Question about Bosch Rn175 Coil Roofing Nailer Nailgun
My Bostitch RN45B-1 Roofing Nailer won't advance the nails and sometimes bends or breaks them
  • Bosch Master
  • 2,005 Answers
Remove and, replace the nail advance gear then retime the nailer
Posted on Jul 17, 2010
I have a porter cable roofing nailer model # RN175 that does not advance the nails everytime what causes this?
Some causes, in order of probability:
Roofing nailers get a lot of tar build up on them, especially around the nose safety and nail feed pawl area. Cleaning off this buildup will usually take care of most problems with roofing nailers.
On the side of the gun away from the side you load the nails on there is a small cylinder with a piston inside that attaches to the feeder pawl. If air isn't getting to the piston or the piston's o-ring or spring is damaged, it won't cycle properly to advance the nails.
If the driver doesn't retract fully, the next nail won't be able to advance properly for the next shot. This can be caused by o-rings in the head that are worn or out of their proper place.
Oct 06, 2012 | Air Tools & Compressors
How do i control the depth the nail shoots in a bostitch coil nailer
The bostitch nailer pictured along along with your question is a RN46 roofing coil nailer. It has a dial on the front of the nose for adjusting depth. Some older nailers (roofing nailers) do no have a means of adjusting so were set at the factory for best performance. The question of depth usually comes up when lower bumper fails and the nail is driven too deep. Easy test. Remove nails and find a very soft piece of wood. Dry fire the gun against soft wood and measure how deep the driver is entering the wood. Harder test. Remove the head and use any handy tool to push driver down to bottom. Measure how far the driver extends past nose (should be about 1/8 to 3/16). If more, replace the lower bumper. Good luck
Jun 21, 2012 | Stanley Bostitch Nail Gun
My RN45 roofing nailer won't feed the nails I fully rebuilt it thought that was the problem, no luck same problem. Any suggestions Thanks
In our experience with RN45 feed problems it almost always has to do with the small piston on the side of the nose that moves the feed paw. Make sure all the parts and o-rings are in the cylinder properly and that the feed paw moves in its track freely. If you bought a rebuild kit it should show you how it goes together properly, if not go to www.ereplacementparts.com or http://servicenet.bostitch.com and search for your model number for a breakdown of your nailer and make sure the feed cylinder is assembled properly.
Dec 31, 2011 | Stanley Bostitch Rn45b1 Industrial Coil...
Looking operators manual for stanley bostitch rn45b
Look here for manual and parts:http://www.bostitch.com/default.asp?TYPE=STATICLEFT&PAGE=tooldoc_results.htm&Left=left_tooldoc_results.htm&partNum=WM45B&serialNum=
The two lines of address above should be all one line in the address bar. If it does not work, go to www.bostitch.com , service parts and find wm45b. Good luck
Sep 18, 2010 | Stanley Pneu Roof Stapler
Stanley coil roofing nailer not sinking 3 1/4
That model may not be designed for that length nail. Check with your local supplier.
Mar 10, 2010 | Stanley Bostitch Coil Framing Nailer
I am looking for an online manual for a Bostitch
http://www.bostitch.com/catalog_images/web_pdf/103280.pdf
Nov 30, 2009 | Stanley Bostitch HP118K 23 Gauge Headless...
My bostitch rn46 seems to double or triple shoot nails frequently. Am I not using the tool properly or could there be a mechanical problem with the tool?
if u are right nails for gun,then make sure when u put coil in and feed in front of firing pin the nails are straight with pin and connecting wires are not bent causing nails to fall out of alingnment.
Oct 02, 2009 | Stanley Factory Reconditioned Bostitch...
Nail gun not putting nail in all the way
yes ,should be on head of gun,if not try turning air preasure up.
Aug 21, 2009 | Stanley Factory Reconditioned Bostitch...
Bosch Rn175 Coil Roofing Nailer Nailgun Logo
694 people viewed this question
Top Bosch Air Tools & Compressors Experts
John Trevino
Jim Goldsmith
Jim Goldsmith
Are you a Bosch Air Tool and Compressor Expert? Answer questions, earn points and help others
