Question about Motorola Walkie Talkie 2-Way Radio
My cp100 is displaying f 32,and wont do anything
    President:
  • 567 Answers
Hi please give me some more information abuot your device because there are several device go as CP 100 so kindly explain the problem and device type. Thank you
Posted on Jul 17, 2010
  • 1 more comment
  • jeremymatt Jul 17, 2010
    my motorola CP 100 is not responding to anything when i turn it on, it reads r 11 and then it goes to F 32 on the screen none of the functions work I can hear the other radios but cant respond Ive tried to reset factory settings but it will not re set
    woops the motoraola is a CP 100 two way radio for construction use.
  • Hilton Bristol Jul 17, 2010
    The radio may have dust inside which affects it function and should be clean,you should get the radio check to see if dust is inside of it.
Welch Allyn CP200 startup screen fine, then 3 beeps and screen changes to coloured bars. Reset button makes no difference. I note that the battery is missing. Is that the fault?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
I do recall that I've seen details about this ECG machine by the above site, long ago. Search for it by type in the brand name 'Welch Allyn'; in the search box at the top right of the Display Window of that site.
Dec 01, 2014 | Welch Allyn Cp100 Cp200 Series Ecg Units...
Can the freq 156,600 be put in this radio if so how do i do it
No, 156.600 MHz is not one of the 27 VHF frequencies available in the CP100 VHF radio. (If by chance you have a typo and you meant to ask about the common frequency of 154.600 MHz, aka green dot, it is available in the CP100 VHF.)
Here is a link to a website with the user guide:
http://www.essnashville.com/CP100-operationsmanual-021407.pdf The frequency chart is on page 34. Programming instructions begin on page 20.
Best regards.
Best regards.
Feb 09, 2014 | Motorola Radius Cp100 Uhf 1ch Two Way...
Will motorola t6500's or t5300's work with cp100's?
No, the TalkAbout family radio service/GMRS radios and the CP100 business radio have no frequencies in common. Sorry.
best regards.
Jul 12, 2012 | Motorola Talkabout T6500 (7 Channels)...
A CP100 ECG. Replaced battery. Still won't turn
could be the charging circuit. You need to make sure the new battery is actually charging through the machine. You can use a volt meter to do this. If you need more assistance you can email me at wats@mesasales.com
Aug 03, 2009 | Medical
The audio on one radio is muffled. How can I fix it?
The problem is likely one of two things: 1) something is covering the speaker holes, or there is debris in the holes or 2) you have a bad speaker.
FYI: This radio is a repairable version of the TalkAbout closely related to the business model CP100. You can send it to a repair facility to have it repaired. (Typically around $69) You can google CP100 repair to find a Motorola shop capable of the repair, if needed.
May 22, 2009 | Motorola Walkie Talkies 2-Way Radio
Trying to link up cp100 to cp110 radio
I don't have enough information to fully help you, however, it would appear your CP100s have the interference eliminator code enabled and the CP110s do not. If you know how to reprogram the CP100, you can simply turn the code to zero. (The dealer who sold you the new radios should have gathered info regarding the programming of your existing units, then they would have matched out of the box.)
Mar 14, 2009 | Motorola Walkie Talkie 2-Way Radio
I need the IC-F11/S to talk to my CP100 (vhf) model
Programming the CP100:
http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Programming the IC-F11:
I believe one must purchase software and a programming cable to program the frequencies of this radio.
Mar 13, 2009 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Mode not supported
TV's usually have a maximum resolution of 1366x768.
if your resolution is higher than then when you connect to the TV, it won't be able to display anything.
Mar 13, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
How do I Reset my T5000 2 way radio to factory default
The T5000 Talkabout radio default settings are not the same as the CP100 and CLS. The CLS and the CP100 UHF are capable of being programmed to match one another on several frequencies, however, the TalkAbout T5000 is not capable of any of them.
The Talkabout radios, as a general rule, are limited to FRS and GMRS frequencies. The CP100 and CLS are from the business and light consumer divisions. They will do most of the common 56 UHF business frequencies.
If you would like to look at the frequency charts yourself, here are some links.
Here are the frequencies possible on the T5000 http://www.fixya.com/support/p514922-motorola_talkabout_t5000_2_way_radio/manual-362/page-17
Here is a link to the CLS radio manual
http://www.123radios.com/Manuals/clsmanual.pdf
Here is a link to a CP100 user manual
Jul 13, 2008 | Motorola TalkAbout T5000 2-Way Radio
Radio Communications Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
