Question about Kenmore Dryers
How can I determine if my ignitor has gone bad? I had a bad rainstorm and the exhaust vent / tube ingested about 1/4 of a gallon of water. It may have been more, but about 1/4 gallon is what I removed from the vent tubing. Dryer acts normal except no heat. Gas line is good, and active. I've got a VOM. Thanks - Don
  • 2 more comments
  • dfmcintyre Jul 23, 2010
    Salde -
    Got access to the bottom area this am. Cleaned out all the lint. Cleaned the window on a rectangular slot along the burner tube that has what looks like a little photocell.
    Unscrewed and removed the ignitor from the burner tube and bypassed the door switch. Turned the dryer on briefly on (10sec). The ignitor will get red hot. Turn off. No smell of gas.
    Repeated test with (what I'd call) the photocell shunted, negative results, no gas.
    Gas is good to the house for the grill and stove.
    What sort of reading should I get on the thermal switches, or should I just test by shunting them?
    Thanks - Don (gone for weekend mode)
  • dfmcintyre Jul 25, 2010
    Have both the three and two pronged coils off.
    According to the parts list that came with the dryer, the part numbers for the two terminal coil is PN 694540, and the three terminal one is PN 694539.
    Can a gas valve itself go bad?
    Thanks - Don
    Additional info...
    Is there a way to test each coil? According to one source, their about $30 ea.
    Thanks - Don
  • dfmcintyre Jul 31, 2010
    Salde -
    Ok, here's what I've tested; All three fuses and the flame sensor I get resistance with the meter. I unplugged the coil connectors and get AC from two of the three pins in the three pin one, and no AC in the two pin one.
    From the design of the coil bracket, it looks like when the coil(s) energize, the pins are pushed in? When I start the motor there is no movement either in or out from either pin that the coils surround.
    Unplugged the flame sensor, the ignitor stays off. Plug the sensor, ignitor glows, no movement from either or both coil.
    Slight correction, dryer was not underwater, i.e. not a flooded basement condition. No rust in motor or housing. I think about less then 1/4 gallon in the vent tubing. Lotta lint around the motor that got vac'ed.
    One more observation. Ran unit with coils off of the pins, and plugged in. Noticed that the 3 pin coil would energize and felt magnetic pull on screwdriver inserted into hole. Got pretty hot too. No pull or heat from the 2 pin coil.
    If the pin movement is in, should I be able to push the pins in manually?
    Thoughts?
  • Kenmore Master
  • 2,694 Answers
Pull the wire connector off and check for continuity,if you get a reading it's good if the 1 stays there on your meter it's bad,also check the sensor and the thermal fuse located on the blower wheel housing,hopefully it will be one of these,we had bad rain here in the boston area and most of the dryers i worked on after were bad motors but if your dryer starts that's a good sign,let me know how you make out
Posted on Jul 17, 2010
  • 4 more comments
  • Sal De Jul 23, 2010
    that's the sensor,if the ignitor is glowing the sensor is good,you either have bad gas coils or a bad gas valve,i'd change out the coils first 279834 is the part number for the coils,just take out the two phillips screws,remove the cover and change out the gas coils.let me know how you make out
  • Sal De Jul 25, 2010
    the part number i gave you is for both the coils,it comes as a kit and they will work in your dryer 279834.don't buy them separately.yes the gas valve could be bad,i've seen very few valves that go bad,try the coils,also with a meter read out the thermal fuse,pull one of the wires off and read it out,it's on the blower wheel housing,most likely it's a 3392519,it's white and long,or if it's the round fuse it probably is a 3390719,just put it on like 20k,touch the leads together to check the meter,if the number 1 stays there the part is bad,if you get any other reading the part is good,do the same with the ignitor,most likely these parts are good because the ignitor is glowing but check them anyway,if they are good change out the coils,a few times i tapped on the gas valve and the gas would come through for a few minutes you can try that too,also if you have a shop vac blow into the tube where the gas comes out or stick a paperclip in there,i actually found a spider web in there and the gas wouldn't come out,it blocked the orifice,hopefully it's just the coils they are like 30 bucks for both in that kit
    also this dryer was under water,anything could have plugged up the orifice where the gas comes out of the valve,could have rusted up.it's hard to figure out what part is good or bad with water damage,you can fix one thing and then something else can go right after that,if it is the valve take a good look at the dryer,check the motor,see how much rust is starting to show up,you might want to change out the dryer instead of sinking money into it and then something else goes wrong from the water damage,good luck,let me know how you make out,if you need more help let me know and send the model number
  • Sal De Jul 31, 2010
    stop touching the senor and the ignitor,if it's glowing then we know everything is working except for the gas coils or the gas valve,the coil part number is 279834,i helped someone else out and they got both the coils from sears with the number i gave you for 22 bucks,change out the coils,if that doesn't do it then you have a bad gas valve.
