Question about RCA 32F531T 32" TV
32F531T color tv loses color after about 15 minutes.
When i am watching tv it will lose color and go to black and white after about 15 minutes and it wont come back for a while it does the same wheather i am playing a game, watching tv, playing a dvd, or anything it just loses color, and also some times after about 15 20 minutes of the tv being on 1 channel it wont let me change channels how can i fix this or these problems
  • Gerry335 Dec 04, 2008
    JVC AV25SX-4 TV; Excellent picture quality but only upon switch-on has now started to smoothly fade into black & white then equally smoothly back to colour. After about ten minutes running the set stabilises and stays in colour - process repeats if I turn set off. Once set has stabilised the colour is fine / picture quality excellent throughout / no audio interference. Any suggestions please ??
  • Anonymous Mar 12, 2014
    tv black and white
  • 85 Answers
The crt socket of your tvhas a problem,coldsolder the board of your crt socket,if not working replace the crt socket.
Posted on Jun 13, 2008
50" DLP Samsung HDTV
That sounds like one of 2 things:
  1. Color wheel
  2. Light engine
Color wheel because of the losing color, but the light engine because of the picture freeze. It's very difficult to judge since I can't be there to see it. I'm leaning toward the light engine though. The only fix is to replace the DMD board, or entire light engine.
Feb 04, 2010 | Samsung HLN5065W 50" Rear Projection...
Why does my tv lose clolor? It changed from color
You haven't stated which input this happens on. Is it on all inputs or only some? Sounds like you have a problem with the control board. $130 to $200 depending on the model. Fairly straight forward swap if you are any good with hand tools. Hope this helps.
hardrocko
Jan 24, 2010 | Mitsubishi WD-52327 52" Rear Projection...
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Sep 10, 2009 | RCA 32F531T 32" TV
Temporary losing picture
CHCK THE OPTIONS MENU SEE IF IT HAS A COLOR CONVERSION OPTION ,,TRY THAT,,ALLIGN THE COLORS
May 14, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Hitachi loses color
you are losing one of your color tubes for it to be goiing to black and white.
Jan 27, 2009 | Toshiba 57H82 57" Rear Projection...
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Color fades
HELLO. it sound's like you have a cold solder problem.!!! what that mean's is that when the set get hot .!!! it lose's it's contack.!!! you might try going over the chassis .!!! soldering the conteck's.!!! with a low watt. solder gun.!!! not over 40 watt's.!!! and use 40/60 rosin core solder.!!! hope this help's you .!!! "GOOD LUCK"
Mar 14, 2008 | Hitachi 50UX58B 50" Rear Projection...
Screen losing color.. turning black and white
Your TV goes black & white, because your Wii could be NTSC or PAL which. If your Wii is PAL and your TV is NTSC then the TV will show a blac and white color. Since NTSC is for North America and PAL for Asia
Jan 13, 2008 | Nintendo Wii Console
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
RCA 32" TV - Model #32F531T - Faded to black
Isolate filament voltage from CRT,i.e. unplug Crt socket from pix tube.Measure filament voltage on CRT PCB.If present,suspect bad pix tube.If missing,solder any/all connects in filament circuit,meaning CRT board first then main PCB.
Aug 08, 2007 | RCA 32F531T 32" TV
RCA 32F531T 32" TV Logo
578 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
