Air conditioner sweats profusely into the room
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. If the condensation is running in instead of outside then the window unit is probably leveled the wrong way try and lean the unit toward the outside to get the water to run backwards toward the outside so the water can run back.
Posted on Jul 17, 2010
I sweat profusely! Can excessive sweating damage my Resound hearing aides
No they are waterproof to a certain extent. you could email the maker?
Feb 24, 2017 | Heating & Cooling
Amana 115vac60hz bucket full
the aircon unit sweats when it is cold, this sweat drips into a bucket. You must empty the bucket when it fills up. the unit tells you when it is full. 24823715-u40lsvyytnuesyuv3fbafhtd-3-0.jpg
ahh... sweating beer! empty the bucket.
Jul 14, 2014 | Frigidaire FAP094P1 Portable Air...
Sweating duct work and pipes
high humidity will cause sweating on cold lineset and ductwork,,, insulate both and it will solve problem
Jun 03, 2014 | Ruud Central System Air Conditioner
Unit not cooling inside below 72 degrees lines sweating
how hot is it outside??? 20 degree split is usually the norm ,,,,,outside 95 then inside will be 75,,,,,where is the line sweating ,,, it should sweat near outdoor unit
Jun 02, 2014 | Ruud Central System Air Conditioner
Thermostat on whirlpool window unit keeps resetting to 86. will not cool room.
Check if the compressor runs when you start your air-conditioner. If it runs, make sure the evaporator sweats and the condenser at the back blows hot air. If not, you have freon leak and check for oil marks inside your a/c unit.If the compressor does not start, check your compressor overload, capacitor, and use a clamp meter to determine if you have a defective compressor.
Sep 01, 2011 | Whirlpool Electronic Window Air...
Grill temprature not down
By grill you mean the air outlet?
If the large line going to the compressor is ice cold and the coil is not sweating profusely the compressor may have become inefficient which is not repairable.
Jul 29, 2010 | Hitachi Heating & Cooling
Not Cool
Measure room and calculate btu's
Formula Length times Width times Height Times Eighteen divde by Five.
Example: 12 x 15 x 9 x 18 / 5 = 5832 BTU's
Jun 03, 2010 | Panasonic CS-A12C Air Conditioner
Window Air Conditioner Sweats
You need to seal the portion of the air conditioner that is inside the window from the portion that is outside the window, Sweating is caused by moist outside air leaking in and contacting the cold portion of the air conditioner. Do not use duct tape, buy aluminum tape which is what professionals use to seal air leaks on ducts. Home Depot sells the tape. Buy the smallest quantity you can find that will do the job ( it can be expensive ) unless you plan to go into air conditioning duct installation.
For best results use some form of insulation over the accordian like side baffles ( cut to fit) . Styrafoam from packaging or silver backed insulboard (Home Depot). Now tape the sides of the insulation to all sides of the window frame, bottom of the window, the sill, and the air conditioner.
Unless you enjoy doing this every year - plan on this being a permanent installation. It is a tedious job because the aluminum tape is not very forgiving and has a peel off backing but it sticks forever.
May 08, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