  • dfmcintyre Aug 20, 2010
    Salde -
    Sorry for the delay. Vacation, got back and installed the two new coils from Sears last weekend. That seemed to do the trick. Put back together and it runs fine. Thanks again for the help!
    Don
  • Sal De Aug 20, 2010
    fantastic!!! glad i could help
Have 75 gallon gas water heater. Can I run 90 PVC off top power vent without vertical PVC first? Have Richmond unit.
1) I believe you can immediately elbow the PVC pipe.
There is a limit for how many elbows can be used between blower and termination, and limit is determined by diameter of PVC pipe.
2) Copy following link for venting resources and typical Rheem and Richmond power vent manuals, and diameter-elbow pdf from Bradford White.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#venting
3) Richmond is Rheem. Product manual will show specifications for venting.
Product warranty is voided if installation does not follow specifications shown in manual.
Feb 20, 2013 | Rheem Richmond 75 Gal Natural Gas 6 Year...
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Size of the exhaust vent pipe on a 75 gallon gas water heater? Is it the same size as on a 50 gallon water heater. Brand is GE, mfg 2008
I believe it takes 4" vent pipe up to 100,000 BTU
BTUs are shown on label side of tank.
http://waterheatertimer.org/pdf/Gas-venting-specs.pdf
Does new water heater have power vent? What does manual say?
Are you experiencing vent problem now? When you light a match and put it under vent stack, does smoke immediately get pulled upward? Are furnace and waster heater connected to same venting. Is there dark exhaust stain around vent hood? Does exhaust vent back out of vent hood when furnace kicks on? Are flue pipes stained with rust and white coating? Are vent pipes vertical, or are there level runs? Are the pipes made of galvanized and screwed together with 3 screws at each joint?
Frankly I would double-triple-check any internet answer dealing with possible CO poisoning at your home.
1) Ask local plumber for specific code in your area.
2) Call gas company
3) Post question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
4) Read whole manual for new water heater before buying.
5) Contact manufacturer.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 30, 2011 | Water Heaters
I have a 2 year old rheem power vent water heater model # 42vp50fw. It suddenly stopped working. It will try to ignite. The igniter will glow and the call for gas will ignite the burner. After a few...
The flame sensor is bad....and it is not sensing that the flame has lit....
Some models have a separate flame sensor and some use the ignitor to sense the flame...
If it has a separate sensor then clean it with a soft cloth... if it is the ignitor then the ignitor is bad...
heatman101
Nov 25, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
DRYER DOES NOT GET HOT
Check for a blockage in the exhaust vent tubing. A moister sensor detects lint build up and prevents the burner to work
If clear and still no heat check the spark ignitor to click once you turn on the unit. If it does click the ignitor is good. Still not heat? Then the moister sensor is at fault
May 23, 2010 | Estate TGDX640JQ Gas Dryer
I have a large capacity Kenmore dryer that is not heating up what should I look for model #75201
A clogged exhaust vent tubing will collect lint causing the moister sensor to shut down the heat. Inspect & clean and it will operate again. If not the sensor is bad or the spark ignitor is at fault. The spark ignitor makes a clicking sound upon starting the dryer up within 20 seconds
May 01, 2010 | Dryers
Isn't heating up. takes forever to dry,
Disconnect the complete exhaust vent tubing and clean it out thorourghly. Then it will dry. There is a moister sensor in your dryer and when the lint builds up inside the vent tubing the sensor shuts off the burner to prevent fires from starting
Apr 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Loud blower on my new Rheem Power Vent 2 water heater
find out if it does the same noise with the venting disconnected
Nov 01, 2009 | Fasco Bradford White Hot Water Heater...
We have a dayton gas furnace model #3E463A. thought the control box was gone. got new one we furnace starts up the power goes on, fan starts no green pulsing light on control no ignition
When your furnace starts...the Ventor motor(exhaust fan) starts up....within a short time (seconds) the Pressure switch closes proving that the Fan is indeed running and the vent is not blocked...if this doesnt happen the furnace will not poweer the ignitor or fire at all....Check the vent pipe outside and look for obstructions or dirt on the screen inside the pipe...the condensate from the fuirnace may not be draining at all...due to plugged condensate drain lines...find this tube coming out of the furnace front...bottom of upper compartment usually , and pull it off the tap....if water starts coming out then your drain is plugged downstream of the furnace.
Oct 25, 2009 | Dayton Gas Furnace Heater
A lot of moisture in the exhaust line of dryer...
thats easy the moisture from your clothes ,,and the outside air,,where ever you live its a lot of moisture in the air,,now the cold air from outside is coming back in dryer and the hot moist air is trying to get out,,bingo condensation,,in your dryer exhaust vent tube ,,hince all the water,,,,now to fix that ,,we need to dump all the water from vent exhaust tube ,,you may need a new one because it will mostly rot...and check the flap or put a window exhaust kit on the house or window,,to stop air flow from coming back in the dryer ,,and where done..onthejob
Jan 28, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Dryers Logo
141 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
