PC Desktop
No boot avaible
Everytime I turn on my computer it goes to the black screen and says! No boot avaible. What can I do to fix it?
  • mactherebell Jul 17, 2010
    It says no boot device is avaible
  • Dell Master
  • 12,061 Answers
What has happened is the HDD has "Lost" it;s Boot track, for whatever reason.
Below are two websites that should help you recover your HDD if possible http://www.michaelstevenstech.com/XPrepairinstall.htm
http://smallvoid.com/article/no-boot-device-found.html
Below shows you how to use fixboot to try to repair your HDD boot track. It may be though, that the HDD has failed http://support.microsoft.com/kb/314058
Posted on Jul 17, 2010
  • 10,319 Answers
Initially Switch the computer on and keep pressing the F8 key until a repair screen shows up.
Start this in the safe mode and see if you get your screen back
Turns on but black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Oct 04, 2013 | MSI Wind U100-030US Laptop
Fix my laptop
Do you see the cursor blinking in the black screen?
Try booting to safe mode. Restart your computer and tap F8 until you see the options to boot to safe mode. Use the arrow keys to highlight safe mode and hit enter. Once you are inside safe mode, install RadarSync and scan your computer with it then update the outdated drivers.
David
Jul 06, 2013 | Sony VAIO Computers & Internet
My computer screen goes black whe i turn it on
It would be helpful if you posted the Make, Model and the OS you are using. Does it boot? Can you boot to Safe Mode? Have you checked ALL cables? Do you get anything on the screen? Fans spin? LED's Blink at boot? Sound? Need more info.
Mar 13, 2013 | Computers & Internet
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
Computer boots up and then goes to a black screen
Hi ,
Please follow these trobleshooting steps......
Turn the computer off and then disconnect any external devices connected and then when you turn the computer on or as son as you press the power button to turn the computer on start tapping the F8 key repeatedly until you get a black screen that says advance boot menu option .Then used the arrow keys on the keyboard and then hit enter,select the operating system and then when you get the log on screen select administrator .If it takes you to the desktop then you can try doing a restore by going to start ?all programs ?accessories?system tools and then system restore ? select the date when you think that you r computer was working fine and then click on next next to exit from the wizard.Should fix the issue .
If the computer does not boot up to the desktop then without wasting time on any trobleshooting steps recovery needs to be done that takes the computer back to its original factory settings.To do this instead of the f8 key tap the f11 key till you get the screen that says system recovery ,click next until you get the screen that has advance option ,click on it ?select destructive recovery ?click next the recovery will start and the computer will be formated (whatever you have added after you bought the computer would be lost ).If the recovery does not work this was then it needs to be done from the recovery disks and fot that you call call HP...
ALL THE BEST
May 15, 2010 | Computers & Internet
Upgraded to win 7 now princeton monitor goes black how do i fix
try this, but a bit tricky.
start off with the pc off
then turn it on
wait till the bios etc splash screen show past the hit del or f2 to goi to setup then after that press f8 repeatedly until it shows some sort of list
this is the alternate boot up just scroll down to ENABLE VGA MODE
after selecting that it will boot up with your screen..
hope that works
Nov 10, 2009 | Computers & Internet
I get a black screen with the mouse everytime i boot to windows
Is it black all the time? From when you start your computer to when you turn it off?
Sounds like the backlight is bad.
Aug 07, 2009 | Dell Inspiron 1720 17" Widescreen...
Randomly lost display on my pc.. and its not a faulty card.
Try to set your PCI-E card as a first one in BIOS. There also should be an option to turn off onboard video.
Mar 07, 2009 | Gateway GT4022 PC Desktop
Boot loader?
my phone now desaper all menu
Oct 10, 2008 | Motorola Mobility V360 Cellular Phone
Screen goes to black after booting up
NO it may be you are have LCD problems try an external monitor if tht goes alrite that the latte is the problem.
Sep 24, 2007 | IBM ThinkPad T41p Notebook
Dell OptiPlex GX110 PC Desktop Logo
120 people viewed this question
Alun Cox
