Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Canon mpc side removal
How are the side panels removed?
MP390 black cartridge won't pring
Posted on May 23, 2008
How can I get the MPC Cleaner program removed from my computer?
Go to Programs and Features in your Control Panel. Click on Programs and Features. Look for the program you want to remove. Click on it and look at the top for the button to remove. Sometimes it'll pop up when you just click on the program. Click uninstall.
Jul 04, 2017 | Beyond Computers & Internet
Remove MPC 434, 424, 414 speakerbar panel? General disassembly procedure or instructions available?
The general procedure is to remove the panel/bar above the keyboard first. There are about 3 types. Look at the left and right edges of the panel and see if there is a screw. Remove it. Slide the panel about 1/8 the away from the screw and it should pop up. The second is to remove the screws from either the underside and/or the back of the system and then slide the panel up and out. Finally, if you have removed all screws, some systems are removed by prying up (gently) the hinge covers.
Mar 04, 2014 | Computers & Internet
How do I remove the front cover for an MPC Clientpro 365 tower so I can add another optical drive?
There should be two Aqua colored tabs on the back diectly under the side panel, press them both at the same time and swing the cover out and it should slide off. Install the optical drive and replace the cover back on...
I have one of these systems and they are easy to work with, relatively speaking!
Sep 08, 2011 | MPC Computers ClientPro 365 PC Desktop
To remove the recovery unit, open the upper right door & remove the developing unit. Be careful to unplug the toner sensor at the front frame. The plug will be damaged otherwise. From the front remove all the corona units. Slide out the fuser drawer. Remove the retainer screw & lock in the drum shaft. Slide out the imaging unit.
The recovery can now be removed.
Jan 20, 2011 | Canon imageRUNNER 5000 Copier
Canon LBP-2900 Printer Open top cover insert toner cartridge
It is very easy to open the printer.First you need to remove the screws at the back.Then slowly remove the white panels which is fixed at the left and right sides.You should be very careful doing so,because there is no screws instead of that only plastic locks.Then you can remove the top cover.The total plastic panel you can remove only removing the two screws.Best of luck
Dec 14, 2010 | Canon LASER SHOT LBP-2900 Printer
How do I remove the back of my MPC Transport T2000?
You have to first remove the hinge covers then remove the power strip where the power button is then remove the hinge screws then unplug the display from the motherboard turn the laptop over and remove all the screws there.Turn it back over remove the keyboard.Then remove both wireless card antenna wires that run up to the display.then lift the display off and lay it to the side.remove the cd drive.Then carefully pry apart the top from the bottom slowly and you should then be able to have access to the motherboard and other internal componants.
Aug 29, 2009 | MPC Computers TransPort T2000 Notebook
How to replace ram in clientPro 414
Back of computer near where keyboard and mouse plug in. Take panel off back, they are just below cooling fans! Please rate me!
Jul 06, 2009 | MPC Computers ClientPro 414 All-In-One PC...
How to reset the bios password on MPC transport x1000 laptop
the best way to remove a bios password is to have the bios reset by a program called "winternals" this can be done by any pc repair shop
Apr 05, 2009 | MPC Computers TransPort X1000 Notebook
Screen says waste ink near full
These are pads located directly below the cartridges while in it's resting position.These pads can be removed with tweezers and cleaned with any ink removing cleaner and then with warm water and soap,Dried and replaced.
Apr 05, 2009 | Canon Office Equipment & Supplies
Jammed ink cartridge
The last thing you want to do is try and rip it out and ruin the printer or even snap the plastic holster that holds the ink cartridge. Try to wiggle and tug while pushing upwards to ensure no damage to be done, if you cannot remove it its hard to tell you what to do.
If you cannot remove it, do not try to force it. Contact Canon Technical Support at:
If you need further help, let me know.
Jan 09, 2009 | Canon Multifunction MPC-370 Printer
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
46 people viewed this question
old marine
old marine
