Question about Sony STR-DE445 Receiver
Not getting power, but makes a clicking sound when power botton is pressed
  • 336 Answers
One of two things.
1) open power transformer (easy but not cheap)
2) short circuit (output transistors) that opened fuse. (more difficult but less expensive)
Posted on Jul 17, 2010
I press bottom tv comes on then goes back off
On this model the power board will need to be completely resoldered, that is your problem.
Nov 29, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
When i press power botton half way works when i press full sometime work sometime don't
the switch is bad and would need replaced. MAKE note of the wiring if you attempt to do this yourself. Get back to me with the brand and model number and I will try and find you a parts source and breakdown.
Jan 24, 2012 | Drills
I placed new ink cartrages in printer and hit ink botton and it just keeps blinking,
First, Make sure you have purchased the correct type of ink for your printer model. Second make sure the cartridges are pressed firmly into place. They should make a "click" sound when pressed into place correctly. Third make sure the cover is closed on the print head and the printer access panel is closed. If you have checked the above try powering the printer off and on again and pressing the ink refill button two times.
Mar 04, 2011 | Epson Stylus CX4800 All-In-One InkJet...
How do i lock my keypad on my nokia 5130? Thanks
hello,you can kindlyb follow the shortcut procedure below,
press MENU>AND STAR BOTTON ON YOUR KEYPAD.BUT YOU HAVE TO MAKE SURE IMMEDIATELY YOU PRESS THE MENU BOTTON YOU CLICK ON THE X BOTTON ON THE BOTTOM LEFT OF YOUR MOBILE PHONE IN NOT LESS THAN 2 SECONDS.
THANKS FOR USING FIXYA.
TAKE CARE.
Apr 06, 2010 | Nokia 5130 Cellular Phone
Have Blue Screen on my laptop - STOP: 0x00000024 (0x00190203, 0x87350828, 0xC0000102, 0x00000000) Unable to access the internet to download program to fix it??
hi friend
the problem may be because of Viruses or hardware problem ,drivers problem, windows registry problem etc.
enter into Safe mode by pressing F8 key just after pressing the power botton the select
"last know good configuration " option
see if the problem get solved .
system restore screen shot click here
if not then pressing F8 key just after pressing the power botton THESE time you select" Safe mode option"
and restore the computer using system restore
click here to for system restore guide
note :use arrow keys and enter key to navigate )
please rate me
Mar 30, 2010 | Toshiba Satellite A100-S8111TD Notebook
How to turn off the safty
just click the start botton and win you see the icon name shutdown then click it or if not .press quickly the power botton, or simply go to run then just type a command shutdown -s
Mar 03, 2010 | Valor ITS-702W Car DVD Player
Will not turn on, but I do hear a click like it wants to
The power supply is probably shot. An expensive repair...mostly labor.
May 08, 2009 | Dell W2600 26 in. LCD Television
TV is not working anyore
maybe stupid but try to plug-unplog from power outlet.. does it make any sound? kliking sound? if nothing helps than your starter is gone.
Apr 28, 2009 | Panasonic PT-60LCX64 Television
HITACHI MODEL NO. 50u22ba
http://serviceman.site88.net/index.htm
Jun 23, 2008 | Hitachi 50UX57B 50" Rear Projection...
Wont power on
Good day, papamotts;
Hitachi has LED’s, green ‘lights’ and a red light to determine what circuit may be the problem; after removing the back of TV, bottom only, plug TV back in and observe which LED’s come on …..BUT most important which LED’s don’t come on; locate and note number, EG; DP37 and etc.
Good luck, big IRISH. Ps let me know.
Jun 21, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Sony STR-DE445 Receiver Logo
118 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
