Question about Pioneer PDP-4270XD 42 in. HD-Ready Plasma Television
I replaced the 2 STK392-110 convergence amps with STK392-180s, and the repair looked good after it was complete. But 4 days later, after several hrs. of the unit being powered on, the convergence went out again. What else could I have missed? What is possibly related to a heat problem? Do I have to replace the STKs again?
  • Pioneer Master
  • 12,061 Answers
Hi, well I applaud you for wanting to have a go, but you must make sure that you are starting in the right place, That is The Power Supply, as, if, that isn't right nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. That’s it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then that’s a prime cause of failure. Resistors, hardly ever go faulty, and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be able to say.. "Oh that’s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish, a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. The Tools you will need are A SERVICE MANUAL a Good Multimeter, a Signal generator, a Signal Tracer, pref an Oscilloscope, Soldering Iron, De-soldering iron, Probably, too, A SMT Hot Air desolderer (for the Surface Mount IC's), Compressed Air, An Anti-Static Wrist Strap, (MOST IMPORTANT, to prevent ESD), Cutters, Screwdrivers, sometimes, Torx, drivers too. Tweezers, are real handy, a magnifying glass, or eyepiece, a good strong white Light. OH, and you MUST have the original remote control too, (Sometimes one must obtain, purchase, a special “Servicing remote”) as one needs this to "Program" the Computer in the TV, after, and during servicing, and to be able to put the TV, into "Service Mode" too.
When servicing try not to let the entire thing overwhelm you as one, treat the set as a conjunction of “Units”. Meaning that we can break the unit up into sections, for instance we have a Power Supply, and Audio section, a Remote Control section, we have a Input Control section, we have a Video Control section, and so on. Now all these connect to specific parts of the circuit. Some have no relationship with each other and some are dependent upon each other. What we need to do is try to understand our “Fault” and isolate it to at least an “Area”. Now when we have isolated the apparent problem, we then need to check our “Input” to that section and also the “Output” of that section, also we must first check that sections supply voltage and current, are correct. Depending on the unit being serviced, the Repair options, may be limited to changing a “Board” to clear the fault. Often these boards are exchangeable, and you get a rebate back, if when you purchase the new board, you send them you old broken board, and they then repair that, and around it goes. Other times, one must go down to “Board level” to effect a repair, always double check, before determining some component is faulty, it is best to isolate/remove, the component to test, often an “in situ” test can give erroneous reading due to “Other” components connected, altering the readings. Always replace with as good if not better components that you are replacing, skimping of component costs is counterproductive, in the long run. It can often be a great troubleshooting method, to completely isolate the “Faulty” part of the circuit, if you can, isolate the in & out, and also remove, the “Native” power from, it too. You power from and external source, then also you can provide an External “Drive” to this circuit which you will NOW, be able to test under a, “know good” situation, which is so important to gain a benchmark for operation. NEVER EVER simply replace a Board or Component without ascertaining WHY, it has failed, as seldom does anything spontaneously fail, unless placed under stress at all operating times, such as a power Supply or the like.
www.go-gddq.com/upload/2009_02/09022211161863.pdf
Above is a training manual to help you understand what's going on.
Below is your service manual. elektrotanya.com/pioneer_pdp-506pe_pu.../download.html
Posted on Jul 17, 2010
Colors out of alignment
If you have background in electronics, you can do it. The difficult part here is on how to access those convergence amp(convergence circuit output IC). By replacing those 2 IC and some resistors sometimes, adjust the convergence and your done. Good Luck
Mar 05, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Picture not clear and looks like 3D image
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 05, 2009 | Televison & Video
Problem with focus (severe problem on upper left
The Convergence circuit needs to be repaired.
There is a pair of Convergence IC's that need to be replaced. Best thing to do is to call a repair facility unless you have a solid back ground in Projection repair.
Hope this helps,
Skyassoc
Jul 03, 2009 | Televison & Video
Convergence problem
Look in back of TV What is the number on the (2) Big Black ICs STK392-110s or ?????? If they are you need to USE STK392-180s. 110s do not hold up.
Jun 15, 2009 | JVC AV-56WP74 56" Rear Projection...
Magnavox 51MP392H Convergence Amps
I always stick with the OEM stk #'s - for one..... also it sounds like you may have some damaged resistors in the convergence section. Pull one leg of each resistor and measure the impedance of each one to make sure they are in spec.
If you need a service manual, go to techlore.com , click the Resources tab, then click technicians corner. You will be ale to click "see all downloads" and look for the magnavox 52mp392h/17,
or you can try this link:
http://www.techlore.com/group/2/list_downloads
hope all this information helps!
Jan 15, 2009 | Philips Magnavox 51MP392H Rear Projection...
Have a pioneer SD-532HD5. The red convergence is way out and curved. I am looking for the replacement numbers and where to purchase new ic's. From reading online this seems to be the solution. Does this...
Convergence ICs STK392-110s upgrade to STK392-180s Better ICs you will also need silicon heat sink compound to put on New ICs,so they dont conduct alot of heat from heat sink they are mounted too.For Parts www.electronix.com or Call 1-800-223-3205. Another compay Acme Parts 1-800-575-9833 www.acme-sales.net If you need anymore help let me know ,Thank you and have a nice Day.
Jan 03, 2009 | Televison & Video
Hitachi convergence
Only If you have any of the low ohm resistors that may be bad , The 110s Do Not hold up they can not handle the heat as well as 180s ,I have sams at my shop will look at which resistors you need to check last one I repaired had 7 resisitors i had to change out this was due to the fact customer had been watching TV for 6 months before having it fixed and i also had to clear the DUC ram and do a complete alinement on convergence it took total of 6hrs to do it from start to finish. Next set that comes in like that EST 650.00 for complete job.
Dec 27, 2008 | Hitachi 53UDX10B 53" Rear Projection...
TN50X81 - one convergence IC runs hot...TV powers off after 5min
What was the STKs that was in set ? If 110s always upgrade to STK392-180s. If they were 392-560s go back with the same. they worked differently then the 110s 150s 180s
Nov 27, 2008 | Toshiba TN50X81 50" Rear Projection...
Samsung hc-p4241w problem
Look for 2 Big black chips they will be together on convergence broad STK-392-110s,120s replace both ics.Use STK-392-180s
Mar 29, 2008 | Samsung HC-P4241W 42" Rear Projection...
PICTURE PROBLEMS
you have lost convergence. one of three boards. in the setup menu do you have convegence option. could be a convergence power supply, or convergence amplifier board.
Dec 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pioneer PDP-4270XD 42 in. HD-Ready Plasma Television Logo
253 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
