Question about Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan
REMOVAL FROM CEILING - Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan
    Problem Solver:
  • 10 Answers
In general, the steps are:
1. Turn off power at the breaker -- not just the light switch.
(There are still "hot" wires in the junction box when "Off".)
2. Take out any light bulbs.
3. Remove any light globes. Some screw in, but most are held by springs so just pull gently with a bit of force.
4. Remove fan blades. Most have a spring at the inside edge of the blade -- press down on the spring and push the blade toward the fan motor.
5. Remove the ceiling mount cover. There is usually a circular ring up next to the ceiling; just twist it off with your hands ("lefty - loosy, righty-tighty").
6. Unscrew the ceiling mount screws. Usually there is one or two in a "simple" hole, and two one "sliding" slots. Take out the "simple" screws, and loosen (but don't remove) the "sliding" screws. Be careful not to drop screws or washers into the fan motor.
7. Twist off the ceiling mount cover to expose the wiring.
8. Disconnect all wires. For safety, put a wire nut on the wires from the ceiling.
9. Tip the fan and remove it from the ceiling mount. Keep in mind that the fan is pretty heavy, and you're on a ladder!
NOTE: Be careful not to put any pressure on any of the blade holders, especially if you intend to re-use the fan. If you do, the blades will wobble.
10. If you're installing a new fan, you can probably re-use the mount. If you want to put up a simple light fixture, remove the mount by unscrewing the two long screws holding it to the junction box.
Posted on Aug 15, 2010
Having trouble taking down the fan have removed the light and the blades cannot get the motor assembly down
Don't know which brand ceiling fab you have, but almost all mount the same way. You have completed most of what needs to be done. So, now you need to remove the ceiling cowl, that slides up and down on the down rod. There should be 2-3 screws in the top outer edge of the cowl. If you remove those, the cowl will slide down the rod. After that, unscrew the wiring nuts, that connect the fan's wiring to the house wiring. Don't forget to disconnect the copper ground wire, too. Then the ball on the end of the down rod shaft can be lifted out of the ceiling bracket.
MOST IMPORTANTLY, DO NOT ATTEMPT TO DISCONNECT ANY WIRES UNTIL THE CIRCUIT BREAKER FOR THAT CEILING OUTLET IS TURNED OFF. DON'T JUST RELY ON THE WALL SWITCH BEING OFF.
Hope this helped you in the removal of the ceiling fan. Please let me know. Thanks.
May 23, 2011 | Heating & Cooling
Water is leaking from the inside.
This is the solution to a the same problem in a Westinghouse Freestyle refrigerator which is probably similar in principle. Basically the internal drainage system from the freezer is blocked. Open the fridge door, locate the dial which moderates the temperature located on the 'ceiling' of the fridge. Remove the light cover, remove the globe. Unscrew the two screws which hold the dial housing to the ceiling of the fridge, let this housing hang from the ceiling in the wires. This will expose a red funnel shaped tray, gently lift the tray and pull it out, you will most likely find the tray drain is blocked with gunk, clean and reinstall. Assembly is reverse of removal.
Jan 08, 2011 | Haier Refrigerators
How do you fix seal leak on dometic rooftop air conditioner ?
remove filter etc. from ceiling assy, you'll see 4 bolts that you remove,(basically 4 corners of lower tray at ceiling) unplug wiring harness and connector, that goes to upper unit from lower, then lift upper unit up off roof. position upper unit to allow for removal of 14" gasket. Install new gasket, set upper unit back over hole align properly, and re-install 4 bolts. Snug evenly until gasket is approx. half thickness of original. Re-attach harness plug etc.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
Trying to remove cover that houses the ball and pipe that hangs the fan. There is no screw to hold the ceiling mount cover to the ceiling mount. I tried pushing up and twisting but no luck. Could someone...
There should be a couple of small screws at the very top on the side of the canopy...you will need to loosen these a few turns and then turn the canopy and drop it down...
This link will help you they had the same problem as you...
http://www.askmehelpdesk.com/electrical-lighting/hampton-bay-ceiling-fan-removal-25673.html
heatman101
Apr 29, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
I have a westinghouse freestyle fridge and it is leaking water seem to be coming from behind the tempreature adjusting knob. Do you have any suggestions. Thanks Michael model RJ452T-R
Nov 03, 2009 | Westinghouse Refrigerators
Removing the ceiling mount from the ceiling of a hampton ceiling
Sometimes there is a small trim piece where the canopy meets the ceiling that "snaps" into place and rather than turning to unlock it needs to be gently pryed off. If you have a small trim piece that makes more than about 1/8 of a turn without unlocking. that is definately what you have.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jerry_612d8419f8984578
Sep 06, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan Logo
136 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
